| View Poll Results: Which do you prefer? | |||
| Custom coloured/made cables |
6 | 54.55% |
| Sleeved cables with heatshrink |
1 | 9.09% |
| Paracord cables without heatshrink |
4 | 36.36% |
| Voters: 11. You may not vote on this poll | |||
Thread Tools | View Mode |
#201 | |||
Hypermodder
thanks too for the thoughts with my daughters situation, its ongoing but we are coping well, thank you. Quote:
As for hardlines I did think long and hard about it yes, but decided to stick with the look I have now as it adds to the colour and feel overall, with the finished lighting I have planned I think the hard line option would look a little harsh, and I like the softer curves with the red, personal preference I guess. Thanks for looking and taking the time to comment!
__________________
Project in progress: Bitfenix Prodigy Stacker
Interior Des(k)ign | BitPac | Bitfenix Prodigy Stacker Modding is addictive!! |
#202 | |
Professional Sleever & Modder
I just thought about your safety as its my firts rule, safety comes first ![]() I cant whait to see the rest ! Happy Modding
#203 |
Hypermodder
Just crawled through this thread and must say that you do a clean and mean job.
Your experience with cars shows clearly just with the choice of materials. I'm more of an aluminum guy myself, but I'm tempted to bust out the mig and do some welding at some point. What I like about alu is that it's a bit easier to work with and it doesn't rust, but with proper tools and finishing it of course isn't a problem. I'd like to know how the desk is going to work ergonomically? What I mean is that when the case part adds quite a bit to the height of the desk, are you going to be able to get the monitors to a proper level? I'm always bumping into problems with ergonomics since I'm quite tall, but measuring my table by eye, I'd say that the monitors (for me) would have to be mounted so that they are pretty much touching the table surface or otherwise they would be too high. You seem to have about 10cm between the top of the table and the monitors, so is the table itself lower than normal? Keep the good work up, I'll be definitely keeping my eye on this one. Darkened P.S. All the best to your daughter!
__________________
I have spread my dreams under your feet, tread softly because you tread on my dreams. Project: Orange Monster - Project: Phantom Black - Project: Red October Japhoto blog - Google+ |
#204 |
Keep calm & mod on. =)
This is going great wejjy & the side projects look easily just as much fun.
#205 |
Hypermodder
Oh, this reminds me, I forgot to comment about the Karmann Ghia, that thing looks good to say the least!
Darkened
__________________
#206 |
I think we can make that fit
What is the contraption you are using on that VW bus? I have worked on cars for a long time and never seen anything like that.
OT now The build looks great so far I envy you for having the funds, skills and patients to do this project. Im glad you did the wires it gives it a more custom look. Keep up the good work!
__________________
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses |
#207 | ||
Uniform November India
- Cut and strip the "pig-tails" - we had a wire prep machine for doing this, I just had to load it with spools, program the cuts and strips and run it. Minutes later you have 50 wires of the same length and with the same amount of insulation stripped off each end, to 1/10 of a millimetre. - Dip each end of the wires into a solder pot for a split second, evenly tinning the exposed wire. - Crimp the tinned ends. Again, this is something we had a machine for doing, which positioned the pin in exactly the right place on the wire and applied enough force to crimp the tinned ends tightly - you'd struggle to effectively crimp tinned ends with a manual crimper. - The other tinned end was usually for either inserting into a PCB and soldering in place or having another set of pins and a connector installed on. Again, I'm not putting the whole log down and it's not a major hazard or anything like that, but for future reference, make sure that you position the pins on the wire correctly and then you'll find that the solder isn't even necessary. That's a DIY version of a rollover jig or spit - it allows the vehicle to be rolled over onto either side or the roof without damage so that you can work on the underside and chassis with better access.
__________________
#208 | |||||
Hypermodder
As for the ergonomics, I am 6ft and I find it perfect for me. The screens are adjustable for height and slide side to side too. Not sure if the table is higher than normal, I dont think it is, if its any use I could measure the heights etc and let you know, but thats the advantage of this type of desk, its completely custom to me, so its perfect for my height and comfortable to sit at as it was designed around me, you could do the same too! Quote:
No need to envy me dude, Ive saved long and hard for all of the parts, and its taken me a long time as Ive not always had the focus or the patience, but I guess it was something I really wanted for a long time so Ive just stuck with it. I too am happy with the wires, but it looks as though my crimps are causing a fuss Quote:
__________________
#209 | |
Thinking about which mod to do 1st.
As for checking back... you betcha! I'm hooked
#210 | |
Hypermodder
![]() More to come soon, trying to get the glass cut and sort the lighting out amongst other things!! Thanks!
__________________
#211 |
Hypermodder
If any of you have a spare 2 minutes, it would be hugely appreciated if you'd vote for me on EK's cool new site!!! Thanks fellow Bit-Tech'rs!
http://http://www.cooledpc.com/build/77 +rep will be offered!!
__________________
#213 | |
Hypermodder
__________________
#214 |
Minimodder
I just read through the whole thing, and I gotta say you make a neat job, mate!
But you, sir, know how to handle steel All the best for your daughter! PS. you got my vote ![]() Hope to see this finished, subbed ![]() Raz out |
#215 | |
Hypermodder
Ta also for the vote, I dont have facebook so Im not getting many but slow and steady is the name of the game!! Thanks for the help... I'm still waiting for the glass so its holding me up, but it will be finished soon, I promise.
__________________
#216 | |
Supermodder
Moar pics!
#217 |
Minimodder
I am one of those lurkers who doesn't talk on forums, and just reads other's build logs because I don't have the parents that allow their 17 year old son (me) to do anything other than air cool (not even an H100) and spray paint his case. Over all, I just read this whole log, comments from others and all, and DAMN this is one sexy desk. I have wanted to do an ITX Prodigy build for a while myself, and I also think it is a great idea to do something as amazing as this. Keep up the great work.
![]() If you are not already finished with this, then I am subscribed!P.S. I hope your daughter is making a wonderful recovery! Last edited by sAnity; 1st Jan 2013 at 02:37. |
#218 |
Hope everything's ok? Did the glass turn up?
#219 |
Multimodder
I'm waiting for some updates!
#220 |
Hypermodder
Its been parked for a while as Im on the Bitfenix project currently, got fed up of waiting for things!! So decided to focus on other things to help my enthusiasm a little. It will be back on soon though!
__________________
| Tags |
| desk mod, dual loop, sr2, watercooled |
| Thread Tools | |
| View Mode | |
