Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 24th Nov 2011, 19:45   #1
iniquix
Multimodder
iniquix has yet to learn the way of the Dremel
i5-2500k overclocking on MSI P67A-GD53 (B3) Motherboard
Good Evening,
Due to my lack on knowledge on overclocking on these motherboards even after reading the bit-tech guide, (which doesn't work on this specific board). I would like to get some help from somebody who knows what to do.
Currently I have only increased the multiplier to x45 and left everything else on auto.
My questions are currently on how to specifically work with the voltages on this board. How to make a stable overclock. Or does just leaving everything on auto and taking Turbo boost, Speed spectrum off work just as well?
iniquix is offline   Reply With Quote
Old 24th Nov 2011, 19:49   #2
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.
Take the RAM speeds up to whatever it's rated for as well, then set the RAM volts to whatever the kit says to use at that speed.
Going higher than 4.5GHz will probably mean you'll need to set the CPU voltage manually at around 1.3-1.35V.
__________________
Uni Box:i5 2500K@5GHz|EK Supreme LT+Coolstream XT 240|16GB HyperX DDR3@1866MHz(in blue)|EVGA GTX670SC 4GB+EK FC670|MSI P67A-GD55||M4 256|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Sidewinder X5 + Intuos 4M
Audio: PC->TosLink->TEAC UD-H01->Schiit Asgard-> Denon 5000|PFE232|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 24th Nov 2011, 19:58   #3
Achilleas.k
Supermodder
Achilleas.k's Avatar
Achilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the Dremel
I just came here for exactly the same reason. I set up this PC in August, which is VERY hot where I am. I couldn't push the CPU clock past 4.3 GHz following the bit-tech guide (for the GD55, although I have a GD53).
Since it's gotten much colder recently, I tried to get it higher. I manage to go to 4.4 GHz without changing voltages. Any higher and I get blue screens or hangs. Now I'm stable at 4.5 GHz but I had to set voltages on "Auto", same as OP.
My question here, which I believe could (or should) concern the OP as well, is what voltages I should be watching and at what values should they be? I use speedfan events to beep when temperatures are high. What ranges should I set the voltages to for it to warn me (in case they drop too low)?
iniquix: Sorry if this counts as hijacking. It felt wrong to start a separate thread one day later for the same matter.
Achilleas.k is offline   Reply With Quote
Old 24th Nov 2011, 20:03   #4
iniquix
Multimodder
http://www.youtube.com/watch?v=3YtSpckyfe0
Don't use speedfan. Use Core Temp for one . Above may help slightly.
Old 24th Nov 2011, 20:10   #5
Achilleas.k
Supermodder
Thanks iniquix! I'll give that a try.
As for monitoring software: I've been torn between CoreTemp and SpeedFan for a while.
Coretemp is great because I get to see temps on the Logitech LCD while gaming, but SpeedFan won because I'm also worried about GPU temperatures (my old 8800 GT used to overhead quite often).
Old 24th Nov 2011, 20:12   #6
iniquix
Multimodder
Use msi afterburner for fan speed increase on your gfx card.
I've also upp'd my RAM to DDr3 - 1600mhz from 1333mhz where do I find the voltages for my RAM - manufacturers website or?
Old 24th Nov 2011, 21:36   #7
iniquix
Multimodder
I have another question after finally finding some stable results at 4.6ghz. When viewing cpu-z it sometimes drops down to 4.2ghz then back up.. any reason why? This is when I'm doing an Intelburn test
Old 24th Nov 2011, 21:41   #8
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
MrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for president
it is usually stated when purchasing the RAM the voltage it runs at.
What brand of RAM do you have?
And in future can you edit your last post instead of multi posting. Unless the post has been replied to.
__________________
MrDomRocks is offline   Reply With Quote
Old 24th Nov 2011, 21:42   #9
iniquix
Multimodder
I've found the stability at 1.64V's on the RAM just having issues with the drop down in the post above.
Old 24th Nov 2011, 21:49   #10
iniquix
Multimodder
To anyone that didn't understand the first comment When looking at the Frequency it alternates in Core TEmp and in CUP-Z from 4200 x 42, to 4600 x 46. I have no idea why it's doing this steep step ECIS all Turbo boost is all off.
Old 24th Nov 2011, 21:53   #11
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
Usually the system downclocks to 1.6ghz I have the same cpu but not mb and mine does downloack, but to 1.6ghz I am not overclocked right now but dont have any settings on auto when ocing. it's usally not best practice!
__________________
Old 24th Nov 2011, 21:58   #12
iniquix
Multimodder
nothings on Auto anymore. This is why i'm finding the problem quite strange.
Old 24th Nov 2011, 22:02   #13
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
I'm not sure, have you stopped any energy saving modes in bios?
__________________
Old 25th Nov 2011, 06:15   #14
iniquix
Multimodder
Disabled energy saving and still getting the drop from 4.5ghz to 4.2ghz while running intelburn. Weird thing was last night I had a Mem Dump for a Prime95 test that run 20 levels on standard and high in intelburn. Never had that before.
Anyone got a clue what could be causing the slow down?
Old 25th Nov 2011, 06:23   #15
iniquix
Multimodder
On top on that I can't find much info about this specific motherboard in terms on stable voltages unlike its big brother and asus counter-part. Anyone got any basics for a 4.5ghz overclock?
Old 25th Nov 2011, 06:39   #16
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
Disabled energy saving and still getting the drop from 4.5ghz to 4.2ghz while running intelburn. Weird thing was last night I had a Mem Dump for a Prime95 test that run 20 levels on standard and high in intelburn. Never had that before. <br/><br/>Anyone got a clue what could be causing the slow down?
Oddly it should drop down to 1.6ghz as that is the none load speed it runs at. And max voltage you should be putting through the i5 2500k is 1.35v at least for a stable and not overly hot cpu
__________________
Old 25th Nov 2011, 08:57   #17
scott_chegg
It's a tool.
scott_chegg's Avatar
scott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for president
Have a look at the last 3 posts in this thread. He's describing the same issue as your having.
http://forum-en.msi.com/index.php?topic=146733.0
The suggested solution is to increase the short and long power limits.
As you can see from my sig I've got a 2500K at 4.7 on a p67a-gd65. I can post my settings if it'll help.
__________________
My System: i5 2500K @ 4.7Ghz | MSI P67A-GD65 (B3) | 16GB Crucial Ballistix Sport 1600MHz | Corsair H-50 Push-Pull with Silent Eagle 2000's | Silverstone Raven RV03 | EVGA 670 FTW | Dell SP2309W | Antec 750W TruePower Blue | Win 7 x64 | Crucial 64GB C300 for OS | Samsung 830 256GB for Active Games & a 1TB Samsung for Steam. Perphiperals: Roccat Kone+ Max V2 | CMStorm Quickfire Pro with Cherry Reds | Cyborg F.L.Y 5 stick for flying and a Logitech DF GT for driving.
scott_chegg is online now   Reply With Quote
Old 25th Nov 2011, 19:22   #18
The Alfred
What's a Dremel?
The Alfred has yet to learn the way of the Dremel
I'm running those as well, and you can leave the board at Auto, but raise the CPU VCore to about 1.3V for a nice stable CPU. You might be able to lower it a little, but 1.3V is still not going to be THAT
The Alfred is offline   Reply With Quote
Old 26th Nov 2011, 16:03   #19
YEHBABY
The Millionaires are back!
YEHBABY's Avatar
YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.
I had that problem when I upgraded bios to "1E". It seems that the latest bios is buggy. I flashed bios to older version "1D" and all is well. Here is the link.
Edit: Once you get bios fixed. Try this Overclocking guide. It is for the GD55, but is still relevant to your GD53. The settings show you how to hit 4.7Ghz. But obviously this depends on your CPU. Link: http://www.overclock.net/t/963798/ms...w-and-oc-guide
__________________
i7 2700K @ 4.7Ghz // Asus Gene V // 8GB Corsair Vengeance LP // Asus GTX580 DirectCUII // Samsung 830 256GB //
2x2TB Samsung F4EG // Corsair AX850W // Antec P182 // Thermalright Silver Arrow Cooler // Dell U2412M
HTPC: 2500K // Asus Gene IV // 4GB Ram // OCZ 120GB // Be-Quiet! CM 580W // Silverstone GD08 // Synology DS209 4TB
YEHBABY is offline   Reply With Quote
Old 1st Dec 2011, 07:39   #20
iniquix
Multimodder
Ok after a lot of rubbish with this board (wish I'd gone for a different one now) and getting the newest bios 1.0F from Live Update. I've overclocked the CPU to 4.4ghz (currently) and done 2 runs on Intelburn, one standard and one on high. 10 runs each and system while slightly hotter then wanted is stable.
Current settings are CPU Core Voltage: 1.38 (to high will play around)
CPU I/O Voltage: Auto
DRAM Voltage: 1.6 (near as you can get)
System Agent voltage: Auto
All others are exactly the same as on http://www.overclock.net/t/963798/ms...w-and-oc-guide
Thank you to YEHBABY for the link it's been a big help.
Will do more testing and update the thread as I go.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
