Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 1st Dec 2011, 08:35   #21
iniquix
Multimodder
iniquix has yet to learn the way of the Dremel
Ok so upped it to 4.5ghz and here's the issues:
So while running Intelburn I've noticed the speeds from 1-10 are all random. Why is this?
I've seen loads of posts about getting down the voltage to 1.32 and below and mine doesn't even look at going under 1.37.. Any reason as to why this maybe?
The system feels sluggish compared to the 4.4ghz Overclock I did previously. While I appreciate 0.1ghz is nothing it shouldn't feel worse?
Any help on these questions would be great.
iniquix is offline   Reply With Quote
Old 1st Dec 2011, 11:18   #22
YEHBABY
The Millionaires are back!
YEHBABY's Avatar
YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.
Originally Posted by iniquix View Post
I've seen loads of posts about getting down the voltage to 1.32 and below and mine doesn't even look at going under 1.37. Any reason as to why this maybe?
The CPU voltage required is really just down to how lucky you are in the CPU lottery. Some people have got CPUs that can run at stock voltage and overclock to 4.5Ghz +, while I have a poor overclocker that requires 1.42volts to hit 4.6Ghz. I tried upping it to 4.7Ghz but it needs 1.5volts and I still wasn't sure that it was stable. After a certain point you have to ramp up volts to get stable.
I wouldn't advise going to past 1.4 volts without good cooling.
As for sluggish system, not sure what that is. How are your temps? Could it be overheating and hitting the thermal throttle which lowers speed. Also noticed that you are using new BIOS, may be buggy?
Edit: I can't see new bios on the website. Are you sure your not using 1E which is buggy. Better using 1D. I tried 1E and it did wierd things like reduce my overclock from 4.6Ghz to 4.2Ghz when I put it under load.
__________________
i7 2700K @ 4.6ghz // MSI P67A-GD65 // 8GB Corsair Vengeance LP // ASUS GTX580 DirectCUII // Samsung 830 256GB //
2x2TB Samsung F4EG // X-Fi Gamer // Corsair AX850W // Antec P182 // Thermalright Silver Arrow Cooler // Dell U2412M
HTPC: 2500K // Gene IV // 4GB Ram // OCZ 120GB // Be-Quiet! CM 580W // Silverstone GD08 // Synology DS209 4TB
YEHBABY is offline   Reply With Quote
Old 1st Dec 2011, 11:23   #23
Achilleas.k
Supermodder
Achilleas.k's Avatar
Achilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the Dremel
General OC question:
While I'm aware that keeping your eye on temperatures is probably the most important thing to monitor when OCing, don't you also have to mind if voltages are outside the acceptable ranges?
For instance, YEHBABY said not to go above 1.4 V without good cooling. So if I believe I have good cooling (which I do) and I set it it above 1.4 V, would the only thing I should worry about be heat? Shouldn't I also be worried that maybe other voltages might be dropping below normal ranges? Or is that not an issue?
Achilleas.k is offline   Reply With Quote
Old 1st Dec 2011, 12:02   #24
iniquix
Multimodder
I've actually dropped my overclock down to 4.4ghz and got it down to 1.32V. Seems to be a lot more responsive then before and also showing higher marks in Cinebench.
I'm getting a slight issue with Prime95 and 1 core not actually going through the tests like its stuck on the first one. Any reason why?
I'm using 1.0F. It's not dropping down when under load now at all. temps only peak at 65C on Intelburn on High for 10 runs. So pretty decent.
Old 1st Dec 2011, 12:38   #25
ResCyn
Multimodder
ResCyn has yet to learn the way of the Dremel
I also dropped down to 4.4GHz at 1.34v with max temps around 60C. I just seemed to get a black hole at 4.5GHz - one core would always fail under Prime95 and I was starting to push the vcore too high for my liking. After much messing around decided I couldn't be arsed solving it for 100MHz so backed it off and have been perfectly stable since.
Try pushing your vcore up slightly and see if that 4th core will complete.
__________________
CPU: i5 2500k 4.4GHz MoBo: MSI P67A-GD53 (B3) RAM: 2x4GB Mushkin Blackline DDR3 1600mhz 1.35v Cooler: Be Quiet! Dark Rock Advanced GPU: MSI 670 PE SSD/HDD: M4 128GB / Samsung Spinpoint F3 1TB PSU: Corsair HX650 Case: Define R3 Monitor: Dell Ultrasharp u2311h
ResCyn is online now   Reply With Quote
Old 1st Dec 2011, 18:12   #26
iniquix
Multimodder
ResCyn can you post your Bios settings please.
Gone up to 1.35V and still nothing on 4th core now.
Old 2nd Dec 2011, 06:57   #27
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.
Quick information, the 1.F0 BIOS is buggy as well, caused random shutdowns on my system and constant lockups as well as only being bootable with 2 filled dimm slots.
__________________
Uni Box:i5 2500K@5GHz|EK Supreme LT+Coolstream XT 240|16GB HyperX DDR3@1866MHz(in blue)|EVGA GTX670SC 4GB+EK FC670|MSI P67A-GD55||M4 128GB|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Sidewinder X5 + Intuos 4M
Audio: PC->TosLink->TEAC UD-H01->Schiit Asgard-> Denon 5000|PFE232|Truth B2030A Monitors
BT Feedback
Tangster is online now   Reply With Quote
Old 2nd Dec 2011, 08:28   #28
ResCyn
Multimodder
I'm going to be away from my PC for a few days but will certainly post them when I can. I know I used one of the guides around for the GD65 but my memory is that bad I can't remember if I ditched all the other voltage tweaks and just went with auto and upped the vcore after giving up on 4.5GHz
__________________
Old 2nd Dec 2011, 17:56   #29
iniquix
Multimodder
Ok Tangster so whats the best way to "downgrade your bios"? I don't have a flashdrive etc.
Old 2nd Dec 2011, 18:10   #30
Tangster
Tangster's Avatar
Get a flashdrive or borrow one.
Download BIOS from MSi website.
Unzip to flashdrive.
Plug in flashdrive.
Get to the UEFI BIOS.
Utilities>M-Flash
Follow instructions.
Unplug flashdrive so it doesn't try and boot from it when it restarts.
Enjoy newly stable system.
__________________
BT Feedback
Old 2nd Dec 2011, 18:41   #31
YEHBABY
YEHBABY's Avatar
Yep downgrade to bios 1D.
My system nice and stable with that.
__________________
Old 3rd Dec 2011, 11:18   #32
mkb
Supermodder
mkb's Avatar
mkb has yet to learn the way of the Dremel
Plug in flashdrive.
Utilities>M-Flash
I would avoid using M-FLASH given that the MSI forum mods advise against its use. Instead, use this:
http://forum-en.msi.com/index.php?topic=116721.0
You can also keep an eye on the beta Bios progress via this thread (you may have to register to the forum to view the thread):
http://forum-en.msi.com/index.php?topic=144655.0
__________________
i5 2500k | MSI P67A-GD53 (B3) | 2x4GB Corsair Vengeance 1600MHz | MSI GTX 680 2GB | Corsair HX 650W | 120GB Vertex 3 | 1TB Samsung Spinpoint F3 | Fractal Design R2 | Be Quiet! Dark Rock Advanced | Dell SP2309W | Sound Blaster Arena Surround Headset
mkb is offline   Reply With Quote
Old 6th Dec 2011, 07:08   #33
iniquix
Multimodder
Weirdly enough at 4.4ghz and current settings I've done 30 Maximum Intelburn tests. Prime95 still doesn't run with all cores though.. strange.
Old 6th Dec 2011, 11:44   #34
iniquix
Multimodder
Ok so after considering the options and looking to overclock slightly higher then 4.4ghz I've resorted back to 1D. Easiest way, for future reference is to unzip and install via BIOS. The MSI feature doesn't work. So my next question is how do I get up to 4.7ghz stable I'm currently running 4.5ghz fine at 1.36V
Old 6th Dec 2011, 11:54   #35
YEHBABY
YEHBABY's Avatar
Try this Overclocking guide. It is for the GD55, but is still relevant to your GD53. The settings show you how to hit 4.7Ghz. But obviously this depends on your CPU. Link: http://www.overclock.net/t/963798/ms...w-and-oc-guide
It gives screenshots which are easy to follow. I tried several guides and found this the best one.
__________________
Old 6th Dec 2011, 13:26   #36
iniquix
Multimodder
My Prime95 doesn't seem to work fully on all 4 cores yet I can do 20 runs on Maximum on Intelburn. Would you classify that as stable? If so can I use Intelburn for my testing and not Prime95?
Old 1st May 2012, 14:15   #37
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
MrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for president
I bought the magazine today and have just gone through the settings to overclock my i5 2500k. Now previously I tried some settings i found in a video guide. Whilst i ddi hit 5ghz at one point I got scared and dropped everything back to normal.
Now it seems my system doesn't like 1.3vcore or 1.35 for 4.5ghz.
it was happy with 1.3vcore for 4ghz though.
I BSOD'd at 1.3vcore for 4.5ghz and failed to boot at 1.35vcore.
I am back at stock now and I think i lost out on the cpu lottery.
But to be honest I don't need to overclock at all.
And whilst I'm still running on air I wont run any overclock for a long period of time.
Might reapply the overclock and bench my system.
__________________
i5 2500k @ 4.5ghz | P8P67 | 8gb Corsair Vengeance 1866mhz | EVGA GTX670 SC | LGIPS231 | K/B Filco Majestouch 2 | Mouse R.A.T 3 | Phones Sennheiser HD 598
MrDomRocks is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
