Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 25th Nov 2011, 14:19   #1
JamieElston
Minimodder
JamieElston has yet to learn the way of the Dremel
Is a single fan radiator enough?
Hi,
just in the process of planning out my first project build - a mod using the Lian Li PC-8NB.
Im going to install a full water cooling loop but due to case size and the fact I want to hide as much away and make it look good, im going to use two seperate loops.
Loop 1:
CPU and motherboard - single fan/radiator to be roof mounted with a bay mounted reservoir and pump hidden away at the top of the case.
Loop 2:
Graphics card - possibly RAM - again a single fan/radiator but this one mounted at the bottom/front of cabinet, with a single pump and a cylinder reservoir mounted on the frame.
The design sounds cluttered but it actually looks good and and most the Loop 1 is hidden at the top of the case behind the panel.
My only concern was that most people seem to be using a double or even tripple radiator. Would my idea still give me good cooling?
JamieElston is offline   Reply With Quote
Old 25th Nov 2011, 14:31   #2
LennyRhys
Silenced
LennyRhys's Avatar
LennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpit
Short answer - no. If you're going to use a single 120 radiator for the CPU loop you'd be as well getting a Corsair H70 or H80, or high end air cooling.
The reason most people use 240 and 360 rads is because 120 rads suck!
__________________
i7 930 @ 4.2 :: Gigabyte X58 USB3 :: 6GB Elpida @ 1528MHz 6-7-6-18-1T
GTX480 SE :: Toughpower 775w :: 320GB & 2TB :: Cherry G80-3000HSMGB
LennyRhys is offline   Reply With Quote
Old 25th Nov 2011, 14:44   #3
mars-bar-man
Side bewb.
mars-bar-man's Avatar
mars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpit
While LennyRhys has a point, I managed to cool an i7 860 OC'd to 4Ghz in an ITX rig on only a single 120mm rad, was a Black Ice Stealth GT, didn't have a brilliant fan on it either. Temps never went above 60*C.
Although in your instance I'd say go for the H-Series from Corsair. I only did mine because 1) I had most of the parts, 2) I hadn't seen a custom loop ITX build before I did mine.
__________________
Bewbs.
mars-bar-man is offline   Reply With Quote
Old 25th Nov 2011, 14:48   #4
asteldian
Supermodder
asteldian has yet to learn the way of the Dremelasteldian has yet to learn the way of the Dremelasteldian has yet to learn the way of the Dremel
Seems a lot of effort to get that kind of OC. The Hyper 212+ EVO should be able to get that kind of OC for just £23. So, either get 240 or 360 or a decent air cooler
asteldian is offline   Reply With Quote
Old 25th Nov 2011, 14:54   #5
Big Elf
'Black Noise'
Big Elf's Avatar
Big Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for president
Depends on what you're cooling. Unless your motherboard chipset runs hot or you want the bling then there's no need to watercool it. You'd probably get OK temps on the CPU with a single rad similar to a high end air cooling setup.
Graphics cards can cope with higher temps but a single rad would probably give you similar temps to the stock cooler, something like a GTX580 might struggle.
Edit: Forgot to add that you don't need to watercool the RAM either unless it's for the looks.
Big Elf is offline   Reply With Quote
Old 25th Nov 2011, 15:27   #6
JamieElston
Minimodder
Cheers for all the advice
I think RAM is a no - it was just a thought and like Big Elf said probably not rquired aside from looks.
Again same for the mobo might save some money and give that a miss.
Going to see if I can squeeze in a 240 rad - if not, back to the drawing board
Old 25th Nov 2011, 18:55   #7
dead beat
Rippin six 4 life
dead beat's Avatar
dead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for president
I would want a 360mm rad to cool a cpu and one gpu on a single loop.
__________________
ASUS ROG Maximus IV Extreme-Z68 | Intel i7 2600K @ 5.1Ghz | 2x EVGA GTX680's SLI (water) | 8GB Corsair Dominator GT RAM @ 1866Mhz | Corsair AX1200 PSU | Crucial M4 256GB SSD | 2 x Samsung Spinpoint F3 HDD's | Dimastech Easy bench Dual V2.5 | Dell 3007 WFP-HC 30" monitor | Custom dual radiator waterloop
Photography gear: Nikon D800 | Nikkor 24-70mm f2.8 | Nikkor 70-200mm f2.8 VRII | Nikkor 35mm F2/D | Nikkor 50mm 1.8D | Nikkor 85mm 1.8G | Nikon TC-14E II | SB-700 Speedlight
dead beat is offline   Reply With Quote
Old 25th Nov 2011, 19:11   #8
total zombie
jedi
total zombie has yet to learn the way of the Dremeltotal zombie has yet to learn the way of the Dremeltotal zombie has yet to learn the way of the Dremeltotal zombie has yet to learn the way of the Dremeltotal zombie has yet to learn the way of the Dremeltotal zombie has yet to learn the way of the Dremel
id consider using a double thick rad for the cpu alone.
__________________
Multi Tool Ninja!
total zombie is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
