Reply
Thread Tools View Mode
Old 25th Nov 2011, 20:45   #1
flix
Minimodder
flix's Avatar
flix has yet to learn the way of the Dremelflix has yet to learn the way of the Dremelflix has yet to learn the way of the Dremelflix has yet to learn the way of the Dremelflix has yet to learn the way of the Dremel
Lian Li PC-A70F - black and white
This is my first worklog here on bit-tech, I'm from germany and I hope you have fun reading this worklog
Normaly I'm a modder who want to do everything by his own but this time some part will be produced by CNC.
The case i will mod is a Lian Li 70FB, my intention is to make a simple and elgant build complete in black & white.
originally I dont want to change something on my actuell system by I couldnt resist to buy some new parts and we will see what else will come
my current config:
-Intel Core I7 920 Aquatuning Cuplex HD
-EVGA Sli Le cooled by EK Wasserkühler
-2x GTX 470 cooled by EK Wasserkühler
-6 GB Corsair Dominator cooled by Mips Blocks
- Laing DDC pump with Ek Top
- Phobya 360er Radi with Phobya Nano-G 12 Silent
- Phobya 240er Radi with Phobya Nano-G 12 Silent
-Aquaero 4.0
-matt black bitspower fittings
To do:
-new Front and top design
-Inlay windows
-white powder coating outside
-black powder coating inside
-build a selfmade sLight
Some pictures of parts I never want to buy but I couldnt resist as I saw them.
Some pictures:
a lot of boxes for a little bit of pump power ...
put all of it together...
New cpu waterblock...
One of the new fans...
here some pictures of my last two projects I'm still working on:
1.
2.
[IMG]http://i464.photobucket.com/albums/rr5/flix_album/P1010455.jpg[/IMG
A Big thanks to Ek, Coldzero and Enermax:
flix is offline   Reply With Quote
Old 25th Nov 2011, 21:02   #2
mars-bar-man
Side bewb.
mars-bar-man's Avatar
mars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpit
Love it!
__________________
Bewbs.
mars-bar-man is online now   Reply With Quote
Old 29th Nov 2011, 21:05   #3
flix
Minimodder
flix's Avatar
Today a very nice package from EK arived
Old 1st Dec 2011, 20:08   #4
flix
Minimodder
flix's Avatar
This nice stuff was in there:
Cant wait to work with it
Old 1st Dec 2011, 20:56   #5
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
looks nice i wil be subbing this one !
KoSoVaR^ is offline   Reply With Quote
Old 16th Dec 2011, 10:37   #6
flix
Minimodder
flix's Avatar
Some more Pics for you
The CPU Cooler:
and here the "naked" Case:
I have to work faster, my actually Setup is really loud and the temps arent nice...
Old 16th Dec 2011, 14:30   #7
OmightyOne
Multimodder
OmightyOne's Avatar
OmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the Dremel
so jellous of the ek parts, keep it up, will be keeping an eye our for this one!
__________________
The Tank - Intel i7 920 @ 4ghz - Nvidia 560ti F/OC (Main) Nvidia gtx 460 F/OC (Physx) - 6gb 1866mhz ocz Reaper Ram - F3 1TB - Coolermaster 850w slient pro - CM HAF case - Custom water loop!
OmightyOne is offline   Reply With Quote
Old 10th Jun 2012, 19:25   #8
flix
Minimodder
flix's Avatar
After a long time I want to continue...
But I wasnt inactive, in the last winter I worked on a project which was part of an contest. with that case I won
klick for some more pics
But I dont write an update to tell you that i've won a contest. ^^
I want to show you the next steps on this project.
In this Case should fit a 420er and an 280er radiator, so i have to do some changes on that case.
At first some rivets must be removed and than I changed the profiles from the upper part.
But I think pics say more than words
I want to mount the Radiator without seeing some screws or rivets, so i have to make a extra mount for it.
At last some pics showing the mounted radiator.
I hope i can continue soon...
And sry for my english...
Old 10th Jun 2012, 20:20   #9
KrunchR
Supermodder
KrunchR's Avatar
KrunchR has yet to learn the way of the Dremel
nice work
__________________
SYSTEM ONE on hold for now....
But my KnuckleDuster makes a Return!
For sale! lian li pc7
KrunchR is offline   Reply With Quote
Old 7th Aug 2012, 13:02   #10
flix
Minimodder
flix's Avatar
I have some Updates for you, I hope you like it
I have to customize the ODD Tray. Without doing that, the radiators wouldnt fit.
without cuts:
After a little Dremel session
Does it fit into the case?
it does!
Than i had to addept the profiles for the 420 radiator:
And again a picture with that part in the case
Old 22nd Aug 2012, 20:02   #11
flix
Minimodder
flix's Avatar
Its time for an update
I've made the radiator mount in the front.
At first i made some cuts on the case..
And than I've cut the fanbezel.
After that, it goes on with the "tubing" in the Front. I want to seperate the radiators easily so i want to use some Bitspower parts to make it possible.
It tooks a lot of time but now its nearly done
Some Bitspower parts are still missing...
I hope you like it
Old 22nd Aug 2012, 21:48   #12
dietje1908
Minimodder
dietje1908 has yet to learn the way of the Dremel
I do :-)
dietje1908 is offline   Reply With Quote
Old 26th Aug 2012, 09:16   #13
flix
Minimodder
flix's Avatar
Nice Someone likes my project
Today i have another update for you
I've cut a small aluminium plate and glued it on the opticaldiksdrive bay (right name?^^)
Afther that, i started to make a new mount for the power supply. Later i want to use a Lightbox/sLight as a midplate, but the original profile whre to high, so i have make two new ones.
These are the original ones
two new profiles
than i adapt them
lastly i make two sheets for the "walls"
its done
Now there is much more space for a Lightbox
On Friday some new Bitspower parts arrived, so i want to use them
the tubing in thi ODD-bay is nearly final
bye
Old 7th Sep 2012, 19:42   #14
flix
Minimodder
flix's Avatar
Small Update for you.
For a cleaner Look I filled the holes in the ODD Bay.
And I have to choos the way of mounting the pumps. Which one did you prefer?
Old 12th Sep 2012, 10:36   #15
flix
Minimodder
flix's Avatar
Today I can proudly present you a sponsor for this project.
Enermax will support this project with some fans and a power supply.
The Fans arrieved today, they are so nice
I will use 5x 140mm Cluster and one 120mm Cluster.
Some pics of this beautis
Included in Delivery are 4 screws, 4 shock-proof isolator-mounts and 3-pin zu 4-pin molex adaptor.
The fanspeed can be regulated by4-Pin PWM mainboard fan control but i will use an Aquaero
Now I have to finish this mod to use them.
So here is the next Update:
I've made a new cover for the power supply.
fits very well, didnt it?
After that I've done something I dont want to do ^^ But sometime I had to do that. I have drilled the holes for the acryl parts in the front part. It was noch easy but now everything can be mounted.
All parts assambled:
with all parts in it:
Thank you Enermax.
Old 13th Sep 2012, 16:29   #16
jeckulz
Supermodder
jeckulz's Avatar
jeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremel
Watching this one for sure...
This is the very case Im planning on getting myself.
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz
OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb
Coolermaster 600w Silent Pro Modded Lian Li PC-0700
jeckulz is offline   Reply With Quote
Old 18th Sep 2012, 07:48   #17
flix
Minimodder
flix's Avatar
Hey,
yes, its a very nice case, LianLi builds the best cases
Small update:
Now I have nearly finished the drilling of holes and i'm very happy with that. That work sucks but it has to be done.
Besides that, I have renewed the profiles for the motherboard tray.
old one disassembled:
And the new profiles mounted:
To get a waterflow from reservoirs to the pumps I have drilled a new hole.
After that, the construction has to be leak testet.
I have to disamble everthing for three times because it was leaky but I hope now it is not leaking anymore. I will test it again when I have done the following part.
At first I cutted some Plexi parts
and want to drill some wholes in it...
... fail -.-
At second attempt it works.
Have a look how it will look with the pumps mounted.
And agains some nice news
Coldzero will sponsor me a lightbox.
Thanks
Old 8th Oct 2012, 13:09   #18
flix
Minimodder
flix's Avatar
Hey,
its me again
During the past two weeks I've made nearly every day some stuff on this mod. But it was'nt really appreciable but all in all the is an progress.
At first you can see the mounting plate for the two D5 pumps.
Besides that If mounted the waterblocks on the hardware and I got the nice Lightbox from Coldzero.
Here you can see how the Lightbox works:
The lower part comes glued together, in the middle of the Box there is a 10mm thick claer plate, which have an (engraved or lasered) checked pattern in it.
Because of that the diffusion of the light is very nice. The top plate of the Lightbox isnt normal white plexi, it also diffuses the light,
Here you have an small overview over the status quo.
I hope you like it
And again a big Thanks to my sponsors:
Old 9th Oct 2012, 06:47   #19
jeckulz
Supermodder
jeckulz's Avatar
Becoming one of my favorites very quickly.
Nothing revolutionary being done, but it's looking to be nicely executed.
Great work mate.
__________________
Old 9th Oct 2012, 20:19   #20
flix
Minimodder
flix's Avatar
Thank you, I try my best
Today I continued the connection plate between the reservoirs, pumps, Grafikcards and CPU.
At first I drawed the waterways on the top plate:
After that, I marked the holes on the middle plate(8mm plexi):
Drilled the holes and the first cuts:
There is still one way missing, I've forgotten to take pictures of that.
This part is already filed and I hope I can glue these parts together tomorrow.
I think you can get how I will route the waterway and I think I can reach my ambition to get a watercooling setup without flexible tubes.
Here again some pictures of it in the case.
That it for the moment.
Thanks for reading
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
