Reply
Thread Tools View Mode
Old 9th Oct 2012, 22:08   #21
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
This mod looks very promising my friend! Mod on!
AnG3L is offline   Reply With Quote
Old 10th Oct 2012, 14:25   #22
whyte
Multimodder
whyte's Avatar
whyte has yet to learn the way of the Dremelwhyte has yet to learn the way of the Dremel
Simply amazing
__________________
Project Carbon Apple
whyte is offline   Reply With Quote
Old 14th Oct 2012, 21:01   #23
flix
Multimodder
flix's Avatar
flix should be considered for presidentflix should be considered for presidentflix should be considered for presidentflix should be considered for presidentflix should be considered for presidentflix should be considered for presidentflix should be considered for presidentflix should be considered for presidentflix should be considered for presidentflix should be considered for presidentflix should be considered for president
Thank you
I have a small update for you.
I've agglutinated the three plates. It doesn look perfect but for me its more than enough because there will be an aluminium sheet mounted on it. However I have to grind and polish it.
On top I made a scre thread. I'm so happy that it works, one fail and the whole work was for nothing. But it works
Here you can see some air pockets, next time I have to use more glue to avoid that.
Thanks for reading
flix is offline   Reply With Quote
Old 22nd Nov 2012, 13:04   #24
flix
Multimodder
flix's Avatar
I have a "small" update for you
I bought a hole saw, very usefull tool.
works great:
Filed down the metal sheet.
After that, I continued with the inside fan grill for the upper side of the case.
At first marking -> center punshing -> drilling
At first with a 3,5mm drill and final with a 10mm one
After I've drilled all holes I have to connect them. I took my jigsaw an began to cut.
filed and grinded
The metall sheet for the front inside must be bended, so this was my bending mashine ^^ :
This was the result:
I think: big fail
Next try becomes much better. I milled a dent into the sheet. I used a Dremel and file.
I was very happy with the result so I want to make the final sheet. The bending looks nice but the holes I drilled before were at a wrong positions.
Next try:
Finished that and make a side panel for that.
assambled everything again:
Hope you like it
Old 22nd Nov 2012, 14:39   #25
Razarach
Multimodder
Razarach's Avatar
Razarach is a hoopy frood who really knows where their towel is.Razarach is a hoopy frood who really knows where their towel is.Razarach is a hoopy frood who really knows where their towel is.Razarach is a hoopy frood who really knows where their towel is.Razarach is a hoopy frood who really knows where their towel is.Razarach is a hoopy frood who really knows where their towel is.Razarach is a hoopy frood who really knows where their towel is.Razarach is a hoopy frood who really knows where their towel is.Razarach is a hoopy frood who really knows where their towel is.Razarach is a hoopy frood who really knows where their towel is.Razarach is a hoopy frood who really knows where their towel is.
Very nice my friend
Razarach is offline   Reply With Quote
Old 22nd Nov 2012, 14:59   #26
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
Wow, this case is really nice!
__________________
Current projects: Tydirium is on the way!
Previous mods: |Sandcrawler Mod| |Illuminated Mind| |Graphite5|
Follow me on Facebook
nagyizom is offline   Reply With Quote
Old 23rd Nov 2012, 10:46   #27
dreps
Multimodder
dreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremel
looks very nice aready can't wait to see the finished result
dreps is offline   Reply With Quote
Old 23rd Nov 2012, 20:40   #28
whyte
Multimodder
whyte's Avatar
absolutely amazing. your skill w with a jig saw is impressive.
__________________
Old 26th Feb 2013, 20:56   #29
flix
Multimodder
flix's Avatar
Thank you guys
After a long break I will go one with this project
In the last months I work on a Lian Li Casemod for a Contest. For anybody who is interested, pictures can be seen on my Facebook page.(page is still in german, I'm thinking about switching to english if somebody is interessted)
Old 26th Feb 2013, 21:15   #30
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Looks great but to avoid the air poccets in the plexiglass use plexiglas cement.
dream1 is offline   Reply With Quote
Old 26th Feb 2013, 21:16   #31
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
Wahnsinn, ich wünschte ich könnte auch nur ansatzweise so gut mit Metall umgehen. Super Projekt bisher!
elAwesome is offline   Reply With Quote
Old 27th Feb 2013, 06:24   #32
Saltire35
Drunken Scotsman
Saltire35's Avatar
Saltire35 has yet to learn the way of the Dremel
Any plans on powder coating the interior ?
Excellent build btw. from me.
*Edit* Apologies, just read your initial post... can't wait to see the powder coating done.
Saltire35 is offline   Reply With Quote
Old 27th Feb 2013, 11:19   #33
flix
Multimodder
flix's Avatar
Thank you guys
@saltire35: I actually dont know If I will powder coating this case. There are some reasons that prevents my doing that. I can do it on my one. I filled some parts with normal filler. I already have some cans of varnish here.
But I know... powder coating would by nicer... I'm still undetermined.
Old 9th Mar 2013, 13:10   #34
flix
Multimodder
flix's Avatar
Small Update for you
Maybe you allready have noticed that I aspire a clean look. So I want to hide all cables.
I decided to make a 90° connector.
This is how I have done this:
original state:
drilled some wholes and cut down the overlaying pieces:
organised some flat cables, cut and crimped them:
The first cables in the connector:
Cut out this piece of aluminium:
and glued it on the connector by using 2K glue. need to file it down a little bit.
The cables should disappear behind the aluminium plate:
Besides that I bought some self made circuit boards, I will use it to make the connectors for the GPUs.
At first I cutted a small sheet to have the PCB. Cutting this smells like hell
I have to the crimps and soldered in some whires:
And nearly finished, just the cables are missing:
Gpu connector finished on the side of the gpu. My soldering skill aren't very good, but I will make a cover for it.
Thats it for now
Old 9th Mar 2013, 16:57   #35
mansueto
Too broke to mod
mansueto's Avatar
mansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyan
I really like what you're doing with the cables, I think it's an awesome idea! Really looking forward to seeing how this shapes up! Keep up the good work.
__________________
Black Momba: i5 2500k @ 4.5ghz | Corsair H80 | MSI P67A-G43 | 16GB DDR3 1600 Ripjaws | 128GB Corsair M4, 1TB Barricuda | Gigabyte R9 380X | Asus PA248 IPS + Acer P243w | Asus Xonar D1 + Fio E07K Andes | Windows 7 Ultimate x64 | Seasonic X760 | Fractal R3 | Corsair Vengeance K70 w/ Browns | Razor Deathadder Chroma
Lenovo U410: i7 3517u | 8GB ram | 24GB + 750GB HDD | 14 inch ultrabook
mansueto is offline   Reply With Quote
Old 1st May 2013, 19:09   #36
flix
Multimodder
flix's Avatar
Thank you
Lately I dont have the time to work a lot on this project, but I've done some small mods to on the hardware.
I've opened the Laing D5 to change the cables:
Besides that I decided to change some parts on the mainboard, it was too colorful...
... and I cleaned the caps and removed some decals:
Some more pictues:
Old 2nd May 2013, 08:18   #37
dreps
Multimodder
sir you got skills!! I would have never messed with the Mobo connectors
Old 6th May 2013, 08:00   #38
maRiio
Multimodder
maRiio's Avatar
maRiio has yet to learn the way of the DremelmaRiio has yet to learn the way of the DremelmaRiio has yet to learn the way of the Dremel
That's some nice MoBo-modding there I especially love the connections for both of the graphics cards
__________________
Projects
Rusty NAS - in progress | Rusty HDD-Case(s) - finished
Social
Facebook
maRiio is offline   Reply With Quote
Old 2nd Oct 2013, 08:37   #39
flix
Multimodder
flix's Avatar
Yes its true, it goes on
The power Connector for the VGAs and Mobo seems to work, but the hardware in general seem to have some problems... even with some original cables...
At the moment I think I will change the whole hardware... at first this was just a fun project, but now I think I will use this system as my main system.
The problem is, that the tubing routes are defined by the acryl plate with the pumps. I need a mainboard which has an PCI-E Slot at the second and sixth position on a normal ATX Mainboard. I couldnt find a fitting board with a Z77 or Z87 chipset. Hmm... If I want to change, I need to upgrade on a X79 System.
Thinking about this problem I want to do some metal work.
I cutted and bended an aluminium sheet for the front.
This is the current status:
Old 18th Nov 2013, 06:11   #40
Primum Agmen
Multimodder
Primum Agmen has yet to learn the way of the Dremel
That's certainly a nice front panel. Planning to polish it/brush it/bead blast it?
Primum Agmen is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
