Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 26th Nov 2011, 23:20   #1
TraumaticHug
Multimodder
TraumaticHug has yet to learn the way of the DremelTraumaticHug has yet to learn the way of the Dremel
Memory - 1.50V vs 1.65V (and scan ratings)
So while choosing between 4GB of DDR3 1600MHz memory I came across 2 seemingly identical memory modules. The only difference being one runs at 1.65V and is £20, while the other (dubbed "Classic") runs at 1.50V and is £22.
CMX4GX3M2A1600C9 1.65V
CMX4GX3M2B1600C9 1.50V
I would have thought that the 1.50V would have been the better of the two as at runs at the same "recommended" voltage as most of the processors I have been looking at, or is the voltage what it can easily handle, not what it runs at, and therefore the 1.65V is better for overclocking?
Scan gave the 1.50V 2/3 stars while the 1.65V got 3/3 stars, and I can't figure out why.
Do scan ratings really count for much?
__________________
AMD 955BE 3.2GHz | M4A88TD-V | 4GB | MSI GTX 560Ti 1GB OC | WD Caviar Blue 6GB/s 1TB | XFX Black Edition 750W |
CM 690II | BenQ E2220HD
TraumaticHug is offline   Reply With Quote
Old 27th Nov 2011, 00:37   #2
Blogins
Panda have Guns
Blogins's Avatar
Blogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpit
The lower the voltage the better, generally speaking. Haven't a clue as far as AMD go however.
I have a 1.25v kit myself and it's nice and cool in a Sandy Bridge rig!
__________________
|Fractal Design Define R3, Black Pearl (Case)|ASUS P8P67 Deluxe (Motherboard)|Intel® Core™ i5-2500K (Processor)|
|G-Skill 8GB DDR3 1600mhz Sniper 1.25v (Memory)|ASUS GTX 670 / Gigabyte GTX 670 (SLI Graphics)|
|Corsair Professional Series Gold AX 850W (Power Supply Unit)|Asus Xonar D2X PCI-Express (Sound Card)|
|OCZ Vertex 3 120GB (Solid State Drive - Boot)|OCZ Vertex 3 240GB (Solid State Drive - Games)|
Blogins is offline   Reply With Quote
Old 27th Nov 2011, 00:43   #3
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
Nothing to do with CPU voltage, basically lower voltage means less power consumption and lower running temps. With AMD mobos always go for the higher voltage stuff as some can pull a lot of voltage. One of my old mobos used to want to draw 1.9v when left of auto settings. That said good ram will take about 2.1v going through it.
bulldogjeff is offline   Reply With Quote
Old 27th Nov 2011, 01:04   #4
modd1uk
Corsair Fan
modd1uk's Avatar
modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!
That the G.Skill Sniper stuff ?
__________________
Corsair 800D :: ASUS P8P67-EVO :: i5 2500K :: 8GB Corsair Vengeance :: MSI Twin FrozrII GTX 570 :: Corsair HX520 :: Corsair H100 :: Samsung 830 256gb :: Samsung F3 :: Samsung F4
Originally Posted by loftie View Post
^+1
Energy saving light bulb agrees with the incandescent bulb.
modd1uk is offline   Reply With Quote
Old 27th Nov 2011, 05:49   #5
noizdaemon666
I've been away far too long
noizdaemon666's Avatar
noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.
If it's a Sandy Bridge(E) setup you're going for, get the 1.5V stuff. That's the highest recommended memory voltage by Intel. Using 1.65V memory would work but might cause long term damage to the CPU's memory controller.
Oh and 1.5/1.65V is the voltage that they run at when running at stated speed. And Scan ratings mean bugger all really lol
__________________
AMD A4 5300 @ 4GHz | | 4GB 1600 Patriot | 128GB SSD | 500GB Samsung HD501LJ | 320GB Hitachi 2.5" | CX430 PSU
noizdaemon666 is offline   Reply With Quote
Old 27th Nov 2011, 08:07   #6
YEHBABY
The Millionaires are back!
YEHBABY's Avatar
YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.
This.
Get 1.5v and take no notice of scan's ratings.
Also memory so cheap why not get the 8GB?
__________________
i7 2700K @ 4.6ghz // MSI P67A-GD65 // 8GB Corsair Vengeance LP // ASUS GTX580 DirectCUII // Samsung 830 256GB //
2x2TB Samsung F4EG // X-Fi Gamer // Corsair AX850W // Antec P182 // Thermalright Silver Arrow Cooler // Dell U2412M
HTPC: 2500K // Gene IV // 4GB Ram // OCZ 120GB // Be-Quiet! CM 580W // Silverstone GD08 // Synology DS209 4TB
YEHBABY is offline   Reply With Quote
Old 27th Nov 2011, 13:56   #7
Blogins
Panda have Guns
Blogins's Avatar
That's it, as in my sig!
__________________
Old 4th Dec 2011, 22:50   #8
TraumaticHug
Multimodder
Just to quickly check before putting it in tomorrow (as I bought both with a view to returning the unused modules):
Using lower voltage memory won't damage anything?
So AMD Phenom II 975BE would be fine with 1.50V memory?
The motherboard's (Asus M5A97) memory compatibility list has the 1.65V Corsair XMS3 4GB, but not the 1.50V.. ut could be that they just didn't test the 1.50V.
__________________
Old 5th Dec 2011, 00:53   #9
sb1991
Supermodder
sb1991's Avatar
sb1991 has yet to learn the way of the Dremelsb1991 has yet to learn the way of the Dremelsb1991 has yet to learn the way of the Dremelsb1991 has yet to learn the way of the Dremelsb1991 has yet to learn the way of the Dremel
Using the lower voltage memory won't cause any damage, no. The memory will almost certainly run fine at 1.5V, if it's unstable for any reason you can always raise the voltage to 1.65... it takes a lot more to cause damage to the memory: the rated voltage is really a minimum - basically, the better RAM can be run at a lower voltage, but it'll all handle more. In general, the maximum voltage will be limited by the CPU/memory controller, rather than the RAM itself. In the case of an AMD system, the memory controller will handle rather high voltages, but it's always nice to have the option of using your memory in another system, and the newer Intel CPUs are best kept at or below 1.5V here.
The fact that the memory isn't listed by Asus probably just means that it hasn't been tested, yes. If there are other 1.5V modules listed, it'll almost certainly be fine. Otherwise, you might need to raise the voltage (but probably won't).
__________________
Lian Li PC A05NB - AMD 955BE@3.8GHz - XFX ATI HD5850 - 8GB DDR3@1333MHz - 2x1TB Spinpoint F3 - Corsair Force 3 120GB - Enermax Modu82+625W - Asus Xonar D2X - Dell 2408wfp (A02) - Filco Majestouch II Ninja (browns) - Mackie MR5 x2
sb1991 is offline   Reply With Quote
Old 5th Dec 2011, 01:42   #10
Roskoken
Multimodder
Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.
Surely everyone should just go for 1.35v then like the rather choice arctic white corsair vengeance modules.
Roskoken is offline   Reply With Quote
Old 5th Dec 2011, 02:35   #11
Bindibadgi
Omnipwntent
Bindibadgi's Avatar
Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.
The difference between memory and IMC voltage must generally be within 0.5V for it to remain healthy, and as AMD 975BE runs higher voltages than the equivalent Intel, then 1.65V is fine.
__________________
Slash88: That kettle video just made me go death thanks.
Fizzban: And it is being panda'd to..lame.
Bindibadgi is offline   Reply With Quote
Old 5th Dec 2011, 04:50   #12
tonpal
Hypermodder
tonpal has yet to learn the way of the Dremeltonpal has yet to learn the way of the Dremeltonpal has yet to learn the way of the Dremeltonpal has yet to learn the way of the Dremel
If you want to be reassured about compatibility, I would suggest checking the memory configurator tool on the Corsair site. Memory manufacturers have a more comprehesive compatibilty list for their products than motherboard manufacturers.
tonpal is offline   Reply With Quote
Old 5th Dec 2011, 10:48   #13
TraumaticHug
Multimodder
Excellent, thanks guys!
It feels like building a PC was easier when I knew less
I should be helping him build it tonight.. I think everything but the CPU and monitor will arrive today. Hopefully I won't be too anal about the cable management or I'll be there all night
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
