Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 30th Nov 2011, 08:56   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Asus Sabertooth X79 Review
LGA2011 has finally landed, so we've looked at Asus' most expensive Sabertooth motherboard yet.
http://www.bit-tech.net/hardware/mot...h-x79-review/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 30th Nov 2011, 09:28   #2
K.I.T.T.
Hasselhoff™ Inside
K.I.T.T.'s Avatar
K.I.T.T. has yet to learn the way of the Dremel
Conclusion
The Asus Sabertooth X79 is a treasure trove of useful and interesting features. It might cost more than other manufacturers' offerings but it has the best cooling, EFI and overclocking and monitoring software of any LGA2001 board we've seen.
2011?
__________________
i7 3770K @ 4.6GHz [WC] | 16GB Corsair Dominator Platinum | 2x Power Color HD7870 PCS+ [WC] | Asus P8Z77WS | Corsair AX850 | 250GB Samsung 830 | 1TB WD Caviar Black
K.I.T.T. is offline   Reply With Quote
Old 30th Nov 2011, 11:47   #3
[USRF]Obiwan
I *am* a Dremel
[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.
If you remove all the fancy stuff it has the same performance as any other X79 board out there. I mean a 1 to 3 point difference is not noticed by anyone in real world use. If you remove all static benches and compare motherboards with no tools at all but common sense they would have all the same performances but one looks better then the other and that is just personal taste. Once it is in your PC nobody G.A.F. anymore.
Personally, i really do not care anymore what motherboard or memory is in my PC as long as it is cheap. It will last a few years and do a upgrade. You don't have to do it for the games, most of them are console ports anyway. And even MW3 runs perfectly fine with all 'ultra' on a GT460 on HD res on a Phenom quad core.
For 320 pounds you have a Asrock motherboard, 8GB mem, quadcore and a MSI 460 graphics cad that can play the latest games and is a fine and cheap daily use PC. That is just 65 pound more for the price you pay for this fancy motherboard alone. It is ridiculously expensive and for what?
__________________
[USRF]Obiwan is offline   Reply With Quote
Old 30th Nov 2011, 12:21   #4
shaunster1011
Multimodder
shaunster1011 has yet to learn the way of the Dremel
Not everyone just plays games on there PC, you know?
__________________
My PC in a desk
shaunster1011 is offline   Reply With Quote
Old 30th Nov 2011, 12:44   #5
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
So for £255, what kind of shelf life will that buy in terms of Intel releasing compatible CPU's, given their lamentable track record for changing sockets?.
I'll be moving over to a SandyBridge setup in the new year, but TBH, i think it makes more sense to buy a mid range £100-£150 Mobo and change it again in 12mths for a similar amount of money, rather than splurge £255 on a CPU socket that might be dumped by Intel in late 2012.
So, 2 mid range boards or 1 top end board now..?
Hustler is offline   Reply With Quote
Old 30th Nov 2011, 13:05   #6
HandMadeAndroid
That's handy.
HandMadeAndroid has yet to learn the way of the DremelHandMadeAndroid has yet to learn the way of the DremelHandMadeAndroid has yet to learn the way of the Dremel
Oh look another motherboard with silly gun design elements. Sometimes I'm embarrassed to be a man.
__________________
i7 3770k, Asus P8Z77-I , 16gb Patriot 1866 ddr3,EVGA 670FTW, Bitfenix Prodigy,crucial M4 128ssd,western digital black 2tb storage, wacom intuos/ i7 sandy bridge kobalt 17" laptop,120ssd, 8gb crucial ram, 500gb7200 WD storage drive, nvidia 555m 3gb/64gb iPad 2
HandMadeAndroid is offline   Reply With Quote
Old 30th Nov 2011, 13:17   #7
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
Ivy Bridge E - due out around this time next year - will fit in LGA2011, as far as we know.
Claave is offline   Reply With Quote
Old 30th Nov 2011, 13:18   #8
K404
It IS cold and it IS fast
K404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run Crysis
Where are the gun elements??
__________________
Completely correct but utterly wrong
K404 is offline   Reply With Quote
Old 30th Nov 2011, 13:52   #9
Risky
I Mod, Therefore I Own
Risky's Avatar
Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.
How noisy is the board with those two fans. I'm not keen of whiney 40mm jobbies, but it's been a while since I had one and perhaps the tech has improved.
__________________
As a rule watercooling can be simple, affordable and effective... I guess I just like to break the rules.
Risky is offline   Reply With Quote
Old 30th Nov 2011, 14:06   #10
Pete J
RIP Teelzebub
Pete J's Avatar
Pete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming Saiyan
Obiwan]For 320 pounds you have a Asrock motherboard, 8GB mem, quadcore and a MSI 460 graphics cad that can play the latest games and is a fine and cheap daily use PC. That is just 65 pound more for the price you pay for this fancy motherboard alone. It is ridiculously expensive and for what?
Some of us want to play Crysis on ultra high settings at 2560x1600 - with AA.
__________________
Latest system review here / I also have a laptop: Gigabyte P35X v6
HTC Vive review coming soon!
Pete J is offline   Reply With Quote
Old 30th Nov 2011, 14:43   #11
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
They're about as noisy any other ones but the Thermal Radar fan control software allows you to fine-tune the fan speed profiles to suit you.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 30th Nov 2011, 14:51   #12
Hustler
Hypermodder
Hustler's Avatar
I was really thinking about what comes after Ivy Bridge, because i assume Ivy Bridge E will follow the same price structure (complete rip off) as the Sandy Bridge E's that have just been released...there is no way I'm paying £500+ for a CPU.
Old 30th Nov 2011, 15:09   #13
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
Those CPU are oriented toward professionnal, not end-user. I look at them more as XEON substitute rather than Pentium. IMHO, the actual XEON lines doesn't differ to much from the core iX series (except some monitoring features and 2-way support for the higher ones). Real professionnal CPU is what Intel was lacking.
GuilleAcoustic is offline   Reply With Quote
Old 30th Nov 2011, 15:32   #14
trig
god's little mistake
trig's Avatar
trig has yet to learn the way of the Dremeltrig has yet to learn the way of the Dremeltrig has yet to learn the way of the Dremeltrig has yet to learn the way of the Dremeltrig has yet to learn the way of the Dremel
definitely a little homer-ism in that review...i get the added value of the fan software...but not that much...defo doesn't deserve a 21 of 25 for that price...bit's reviews in the past focus on general usage, with an addendum of some sort that "IF you are a heavy multi-threaded app user who needs the extra ram and software features, this is a decent deal for you but for the majority of users this just isn't the best value." this review felt more like "it doesn't matter what kind of a user you are, buy this board i wantz to make babies"...
__________________
i5-4670K @ stock w/scythe mugen 4-msi z97m gaming-8 GB 2400 mhz gskill-asus strix gtx 970-phantek enthoo evolv matx-evga 550 G2 psu-512 gb mushkin boot drive-wd black 1.5 tb 32mb cache & various other ssd storage-logitech gx9 mouse g510 keyboard-aoc g2460pg
trig is offline   Reply With Quote
Old 30th Nov 2011, 17:08   #15
HandMadeAndroid
That's handy.
The 'magazine' heat-sink
__________________
Old 30th Nov 2011, 17:10   #16
Combatus
Moderator
Combatus's Avatar
Errm you might want to re-read the final paragraph...
if you're not dealing with professional multi-threaded applications all the time, an LGA1155 system remains the better option
__________________
Old 30th Nov 2011, 17:50   #17
trig
trig's Avatar
errm...i did...you should re-read the post...i wasn't referring to platform recommendations...i was referring to the mobo recommendations...you don't have to be a professional multi-threaded app user to want an x79 system
__________________
Old 30th Nov 2011, 19:30   #18
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyan
IB-E is definitely compatible with SB-E motherboards.
http://www.cpu-world.com/news_2011/2...-E_socket.html
http://vr-zone.com/articles/intel-iv...e-e/14006.html
__________________
HeatWare
debs3759 is offline   Reply With Quote
Old 30th Nov 2011, 19:31   #19
rollo
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
90% of the people speaking in this thread are not the target market.
If you want an x79 system for any other reason than multi threaded apps then you have more money than sence as the 2500k overclocked is still faster in 90% of all games tested.
£500 for a 6 core cpu still beats the £780 than intel want for a 980x or 990x for that matter.
if you need a 6 core cpu then £500 is pretty dam cheap compare it to the xeon systems out there which start from £4k Onwards on just cpus if you go high end. or you could go Amd they have an 8core for £230 ( but its out performed alot )
Thermal radar sounds awesome can we have a review of just that.
rollo is offline   Reply With Quote
Old 30th Nov 2011, 19:36   #20
debs3759
debs3759's Avatar
<double post>
__________________
HeatWare
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
