Reply
Thread Tools View Mode
Old 1st Dec 2011, 00:41   #1
secretreeve
Lead design and realisation manager
secretreeve's Avatar
secretreeve has yet to learn the way of the Dremel
The ULTIMATE computer case
Welcome to the Ultimate computer case worklog thread on specialtechs forums!
This is a bit of a large project due to the sheer size of the case.
The Pillar case is so called because its quite literally a Pillar of technology, measuring in at 2ft wide by 2ft deep, the real jaw dropping magnitude comes in with its height, SEVEN (yes 7!!!) full length feet make up the height of this goliath!
Consisting of an aluminum framework there will be 3 sections of grilled/meshed areas for radiator mounting, 2x2ft x 2ft acrylic panels with a custom terra nova themed pattern which will be backlit red.
A BIG BIG thank you to specialtech, pc cooling solutions who has kindly offered sponsorship for this build. Drop on by to www.specialtech.co.uk and check out thier range
And to Lamptron, www.lamptron.com, for your modding needs!
Link to my youtube channel where i will be posting up video work logs
http://www.youtube.com/watch?v=LpKJN49Q3_c
Firstly i give you the basic framework
Now where the grilled/meshed areas will be
rough design of the front panel. This is going to be hidden behind a flip down peice of mesh to conceal it all maintaining the clean simple look
the power supply mounts
worse than chinese instructions. actually this was to help me work out how much metal i need. the numbers like 609 are mm lengths.
Finally i present to you, a rough, basic image of what the Pillar will look like when completed
Currently owned hardware:
MSI X58 PRO-E motherboard
Intel i7 920 2.66ghz cpu
3gb DDR3 1333mhz ram tri channel
GTX460 1gb OC edition gpu
Corsair TX850watt psu
magicool 360 slim radiator
GTX 240 radiator
EK 800l/p pump
EK basics res
8/10mm tubing + compression fittings
koolance GPU 220 gpu block
XSPC RASA cpu waterblock
5 x scythe gentle typhoon 1850rpm fans
secretreeve is offline   Reply With Quote
Old 1st Dec 2011, 15:10   #2
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
I think that sums up my feelings for now alone!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is online now   Reply With Quote
Old 1st Dec 2011, 15:37   #3
Silent_Raider
Multimodder
Silent_Raider's Avatar
Silent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run Crysis
Nice! I hope you have a good room for this beast, because once you build that thing, you will not be moving it lol.
__________________
Intel Core i7-2600k @ 4.4GHz | Corsair H100 | ASUS Sabertooth Z77 | G.SKILL Ripjaws X Series 16GB (4 x 4GB) DDR3 1866 | 2x Crucial C300 256GB SSD| 2x MSI GTX 680 Twin Frozr III 4GB | Rosewill BLACKHAWK-ULTRA | Kingwin Lazer 1000W | LG 10x Blu-Ray Burner | Creative Sound Blaster Recon3D THX | Logitech G500 | Razer BlackWidow Ultimate (Dragon Age III Edition) | 3 x Dell UltraSharp U2412M 24" 3600x1920 | Logitech Z-5300e 5.1 | Win 7 x64 Ultimate
Silent_Raider is offline   Reply With Quote
Old 1st Dec 2011, 15:42   #4
Throbbi
I Mod, Therefore I Own
Throbbi's Avatar
Throbbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpit
What the hell are you building, a house?!
Bonkers, ridiculous, over the top..............love it already
P.S. You may want some work in progress pics before a mod moves it over to the Modding section
__________________
Steam - Throbbi ::WoT -Unpainted_Target ::BF3 - Throbbi
Phenom IIX4 B60 (core unlockedX2 560 @ 3.9ghz) - 2x4GB 1333DDR3 - 1.8TB Storage - XFX GTX260 kindly loaned by Lancer778544! rep him! Relix commands you! (he does, honest, told me yesterday)
::The rig made possible ONLY by this great community!
Share And Enjoy!
Throbbi is offline   Reply With Quote
Old 1st Dec 2011, 16:30   #5
secretreeve
thanks for the comments guys lol.
there will be some work in progress pics coming along in the next week or two i hope. currently still working on the design side lol
Old 1st Dec 2011, 16:37   #6
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
So what the hell are you going to do with that many rads?
bulldogjeff is offline   Reply With Quote
Old 1st Dec 2011, 22:08   #7
secretreeve
i wont be fitting it fully out with radiators, but it is good to just have that option.
i mean you could have 2 evga sr 2 maxed out with the best of the best gpu's water cool the lot and never worry about the heat generated because of radiator options.
as for a large enough room. this wasnt meant to be built till late next year but decided to step it up.
its primarily being built just to go "i told you it could be done and i did it" self accomplishement reasons i guess.
Old 2nd Dec 2011, 09:20   #8
shah
Hypermodder
shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.shah is a hoopy frood who really knows where their towel is.
Wow!!! One can literly stand inside the case. Good luck mate
__________________
Sugo SG08| Zotac H67 ITX| Ivy Bridge i5 3450 | Corsair H50 | 4GB Corsair Dominator - 1600MHz | HD5770 | Samsung SSD 128GB | WD RED 3TB
shah is offline   Reply With Quote
Old 2nd Dec 2011, 09:24   #9
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run Crysis
A monolithic case .... count me as a daily lurker
GuilleAcoustic is offline   Reply With Quote
Old 2nd Dec 2011, 15:36   #10
secretreeve
ordering some metal in on the 9th of december. next friday, so i can begin work on this gigant case
Old 3rd Dec 2011, 21:11   #11
secretreeve
Hacksaw Blades Cobalt 2pk 24tpi Each £3.80 x1
Woodworking PLASTIC 300MM MITRE BOX Each £5.55 x2
Aluminium Flat Bar 3/4" x 18" 2000mm £7.39 x1
10PCE TAP & DIE SET Each £8.41 x1
150MM ENGINEERS SQUARE Each £5.12 x1
Aluminium Angle 3/4" x 3/4" x 1/16" 4000mm £9.97 x1
Aluminium Box / Square Tube 3/4" x 3/4" x 16swg 4000mm £12.01 x2
Heavy Duty Hacksaw Each £5.59 x1
Aluminium Channel 3/4" x 3/4" x 1/8" 4000mm £16.83 x1
80 M6 button cap hex bolts
that's fridays order, so on the 12 (hopefully) this "little" lot will arrive and work can begin.
good news too, i found my old camera (like 2mp digital) from back in the day so can get some mediocre images and my old VGA digital camcorder for work log videos on my youtube channel rofl
Old 6th Dec 2011, 15:45   #12
JamieElston
Minimodder
JamieElston has yet to learn the way of the Dremel
Christ ! that looks bigger than most the racks in my datacentre at work !!
JamieElston is offline   Reply With Quote
Old 6th Dec 2011, 19:51   #13
secretreeve
good isnt it? haha
Old 22nd Dec 2011, 09:06   #14
secretreeve
progress pictures added
Old 23rd Dec 2011, 16:53   #15
secretreeve
another update added to main post. also, why do my posts all have to be approved?
Old 23rd Dec 2011, 18:18   #16
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
They have it set up that way, until you have enough posts you can't post with out it being approved. Cuts down on spam, etc
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is online now   Reply With Quote
Old 23rd Dec 2011, 18:34   #17
Nexxo
There is no rep for awesomeness.
Moderator
Nexxo's Avatar
Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.
OMG IT'S HUUUGE!!! KILL IT!!! KILL IT WITH FIRE BEFORE IT EATS US ALL!!!
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust
Nexxo is offline   Reply With Quote
Old 23rd Dec 2011, 20:44   #18
secretreeve
"i think he likes it"
Old 23rd Dec 2011, 22:24   #19
Achron
Cad Pro Quo
Achron's Avatar
Achron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the Dremel
I think "The ULTIMATE computer case " is quite the saying to live up to.
__________________
Completed: Acronym
Achron is offline   Reply With Quote
Old 24th Dec 2011, 03:42   #20
secretreeve
the ultimate computer case is also a matter of oppinion really, no single case can really be the ultimate one because some people want big, some want small, some want air cooling, some want water.
personally, for me, the bigger the better, and this is as big as i can make one lol
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
