Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 5th Dec 2011, 04:50   #1
cillerbee
Minimodder
cillerbee has yet to learn the way of the Dremel
Upgrade to 2700K or New Monitor & w/ for Ivy Bridge
I was debating whether I should upgrade to the i7 2600k/2700K or get the Samsung S27A950d monitor and wait for Ivy Bridge to upgrade.
I am getting mixed opinions regarding whether Ivy bridge is worth the wait or not so I was looking for some input from you all. Thanks
My current rig:
Processor:Intel Core i7 920 @ 4.0GHz
Memory: G.Skill Ripjaw 12GB 1600MHz
MB: ASUS P6T Deluxe V2
VGA: 2x Sapphire HD6950 @ 6970 Shaders in Crossfire
Monitor: Samsung S27A350
PSU: 750W Enermax NAXN 82+
Case: CoolerMaster HAF X
SSD: Corsair F90 90GB , 2 x OCZ Vertex 30GB
HDD: WD 640 GB x 3
cillerbee is offline   Reply With Quote
Old 5th Dec 2011, 06:33   #2
LennyRhys
Silenced
LennyRhys's Avatar
LennyRhys - may the hammer of Bindi be bestowed on youLennyRhys - may the hammer of Bindi be bestowed on youLennyRhys - may the hammer of Bindi be bestowed on youLennyRhys - may the hammer of Bindi be bestowed on youLennyRhys - may the hammer of Bindi be bestowed on youLennyRhys - may the hammer of Bindi be bestowed on youLennyRhys - may the hammer of Bindi be bestowed on youLennyRhys - may the hammer of Bindi be bestowed on youLennyRhys - may the hammer of Bindi be bestowed on youLennyRhys - may the hammer of Bindi be bestowed on youLennyRhys - may the hammer of Bindi be bestowed on you
Depends what your budget is. If you're prepared to spend £500 on a monitor then you should consider getting the Dell U2711 instead of that Samsung - take advantage of the PC's ability to output very high resolutions. It's not a console, so there are more display options than gimmicky 1080p!!!
I nearly upgraded to 2600K recently but I'm glad I didn't... I have instead bought a hexcore CPU to play with for a couple of weeks. My intention is to sell it when finished (I already did it this summer with the i7 970) however if it's a good un I might be very tempted to keep it... the X58 platform is still extremely capable and I'm certainly in no rush to move away from it quite yet!
LennyRhys is offline   Reply With Quote
Old 5th Dec 2011, 06:56   #3
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.
I agree. Keep the 920 setup for now, and wait for IB-E. Pete J did this and said it felt more like a side-grade than a upgrade.
I've been thinking about upgrading to the 3960X but, after some tests, it was only 5-10% faster clock for clock with my 990X. Also allot less when gaming.
As for the monitor, I would go for a Dell U2711 if you are wanting to spend that amount.
true_gamer is online now   Reply With Quote
Old 5th Dec 2011, 06:57   #4
flame696
Terminating People Since 1980....
flame696's Avatar
flame696 is the Cheesecake. Relix smiles down upon them.flame696 is the Cheesecake. Relix smiles down upon them.flame696 is the Cheesecake. Relix smiles down upon them.flame696 is the Cheesecake. Relix smiles down upon them.flame696 is the Cheesecake. Relix smiles down upon them.flame696 is the Cheesecake. Relix smiles down upon them.flame696 is the Cheesecake. Relix smiles down upon them.flame696 is the Cheesecake. Relix smiles down upon them.flame696 is the Cheesecake. Relix smiles down upon them.flame696 is the Cheesecake. Relix smiles down upon them.flame696 is the Cheesecake. Relix smiles down upon them.
I agree with LennyRhys I think your best off get a monitor like the 27" Dell and making use of the the 2 x 6950s. The 920 is still a great CPU that still holds it own and to be honest in real world applications you won't see much difference, but with a monitor you will get so much more real estate which comes in handy
Edit: Damn you Simon, ninj'd
__________________
Main: i5 4670k/ Asus Maximus VI HERO / 8Gb Corsair Vengeance 2133mhz RAM (Red) / 120Gb Kingston V+200 SSD / Asus HD7970 / Corsair AX850 / CM Storm Trooper / Mionix Zibal 60 /
HTPC: HP ProLiant G7 N54L microserver
The Project: Antec TwelvOrange
flame696 is online now   Reply With Quote
Old 5th Dec 2011, 06:57   #5
cillerbee
Minimodder
Where I live the S27A950D is going for about £430 including vat. and the Dell U2711 about £690 inc. Vat.
Where as the i7 2600k upgrade with an asus gen3 z68 mainboard will cost me £445 including vat. So im trying to stay within then £400 - £450 range. Sorry I should have mentioned that earlier.
Old 5th Dec 2011, 07:00   #6
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
If that is the case, I would recommend seeing these guys about a Dell U2711. Clicky Clicky
I highly recommend them.
Old 5th Dec 2011, 07:10   #7
LennyRhys
Silenced
LennyRhys's Avatar
Was gonna suggest them - Ninja'd by Simon
__________________
i7 930 @ 4.2 :: Gigabyte X58 USB3 :: 6GB Elpida @ 1528MHz 6-7-6-18-1T
GTX480 SE :: Toughpower 775w :: 320GB & 2TB :: NEC MDview 262
Old 5th Dec 2011, 07:40   #8
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
Sorry...You may need to improve your Ninja skills.
Old 5th Dec 2011, 10:32   #9
digitalerr0r
Multimodder
digitalerr0r has yet to learn the way of the Dremel
I say just keep waiting for ivy release and get the cpu and or there might be a better monitor during that time (:
digitalerr0r is offline   Reply With Quote
Old 5th Dec 2011, 14:51   #10
cillerbee
Minimodder
Alright thanks for all the input guys. I will wait for ivy bridge and attempt to get the monitor you all recommended. Problem is I live overseas and shipping + vat makes it a costly buy but I'll scour some local retailers.
Reply
Tags
2600k, i7, ivy, s27a950d, samsung
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
