#1 |
What the?
IP spoofing tool
My dad lives in Greece and is looking for a tool that will fool UK websites into thinking his IP address is UK based. He has talked about this before for gaining access to the BBC iplayer but it is a particular nuisance at this time of year when he wants to do his Christmas shopping online. He can browse sites such as Amazon UK but if he tries to buy anything it redirects him to the Greek Amazon store.
He has tried a couple of programs, one called Expat Shield and another called Tor but both have been spyware/adware and have caused numerous issues. Does anyone have any tool/packages they can recommend? Ease of use would be appreciated as he is in his 70's!
#2 |
How do I Internet!!
Have you tired seaching for open proxys in the UK.Before you take this suggestion allow other member to comment because i recall open proxy can be dangerous and track usage,info ie record data.Hopefully another member can clear that up.
__________________
CPU:Intel I7 930(Bloomfield) @2.80GHZ CPU Cooler:Corsair H80 MOBO:Asus P6t SE Graphics Card: Palit 670GTX 2GB OC RAM:12GB Corsair XMS3 1600mhz 9-9-9-24 PSU:Corsair HX 750W Hard Drives:50GB SSD OCZ Sandforce driver/1TB WD Green 7200RPM Case:NZXT 810 Switch Black |
#3 |
Infrastructure Specialist
The Tor network should be clean but can route you out of anywhere in the world.
A UK proxy would be a good bet. Or get a VPN to a UK provider. Both would be better than trying to spoof an IP
__________________
If what I've said helps you please remember to hit the rep button on the left Missing the old meeting place? Find us here |
#4 |
What the?
I was thinking the latter would be a better idea. Greece being the 3rd world country of Europe the only internet access he can get is through a 3G dongle and his download limit is 1Gb a month. The VPN services are all priced for much higher usage. Again any recommendations on providers are appreciated
#5 |
Ultramodder
If he just needs temp access you could give him remote access to a PC you have here :P
Find everything he wants on his connection, save links and visit through the remote access to buy. |
#6 |
будет глотать вашу душу.
The safest thing would be to set up a remote connection to your computer for him if any purchasing is going to be done. Proxy are good for general use, but since you have no way of knowing who is operating them, or what data they may collect it can be quite risky.
Look at Hamachi, it is pretty easy to use and does not require much beyond installing it and entering a couple pieces of information to allow them access to your pc.
__________________
[end of line]
intel i5-750 | evga p55 sli | 8gb mushkin blackline | evga gtx670 | 240gb mushkin chronos dx | creative titanium hd | mushkin 580w | gh60 custom | logitech mx revolution | achieva shimian qh270 |
#7 |
Ultramodder(Not)
Have you tried HotSpotShield? I used to use it to watch TV Shows on Hulu and it worked a charm. The only downside is that it somehow attaches advertisements to certain websites. It can be turned on/off when desired, which is a good thing.
Just google Hotspot shield and you will find it.
__________________
|| Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: Gigabyte GTX 580 Super OC || Memory: Mushkin Blackline 8GB || SSD: Corsair Force 3 120GB || HDD: WD Caviar Black 2TB || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v || Keyboard: Logitech G510 || Mouse: Razer DeathAdder |
#8 |
J
Tunnel through SSH on your machine or a server is the best i can come up with.
http://travisaltman.com/tunneling-http-thru-ssh/ Isn't iPlayer gonna use up all his bandwidth though?
__________________
i7 950 @ 3.8 1.192v|Noctua NH-U12P SE2|Asus P6X58D-E|12 GB DDR3 1600|1TB Samsung Spinpoint F3|Samsung 830 64GB|XFX Double D R7950|Asus Xonar DG|Antec Quattro 850w|Bitfenix Colossus|Dell U2311H|Dell E173FP
Steam|PSN:nythraln |
#9 | |
How do I Internet!!
Streaming Video from bbc player will nom nom that bandwidth no problem.Would be ok for the purchasing aspect tho +1 TaRkA DaHl for the logmein approach.
__________________
#10 |
What the?
That is for him to worry about. He has a program which shows him how much data he has left so i think one program on iplayer will give him enough of a scare to stop!
Thanks for all the suggestions. I will try and see if I can set up my FreeNAS box as a proxy. [edit] I take it an Atom based PC would work for this? I have an Atom HTPC that would be perfect for this.[/edit] Last edited by Da_Rude_Baboon; 7th Dec 2011 at 09:03. |
#11 |
Gimp dog!
The problem with setting up a proxy on your own connection is that the speed your dad can transfer data will be limited to your upstream speed not your downstream speed.
Other than that slight caveat, an Atom box should be more than enough grunt to act as a proxy - it's not really doing that much, just basic NAT.
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse |
#12 |
What the?
Good point. It likely to bugger my pings when gaming too. I will give it a go and if he is happy I will educate him to only use it when he needs it and not route all his internet traffic through me.
#13 | |
Banned
One alternative to consider is JAP - without payment you're restricted to a proxy in Dresden, Germany but if you pay for the commercial Jondo service, you have a choice of servers including one in the UK. |
| Thread Tools | |
