Graphics Crosssfire upgrade - no real fps benefit?!
Discussion in 'Hardware' started by AlexB, 8 Dec 2011.
  1. AlexB
    AlexB Web Nerd
    22 Dec 2005
    Hey chaps
    I just added a 2nd 6970 to my PC, and put them in crossfire, I updated my AMD drivers, and CrossfireX was now enabled in the catalyst settings, but when playing games, I get almost no benefit. I've gone from 60-62 to 70 in iracing, but nothing at all in a few other racing games I play.
    So, what have I cocked up, or is this just a 'meh' moment?
  2. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    That's the story of using more than one GPU - sometimes it scales, and sometimes it doesn't... and ATI have never really excelled in the multi-GPU scaling department.
    With GTX460 SLI I get 100% scaling in some games (Crysis being one) and also in some benchmarks, but some games make absolutely no use of the 2nd GPU at all.
  3. AlexB
    AlexB Web Nerd
    22 Dec 2005
    poop.
  4. Parge
    16 Jul 2010
    Yeah, unless the game is written to take advantage of X-Fire, and ATI have enabled the game in their drives you won't see any benefit.
    Some games (say BF3), will scale to almost 100% though.
  5. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Have you ticked the Catalyst AI function? If you dont select that you will see no benefit at all.
    I have mine on advanced setting, as it forces the cards to render alternate frames, and while my max fps barely changes from the standard setting, my minimum fps are much higher.
  6. AlexB
    AlexB Web Nerd
    22 Dec 2005
    The 'enable' crossfirex checkbox? That's checked. I'll look for the advanced option you're on about later :)
  7. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    I doubt there are many racing games that take advantage of even one 6970. You may find you are limited by the number of CPU cores the game can use.
  8. AlexB
    AlexB Web Nerd
    22 Dec 2005
    I can't find that setting, Fizzban, where is it?
  9. BrightCandle
    BrightCandle What's a Dremel?
    30 Apr 2009
    Get RadeonPro and tweak the profile yourself. Try Alternative Frame Rendering (AFR) as your first step as that often works but don't be afraid to try games that are similar in nature (F1, grid) and all the different modes of crossfire. Maybe one of those will work (it often does) and give you better scaling.
    Its also worth noting that in other games you need to watch for negative scaling. Sometimes (its happened at least 4 times through the autumn game releases) you will see games perform very poorly with the default crossfire setup. Turning it off (RadeonPro again) will dramatically improve performance until a profile comes out.
    Welcome to the world of crossfire, remember to jump on every new profile and driver release you are now going to need them.
  10. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Right now AMD GPU's scale better than Nvidias by a good margin, they are well ahead in that department.
    Though it is true that not all games will show improvements.
  11. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    Have you installed the Catalyst Application Profiles (CAP)? You need these for crossfire. +1 for RadeonPro also. great tool.
  12. Fizzban
    10 Mar 2010
    Catalyst Control Centre - Gaming -3D Application Settings, below Anisotropic Filtering. Make sure it is un-ticked ie. enabled. :)
  13. DarrenH
    DarrenH What's a Dremel?
    12 May 2010
    I added a second saphire 5770 for crossfire because I had read good reviews about ATI/AMD cards and the 5770 in crossfire. I am glad I did. It works a dream. I simply un-installed the ccc/video drivers completey and then re-installed and it worked straight away with crossfire enabled.
    Not all software/games will be crossfire or SLI compatible, but in the ones that are I have found 90%+ improvements. I get the crossfire logo appearing at the top, right-hand corner of my screen whenever it is used (you can turn that off in CCC). I also run afterburner with the GPU usage and temps for both cards displayed at the top, left-hand corner.
    It works a treat. Much better than I anticipated in both XP and Win 7 64-bit.
    *TIP: Try removing your original 6970 and use just the new one for an hour to make sure the second card you bought is working fine!
  14. heir flick
    heir flick Minimodder
    2 Feb 2007
    Run msi afterburner and see what gpu usage your getting ingame
  15. AlexB
    AlexB Web Nerd
    22 Dec 2005
    Just run afterburner - 99% on gpu1, 80% on gpu2.
    Eta - after playing for a bit longer, upto 99% on gpu1 and 98% on gpu2.
    still not seeing any improvements in framerates, except perhaps actually _less_ in a few older titles.
  16. AlexB
    AlexB Web Nerd
    22 Dec 2005
    Removed the 2nd card, framerates are higher now. :(
  17. BlackDrag0n
    BlackDrag0n What's a Dremel?
    3 Nov 2011
    Are you sure you installed the card in the right PCI-E slot for dual x8 and not x16 and x4?
  18. DarrenH
    12 May 2010
    As I said,
    "*TIP: Try removing your original 6970 and use just the new one for an hour to make sure the second card you bought is working fine!"
  19. AlexB
    AlexB Web Nerd
    22 Dec 2005
    Will try that tonight.
    Ta
  20. AlexB
    AlexB Web Nerd
    22 Dec 2005
