Reply
Thread Tools View Mode
Old 10th Dec 2011, 17:59   #1
ASPHIAX
Beyond Complexity Lies Simplicity
ASPHIAX's Avatar
ASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the Dremel
2001 - A Case Modyssey - New plans = New Render Video!
I can still remember the first time I saw the movie when I was 11 years old.
It was on an old black and white antenna tv, the sound turned almost off so my parents wouldnt hear it as I wasnt supposed to be up that late, but it didnt matter... I was there, I was at Clavius Moonbase, I pulled HAL's memory modules, I was the monkey that cracked the skull of the rival leader. This is the movie that got me hooked on SCIFI . Stanley Kubricks's EPIC interpretation of the vastness of space, The sense of reality with which the film is shot, the 2 minute blackscreen intro, the special effects, the far reaching concepts, and good god ... the books by Sir Arthur C Clark were even better!
Anyway, after the build of the USS EURISKO - Intrepid Mark II Class (It only needs a good paintjob) I got in contact with the Dutch Modder Nixjuh. We started talking about our passion for SCIFI on the SCIFI OCD group and he showed me some of his work. His artistic skills are off the charts and we soon started brainstorming on how we could use his drawing and sculpting skills on a tribute pc to one of our favorite movies.
Here's what came out of those sessions :
3D model of the inside of the case
The shape of the Case resembles the Monolith TWA-1 from the movie. We could not keep the 1².2².3² dimensions without making the case huge or to thin for any hardware, so we ended up with a design that was 80cm high, 43 cm wide and 18 cm deep. In real life the monolith shape does come out a bit better then in this 3d render.
So what's inside: (some of these are not confirmed yet)
BlackIce GT Extreme 560 Radiator
6 x 140 mm fan (4 for the 560 rad and 2 for intake)
Motherboard AMD
watercooled AMD 1090T processor
2 x watercooled 580GTX in SLI mode
2 x SSD
Custom reservoir with picture of Arthur C Clark
Bitspower fittings
Aircooled RAM
1200 Watt PSU
The inside of the case has been designed to resemble the inside of the HAL9000 computer. The scene where Dave Bowman disconnects HAL's memory modules and makes him sing a song as a means of a factory default is nothing short of brilliant.!
The frame will be made of Pine and MDF. We would have liked to use ALU but we dont have any means of working the metal. The visible inside of the case will be designed around a full cover plexiglass sheet covering most of the hardware (creating a closed well ventilated room) with numerous frosted red/white illuminated plexi memory modules and black/red shades to finish it off. The 580GTX 's will be covered by a plexi encasing resembling the HAL9000 interface.
The outside is where Nixjuh will show his considerable talent! Special engravings of 10 of the most impressive scenes from the movie will cover the clean and featureless black metal hood that will be placed over the internal frame. We have something special in mind for the on/off and reset buttons and side window but we cant tell too much about that yet. We can tell you that the casing will be put onto a rocky platform with several USB ports integrated into it and that "the dawn of man" is its main design criteria. We cant tell you how much fun we already have had designing and preparing for the build and hope that you'll be as eager as we are to find out how the concept will evolve and grow.
Here's an update on the work done so far !
ASPHIAX en NIXJUH
__________________
Current Build : BORG COSMOS II
Current build : 2001 - A Case Modyssey
Finished build : IMPERIAL AT-AT
Finished Build : USS EURISKO - Intrepid Mark II Class
www.asphiax.wordpress.com
ASPHIAX is offline   Reply With Quote
Old 10th Dec 2011, 17:59   #2
ASPHIAX
ASPHIAX's Avatar
Current state :
__________________
Old 10th Dec 2011, 18:05   #3
ASPHIAX
ASPHIAX's Avatar
Ok so here goes !
First, we have changed the buidling material from MDF and PINE to Aluminium. And boy did that make a difference. I build a large part of the frame but the feeling it was to light creeped up on us and after doing some homework we decided to go for alu. This did ment having to invest in some tools but I AM SO HAPPY we did. What a material, I know I will probably never go back to MDF again (except when there's a good reason)
Anyway , here is the MDF / PINE frame
The 3D design did come in handy now, easily got all the measurments from the design and was sent to the ALU vendor.
So what have we got? 12x12 mm square rod ..
And 2mm ALU panel ..
First sized up one of the major defining elements, the massive BlackIce GT 560 Extreme !
It should fit with a couple of mm left after the rods have been placed, we will see !
I already have most of the hardware so a quick test fitting to see how she goes ..
Only had green and 120mm enermax fans , they will be exchanged for 140mm red's !
One of the toughest things (IMO) to do if finding the right locations for the fan holes and screws ..
Couple of hours later, and a whole lot of sanding and filing ...
Couple of hours later, man that aluminium works great !
And the final state for tonight, got a good day tomorrow also ! Will be traveling to Nixjuh (30KM) and work on the frame from there. He has got something very (VERY) cool to show !
And the monolith is born, Imagine all black alu and red enermax behind the rad ... Could look cool I think !
Laters !
__________________
Old 10th Dec 2011, 18:10   #4
P3rRRrY
Minimodder
P3rRRrY has yet to learn the way of the Dremel
Great start. Subscribed!
__________________
Asus Rampage IV LGA2011
Intel Core i7 3960X LGA2011
Corsair Vengeance DDR3 1866MHz 32GB CL9
RevoDrive 3 X2 MAX IOSP 480GB
SilverStone TJ11
P3rRRrY is offline   Reply With Quote
Old 10th Dec 2011, 18:17   #5
Sheiken
Wat?
Sheiken's Avatar
Sheiken has yet to learn the way of the DremelSheiken has yet to learn the way of the DremelSheiken has yet to learn the way of the Dremel
I LOVE THIS! Following along!
Best name for a mod, ever.
__________________
Whoring Out My Hardware 3.2!
Portaputer - Clevo W540EU - 14" / i5 / 8GB / 256gb ssd
H@ck Pro Gigabyte Z77-DS3H / i5 2400/ 8GB DDR3 / vMod Gigabyte GTX 660 OC @ 1200mhz boost / Corsair Carbide 300r / 250GB / 1000GB
Sheiken is offline   Reply With Quote
Old 10th Dec 2011, 18:24   #6
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
This looks very interesting and if it comes out like the renders, it's going to be epic.
bulldogjeff is offline   Reply With Quote
Old 10th Dec 2011, 18:28   #7
ASPHIAX
ASPHIAX's Avatar
Thanks ! We will be updating regularly !
Ha, thanks man ! We thought it would add a funny twist to it !
__________________
Old 10th Dec 2011, 18:55   #8
OmightyOne
Multimodder
OmightyOne's Avatar
OmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the Dremel
Great! looking good, cant wait to see what it will end up as!
__________________
The Tank - Intel i7 920 @ 4ghz - Nvidia 560ti F/OC (Main) Nvidia gtx 460 F/OC (Physx) - 6gb 1866mhz ocz Reaper Ram - F3 1TB - Coolermaster 850w slient pro - CM HAF case - Custom water loop!
OmightyOne is online now   Reply With Quote
Old 10th Dec 2011, 19:06   #9
ASPHIAX
ASPHIAX's Avatar
Thanks, first time for me with ALU so a bit of a learning curve but its going along ok.
We havent decided to cover all the hardware by a plexi plate or keep the hardware visible like this :
Thanks! Stay tuned and find out !
__________________
Old 10th Dec 2011, 19:13   #10
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
Nice start! I'll follow this
__________________
Current projects: Tydirium is on the way!
Previous mods: |Sandcrawler Mod| |Illuminated Mind| |Graphite5|
Follow me on Facebook
nagyizom is offline   Reply With Quote
Old 10th Dec 2011, 19:52   #11
ASPHIAX
ASPHIAX's Avatar
Thanks bro! Cant wait for your "planned" build, lol!
__________________
Old 10th Dec 2011, 20:10   #12
slipperyskip
Seemingly Disinterested
slipperyskip's Avatar
slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.
You had me at "Custom reservoir with picture of Arthur C Clark". Gotta see that.
slipperyskip is offline   Reply With Quote
Old 10th Dec 2011, 20:15   #13
ASPHIAX
ASPHIAX's Avatar
Yeah, we might change that to "picture of Arthur C Clark and Stanley Kubrick" as they are both the fathers of this movies, it wouldnt be the same if you take out either one.
Just gotta find a good one of both of them together, that would be sweet !
Thanks !
ps Actually this one might do. Its even on the set of 2001
__________________
Old 10th Dec 2011, 22:32   #14
jamsand
Hypermodder
jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!
sub'd also thought that was going to be a MASSIVE hot swap SSD RAID there lol
jamsand is offline   Reply With Quote
Old 11th Dec 2011, 11:58   #15
ASPHIAX
ASPHIAX's Avatar
Thanks! All the white plexi would be SSD's? SWEET !! Cost a bundle though!
__________________
Old 11th Dec 2011, 12:39   #16
adidan
CPC_refugee
adidan's Avatar
adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.
+Rep for the title Sander, let alone the great work as always mate.
__________________
Don't do today what you can put off until tomorrow
Battlefield 3 adidan_uk BF3 Stats
i7 3770 3.4GHz // Asus P8Z77-M // Scythe Big Shuriken // Gainward 570 Phantom // 8Gb G.Skill Ripjaws 1600MHz //
250Gb Samsung 840 // 650W Be Quiet Dark Power Pro // Lian Li V351b Apache Filled // Samsung T220 22" // W7 64
adidan is offline   Reply With Quote
Old 11th Dec 2011, 13:18   #17
Nixjuh
What's a Dremel?
Nixjuh has yet to learn the way of the Dremel
Hi everybody,
First of all I will introduce myself a little and tell you my place in this build. I ran into Asphiax when I came looking for the EURISKO. Then we started talking about our passion for SCI-FI and came up with the idea for this build. The first weeks we only did a lot of brainstorming to come up with a good and unique concept. As you saw in the start post above, Asphiax made some awesome 3D renders and started building the case. Yesterday I saw it for the first time and it really shows some craftsmanship and quality! This case will be about the fun of building and learning new skills.
And this is where I come in, I will be doing most of the artwork on the outside of the case. There will be 10 engravings on the outside of the case, which will all resemble a scene from the movie. Also there will be some real 3D features on the outside, but that’s something for later (hence the censored on the photo) But remember, this is just a mock-up for the placing and the content of the engravings, the final engravings will not feature shadow or colors or anything ofcourse.
We want to give our special thanks to Simon Atkinson, who let us use some of his artwork for the engravings, he does some amazing artwork, model making and drawing! Be sure to check out his website
Today we will show you our plans for the engravings so here we go!
This is a 3D render of the case including the outside casing.
The front will show a picture of the apes touching the monolith, and the astronaut inside a tunnel.
On the top we will have an engraving of the Discovery 1.
And in the back it will feature the rising moon and the astronaut inside the centrifuge in Discovery 1.
Now for the two largest panels.
The one on the back of the motherboard plate will be fully covered and show a picture of earth, the star-child looking down to earth and station V shooting out the Orion spacecraft
And the last but most certainly not least side will have a plexiglass window in the shapes of some tears in the metal. This has to do with our own chimera, in which the ape finally manages to damage the monolith. Hence the theme “The rise and fall of men”. It will also feature an engraving of the EVA .
And an overall layout of all the engravings to give you a better understanding.
And the final feature will stay a mystery for now, but we will keep you posted!
Nixjuh is offline   Reply With Quote
Old 11th Dec 2011, 14:57   #18
Nixjuh
What's a Dremel?
This week we will buy all the equipment we need for the engravings and start with some test pieces, then lay out all the designs and start the real work!
Old 11th Dec 2011, 15:05   #19
ASPHIAX
ASPHIAX's Avatar
Thanks man ! We thought it would be appropriate ! LOL
__________________
Old 11th Dec 2011, 15:15   #20
Throbbi
I Mod, Therefore I Own
Throbbi's Avatar
Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.
Wow! This is awesome! I can only hope that once it's complete Windows startup/shutdown/error sounds are changed to HAL's voice, 'I'm afraid I can't do that Dave' is probably already used as the error message on thousands of PC's but this one needs it.
__________________
Steam - Throbbi ::WoT -Unpainted_Target ::BF3 - Throbbi
AMD FX-6300-Gigabyte 990AX-UD3-MSi GTX660-Momentus XT-be quiet! E7-600W-Avexir 2x4GB 1600
Share And Enjoy!
Worklog - The Amputer!
Throbbi is offline   Reply With Quote
Reply
Tags
2001, aluminium, scifi
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
