#141 | |
The modding head is firmly back on.
#142 | |
No disassemble!
Unless it's the triple channel memory that's helping. I may pull a stick and run it again.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60 |
#143 |
Co-Mumble Ruler!!
Well several restarts later and one BSOD I have decided to not overclock my system again for awhile. Might need to double check the settings I have in place for the OC. I used a video guide I found for i5 2500k to overclock to 4.5. I got it to run a 5Ghz sometime ago but it wont do it now. My system hanged or I thought it did and then after restart I got a BSOD. Now back to normal.
__________________
i5 2500k @ 4.5ghz | P8P67 | 8gb Corsair Vengeance 1866mhz | EVGA GTX670 SC | LGIPS231 | K/B Filco Majestouch 2 | Mouse R.A.T 3 | Phones Sennheiser HD 598
#144 |
Resident Bulldozer Guru
Four overheats and a blue screen later.
http://browse.geekbench.ca/geekbench2/531518 4.825Ghz. 5Ghz required too much voltage, it got too hot. I was pushing 59.5 degrees as is. (250x 19.5 1.575V) At least this board is intelligent when it Overheats. Spins all the fans to full and kills power to everything else. I'm half amazed the motherboard speaker doesn't yell out "COOL THE F#CK DOWN!" during this.
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Xonar DX/XD | 2X SLI KFA2 550Ti White Edition | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | OCZ Agility 3 60GB | 1.5TB in Drives | Lite-on Blu-ray ROM Dell 1908 | Sennheiser HD 485s | Creative Gigaworks T40s | Logitech G13 | Microsoft Sidewinder X6 | Cyborg R.A.T 9 Last edited by .//TuNdRa; 19th Dec 2011 at 14:04. |
#145 | ||
Was that a warranty I just broke?
![]() CPU (i7-2700K) @ 5 GHz RAM (8 GB DDR3) @ 2133 MHz 32-bit score 15335 http://browse.geekbench.ca/geekbench2/531512 64-bit score 21434 http://browse.geekbench.ca/geekbench2/531514 And a screenie to show cpu-z display when running the 64-bit test:
#146 |
Holy crap. I'll never catch anyone who registers!
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Xonar DX/XD | 2X SLI KFA2 550Ti White Edition | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | OCZ Agility 3 60GB | 1.5TB in Drives | Lite-on Blu-ray ROM Dell 1908 | Sennheiser HD 485s | Creative Gigaworks T40s | Logitech G13 | Microsoft Sidewinder X6 | Cyborg R.A.T 9 |
#147 | |
#148 |
If you register; I will kill you. Or just force you to run the 32bit only benchmarks when comparing with my FX8120. I don't have £8 spare to throw at Geekbench.
__________________
#149 |
For what it's worth i wouldn't bother, better to find a bench mark that runs 64 bit as standard.
#150 |
True. After having just overheated my processor four times within ten minutes, however, i'm not going to be benchmarking for a while.
Thermal Cut out on the FX series is 75 - 80 degrees, BTW. They heat up incredibly fast, my Archon wasn't even warm when it overheated.
__________________
#151 | |
You will see from the two sets of results, the improvements are: Processor Integer Performance: +18% Processor floating point performance: +70% Memory performance: +18% Memory bandwidth performance: +4% __________ Overall performance gain: +40% So, the memory performance scales at a similar rate to the processsor integer performance, which is nothing to do with how much memory is visible. It relates to the excution of the instructions (and how well the memory performs when running those instructions). The minimal increase in memory bandwidth performance is not enough to say that having all memory available to tests provides a boost in itself.. The biggest difference is in the floating point tests, which is much as I would expect. |
#152 |
In wasn't going to get that technical, I just meant the overall score.
#153 |
It's big, and it's clever.
Could always use PCMark 07. That's 64bit. I'm not registering Geekbench.. no point unless everyone does.
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ 4GB EVGA GTX670 Superclocked SLI ¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦ Logitech Z623 EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS8704EM2 ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered MOON | Thecus N3200pro 3TB RAID5
#154 |
Technophile(and yes, thats 724Mb/s)
Hmmm so if I bought it it'll probably give me the edge to beat .//TuNdRa...
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Sapphire Radeon HD 5870, 128GB Crucial M4, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W. |
#155 |
Until he buys it too. It's an arms race!
__________________
#156 |
Then I'll have to buy it to take the AMD top slot back and so it goes on.
Like they say, an eye for an eye and in the end the whole world goes blind. But the way I see see it. In the land of the blind the one eyed man is king. Oh well nurse will be round with dinner and my medication soon.
#157 |
Forget PCMark7. It measures everything. Just been looking at results, and people with slower CPUs and memory and GPUs are scoring higher due to SSDs and faster broadband connections. It measures even web browsing speed, loading times, image transfer to disk rates... all sorts.
Too variable.
__________________
#158 | |
Cheesecake anyone?©
It's going to feel like xmas day tomorrow for me and a few others ![]() Is it not about time bit-tech created a newer benchmark, to keep us on our toes? |
#159 | |
__________________
#160 |
Cheesecake anyone?©
You would with those UNI speeds. I fine my 8mb connection fast, but yours is just incredible. You must be able to download your whole steam collection in 1hr lol.
| Tags |
| amd needs love too, e-peen measuring, sb-e owner's club, we no need steenkin linux |
| Thread Tools | |
