Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 15th Dec 2011, 12:30   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Corsair H80 Review
Corsair's H80 aims squarely at the gap between high-end air cooling and low-end water cooling.
http://www.bit-tech.net/hardware/coo...r-h80-review/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 15th Dec 2011, 12:38   #2
Ratchet219
Modder
Ratchet219's Avatar
Ratchet219 has yet to learn the way of the Dremel
Wow, finally some useful info from bit-tech! Well done guys. Keep up good work!
__________________
HP EliteBook 8560w
Ratchet219 is offline   Reply With Quote
Old 15th Dec 2011, 12:41   #3
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
If as quoted 'For Socket AM3+ and LGA1155 owners, Antec's Kühler H20 920 costs and performs the same and has the benefit of software fan control making it the better buy.' How do you justify the Corsair's score of 83% against Antec's score of 81%?
__________________
SchizoFrog is offline   Reply With Quote
Old 15th Dec 2011, 13:01   #4
improprietary
FT03 is a bitch to watercool
improprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremel
fyi this fits in a silverstone ft03 and can be run as intake fan with low ram blocks... barely
__________________
I'm spending a year dead for tax reasons. - Douglas Adams
Wanna help me and get cloud storage? Use Dropbox http://db.tt/msbUQQC
improprietary is offline   Reply With Quote
Old 15th Dec 2011, 13:12   #5
Zombie
Minimodder
Zombie has yet to learn the way of the Dremel
Because percentage points at the end of a review are an arbitrary idea that really have no comparative value. Summarising a 3 page review with one (or even 3) numbers makes little to no sense but us consumers demand it.
I'm sure the reviewers find that the most pointless part of the reviews and it only causes trouble with cross comparisons. After all, they're journalists not accountants.
__________________
Thomas Garrard
http://www.tgcreate.com
Zombie is offline   Reply With Quote
Old 15th Dec 2011, 13:19   #6
mikewd
What's a Dremel?
mikewd has yet to learn the way of the Dremel
So it beats an arbitrary single air cooler? Why not test it against the best air cooler? These cheap pre-built water coolers seem to do a very good job of covering up the fact that they are a very mediocre price/performance competitor against top range air coolers.
2nd point: These new intel ads are enough to make me start using other websites for reviews.
mikewd is offline   Reply With Quote
Old 15th Dec 2011, 13:20   #7
V3ctor
Tech addict...
V3ctor's Avatar
V3ctor has yet to learn the way of the Dremel
Honestly, I think that the WC is part of the past...
I had it when I had a Q6600(B3)@3.2Ghz and a HD4870 (that was toasty)...
SB's don't need that much of a cooling, and the new gpu's come with great coolers or are "fresh" by them selves.
Maybe Ivy's are the market for these coolers, but even then u have great air coolers that are cheaper than these and totally silent (I have a friend that complains his water pump is noisy with one of these new WC systems, Corsair and Kuhler)
__________________
Main: Intel Core i7 4770K@4.5Ghz / ASUS Sabertooth Z87 / 2x4Gb Gskill Trident X 2400Mhz / MSI GTX 750Ti 2Gb GDDR5 / Samsung T260 / 2x Corsair Force GT 240Gb raid0/ Corsair HX-850W/ Silverstone FT02R-Wi
Laptop: Intel Core i7 4790K 4-4.4Ghz / 8Gb DDR3 1600Mhz / nVidia GTX 980M 8Gb GDDR5 / Samsung SSD 256Gb XP941
Hobby: AMD Opteron 175 / ASUS A8N-SLi SE / 3Gb DDR400 / ATI HD4850 512Mb GDDR3 / Crucial M550 128Gb M2
V3ctor is offline   Reply With Quote
Old 15th Dec 2011, 13:50   #8
RobJapan
Minimodder
RobJapan has yet to learn the way of the Dremel
Adblock should be your new best friend.
RobJapan is offline   Reply With Quote
Old 15th Dec 2011, 13:53   #9
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
We've re-built all our test rigs since we tested the Kühler H20 920, as mentioned on the performance page - as such, the results and conclusions in the H80 review are more up to date and are based on different systems than those we used in the Kühler review which went live in July.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 15th Dec 2011, 14:26   #10
SchizoFrog
I *am* a Dremel
So the Antec would score higher now in the new systems? That seems odd. Still doesn't add up to your recommendation that the Antec is a better option than the Corsair.
__________________
Old 15th Dec 2011, 14:38   #11
Combatus
Moderator
Combatus's Avatar
We're using different tests on our systems so cooling scores and value scores are affected. In addition, the Antec's score is based upon a combined score for both the test systems we used at the time, while with the Corsair H80, we've extrapolated individual scores for each CPU socket, so you can't really compare the two.
__________________
Old 15th Dec 2011, 15:17   #12
jon
Multimodder
jon has yet to learn the way of the Dremel
+1
I fail to see the cost / performance value of WC setups on modern SB chips. Perhaps on AMD's, as I'm not up to date on their heat generation. But it's almost as if the SB design is so heat efficient that WC setups are no longer necessary (for the CPU). Still plenty of heat on high-end GPU's ...
-J
__________________
DargonZine: The longest running fantasy magazine on the net. Period.
jon is offline   Reply With Quote
Old 15th Dec 2011, 16:08   #13
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
Currently my H80 is sat in it's box not getting used because my air cooler perform's better.
It was good until I overclocked my old I7 920 or I7 950 which on either machine and overheated at 1.25v with 2 high cfm fans on it.
I honestly cannot recommend it to anyone and instead recommend either a good air cooler or a custom water loop.
I'll stick to my Akasa Venom Pro on my 2500K as it get's to 70c per core but with the H80 hit's 60c not worth the hassle and noise.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 15th Dec 2011, 17:21   #14
Omnituens
Hypermodder
Omnituens's Avatar
Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.
My old H50 is keeping my i7 920 stable @ 4.3GHz, not had any issue with it. Maybe because my 840 case has 2 mahoosive exhaust fans at the top.
__________________
Current Rig: i7 D0 4.2GHz, X58 Sabertooth, 12GB RAM, GTX 680, Xonar D2X
Omnituens is offline   Reply With Quote
Old 15th Dec 2011, 17:54   #15
Diellur
Minimodder
Diellur's Avatar
Diellur has yet to learn the way of the Dremel
When will we see a review of the H100 and a comparison of closed-loop water-coolers?
__________________
Gaming Rig: i5-2500K / P8P67-Pro / 1GB MSI GTX 560Ti TwinFrozr2 / 2x2GB Ripjaws X / XFX 750W Pro Core / Obsidian 700D
HTPC: G620 / P8H61-I / 2x2GB Corsair / Silverstone 500W Modular / 60GB Corsair Nova / HD 6450 Passive / Grandia GD06B
Mediaserver: E2140 / P35C-DS3R / 2x1GB / Be Quiet! 480W / 40GB Vertex 2 / 6TB / WHS v1 / PE-100N / PE-103R5 / eSATA dock
Diellur is offline   Reply With Quote
Old 15th Dec 2011, 18:02   #16
CrapBag
I Mod, Therefore I Own
CrapBag's Avatar
CrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming Saiyan
Would have been nice to see how much difference it made fitting it as an exhaust.
I'm considering buying this or the 920 and leaning towards the H80 being that the 920 seems like a noisy beast but I could only fit it as an exhaust in my case.
CrapBag is offline   Reply With Quote
Old 15th Dec 2011, 18:14   #17
OzThe2
What's a Dremel?
OzThe2 has yet to learn the way of the Dremel
Awesome - Adblock is now my best friend. Thanks for that tip. The site is so much cleaner now I could eat my dinner off it!
OzThe2 is offline   Reply With Quote
Old 15th Dec 2011, 18:28   #18
RedFlames
...is volatile under pressure.
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
If memory serves they tried the h60 both ways and while it did cool better as an intake the difference wasn't that great
__________________
You wouldn't really die of anything, in the traditional sense. You would just stop being biology and start being physics.
RedFlames is offline   Reply With Quote
Old 15th Dec 2011, 21:03   #19
Chicken76
Hypermodder
Chicken76's Avatar
Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!
Wow, nice one! Wasn't expecting H80 to be reviewed after all this time. Better later than never.
While the review was nice, some things could have been added to make it really outstanding, such as:
  • comparative pictures of previous generation Corsair H-series coolers (H50 & H70), current generation (H60 & H100), similar products from competitors (Antec). Would have been nice to see the width the the radiators on all of these in a single picture, the size of the pumps, length of the tubes, etc.
  • your impressions on the build quality (has it improved over the previous generation or the competition?)
  • noise should be treated more in depth. fans and pump.
Or are you guys preparing all of these aspects for a closed-loop-liquid-CPU-cooler roundup? That would be ... (as much as I hate using this word) awesome!
On another note, how did you guys get rid of two mounting brackets? (hope that's what they're called) The videos on the Corsair website show the H80 has four of them and angled at 45 degrees with the sides of the square pump. In your pictures, there can only be seen two of them and they are perpendicular to the sides.
Chicken76 is offline   Reply With Quote
Old 15th Dec 2011, 22:30   #20
ssj12
Hypermodder
ssj12 has yet to learn the way of the Dremel
So how well will this cool my i7 950 since there was no tests on the socket? I have a thermaltake frio currently.
ssj12 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
