Modding PC in a desk
Discussion in 'Modding' started by shaunster1011, 19 Dec 2011.
  1. shaunster1011
    shaunster1011 What's a Dremel?
    26 Sep 2011
    Hi all, I have nearly completed my PC desk mod now, its inspired by the other great desk mods I have seen on here but its made to my own style.
    I have to confess I did not build the actual 'shell' of the unit myself, I dont have the required skills for that!
    Anyway a little about the desk, its not made from metal, rather wood. In fact its 18mm high gloss black MDF, the sort you use in kitchens, it goes very well with the colour scheme in my room, orange black and green.
    Ok so some plans
    First up a basic look at the desk
    Specs of the system going in
    I7 2600k
    Asus HD 6990
    Asus Maximus 4 Extreme P67
    8GB corsair dominator GT 1866
    2x 360 rads
    Corsair HX1050w PSU
    120GB OCZ agility 3
    EK waterblocks, all nickel plexi - Full cover mobo, CPU, RAM and GPU blocks.
    Aquacomputer aqua tube res
    Xigmatek Crystal fans, 120mm and 140mm green LED ones.
    My aim is to not see any cables apart from those that cant be hidden completely such as those powering the GPU.
    I posted here as its not really a project log, I hope thats ok. I have more images uploading and will add them soon
  2. shaunster1011
    26 Sep 2011
    Ok now some images.
    Motherboard tray installed
    Reservoir installed. I have a UV led in the back and a fill port coming out the back of the desk so I can top up the water without removing the glass.
    Cutouts for temp displays in progress
    Started routing some cables under the mobo tray, also cleaned some dust up :lol:
  3. Stockium
    Stockium What's a Dremel?
    24 Sep 2011
    UK
    Looks great just waiting for some more!!! Keep it up and well done
  4. Elton
    23 Jan 2009
    California
    The black is gonna be epic. gonna keep track of this one.
  5. buchanan0204
    buchanan0204 What's a Dremel?
    15 Dec 2011
    Ayrshire
    Makes me wish I had DIY skills.
  6. shaunster1011
    26 Sep 2011
    Ok guys, got some more images now.
    (sticky pad on order to keep the pump in place)
    Still loads more to be done but im happy with the look and feel of it so far :thumb:
  7. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Pittsburgh, USA
    Looks awesome!
    Might I suggest some angled fittings to reduce your excess hose loops.
  8. bulldogjeff
    2 Mar 2010
    Gliding through cyber space
    Thats nice, like it a lot, good work dude:thumb:
  9. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    United Kingdom
    Looks really nice. Love the lighting :).
  10. mally91
    mally91 What's a Dremel?
    21 Jun 2011
    north east england
    looks awesome
