#1 |
Multimodder
Project Thief - Monster Water Cooled Build - March 9th
First off - thanks to my sponsors - CaseLabs, Monsoon Cooling, DT Waterblocks, Primochill, Corsair, EK Waterblocks, Lutro0 Customs and Alphacool
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The full build log will be posted on here and on my website - however it may get fractured into multiple posts here, so if you want an easy read go to here, you can also subscribe to my youtube channel if you so wish. Current status: Case: ![]() ![]() Workstation Hardware: ![]() ![]() Gaming Hardware: ![]() Random cool photo of the week: ![]() Index TBD!
#2 |
Multimodder
The project name is not finalized so suggestions are welcome - I thought of thief because it dual wields and it steals all my money!
I am working on a huge monster build that will showcase CaseLabs newest case - the monster TX10. This monster case can fit two SR-2 (HPTX) systems with full water cooling. As shown it could fit multiple Mo-Ra 140x9 raditors, or 6 140.4 radiators. It can even fit front mounted 140.5 radiators. The main feature will be two giant custom waterfall reservoirs that will occupy the front bays. Here is the current hardware that I have to go in: ![]() Unboxing Videos and Pics I picked up the case directly from Jim - so the packing was reduced in order to fit in my car. If you buy one of these it will come in two boxes as it's packed a lot more securely. ![]() Lots of Parts ![]() Building the case As Jim knew the case was going to be powder coated by FTWPC he saved cheesecake the hassle of sandblasting it by skipping the CaseLabs normal black/white powder coat. Because of this the case is not only in it's raw bare aluminum state, but it also is less assembled than normal in order to save on time taking everything apart. ![]() The Pedestal frame consist of top, bottom, front and back that are screwed together with countersunk screws ![]() Screwing the casters in ![]() These are the spring clips that hold the panels on - they hold the panels tight, while still be pretty easy to remove for changing your loop up ![]() Pedestal frame with one of the clipped side panel and the back plate screwed on ![]() Pedestal with all panels attached except the top/bottom cover ![]() Main case frame coming together, this is the view from the back showing the holes for the dual vertical motherboard trays ![]() Case + Pedestal with XXL window fitted on one side Here's a video of the case partially assembled: Choosing colors for the powder coat To make sure I was making the right choice on the color I decided to get some card and tape it to the frame. I removed the acrylic window and used a grey piece of card to model the motherboard: ![]() Metallic Charcoal Grey and Metallic Crimson Red ![]() ![]() Metallic Charcoal Grey, Pearl White and Crimson Red ![]() Metallic Charcoal Grey with Metallic Pearl White ![]() That's it for now - let me know what colors you like! Last edited by stren; 17th Jun 2012 at 04:22. |
#3 |
Multimodder
Paint samples came in today - it looks like "Galaxy Grey II" will be the exterior and "Silver/White" will be the interior. It's hard to show the texture, but those two are both similarly smooth, with a bit of shine but not much.
#4 |
Multimodder
Some parts came in today -
#5 |
What's a Dremel?
OMG!!! Love it. Keep it coming.
#6 |
What's a Dremel?
This is bigger than my apartment!!
#7 |
Fenrir The Wolf
This look like a server with that huge case.
I love it. |
#8 |
Multimodder
Thanks everyone!
Thought you guys might want to see some pics of the existing hardware that will be *partly* reused as well as some of the new pieces. Apologies that the photos aren't that great, my wife took the camera with her tonight so I had to use my phone. Here's my modded Antec 300 that contains my gaming rig (i7-920, Rampage III Extreme, 3xGTX480, Xonar STX, AX1200). When the workstation gets SB-E this will get the 990x. Note that one gentle typhoon is stopped - I unsoldered the power wire because it's out of balance so the noise is annoying. ![]() Here's the front of the case with the space efficient but bubbly Koolance dual D5 reservoir as well as the dual 24V controller. I'll be using this reservoir until the 18 bay cheesecake reservoirs come in. No dvd drive, I removed it after installing windows and a couple of games. Most other games I have are on origin/steam. ![]() Here's the interior - cable routing isn't perfect because I knew I was moving to the TX10 soon. I'll also be replacing all the blue LEDs with reds to match the ROG theme a bit better: ![]() ![]() Here's the workstation in it's current temporary incarnation in a DD torture rack. i7-990x on an asus p6t. LSI raid card, 3 ssds and 3 hard drives and a 8800gt to drive the monitors. It has the H100 cooler temporarily and as you can see it needs some sleeving work: ![]() Here's a front shot showing the push/pull AP15's on the H100, they perform about as well as the stock 2600rpm corsair fans at max, but with a *lot* less noise ![]() Trident + turbulence memory - back in the day this was sweet stuff 3x4gb @ 2000-8-9-8, now of course you can get better for a lot less money haha such is progress! ![]() And now for some parts waiting to be installed - vintage EK gpu block: ![]() My old rasa block - I'm hoping to not use this and instead get a second raystorm soon - note the o-rings on the barbs seem to be dying: ![]() EK 250 res and DDC-1 for the worksation gpu and motherboard loop that will be self contained on the motherboard tray. ![]() That's about all the fun stuff I can show for now! |
#9 |
Fenrir The Wolf
Can't wait for more fun stuff.
#10 |
Multimodder
Hehe thanks nor me - very impatient to get the modding started - but I still have to wait for the case to come back and some more $$$!
#11 |
Minimodder
nice job, waiting for new pictures
#12 |
Supermodder
nice work +sub
#13 |
There is no rep for awesomeness.
Moderator
OMG IT'S HIOOOJ!!! KILL IT!!! KILL IT BEFORE IT EATS US ALL!!!
Worried about expansion? As in having more kids and room for a conservatory?
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust |
#14 |
Minimodder
will be VERY interesting to see what you will do with this
sub'd
#15 | |
Multimodder
![]() Let me know if you have any suggestions
#16 |
Pump Killer
As Eddie Murphy said about Brigitte Nielsen in Beverly Hills cop: "Damn, that's a big bi**h"
![]() I can't help but loving that case! And I have a sneaky suspition that I'm gonna love it even more when it's been modded!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#17 |
Supermodder
damn thats a big reservoir!
#18 |
Multimodder
nice cant wait to see more
#19 |
Multimodder
Ah I just hope I can live up to the opportunity I have here!
#20 |
Multimodder
TWO SR-2 Systems. DID HE SAY 2 FULL SR-2 SYSTEMS. WOW
__________________
http://www.HobbieZones.com Case Mod BIG http://forums.bit-tech.net/showthread.php?t=203486 |
| Thread Tools | |
| View Mode | |
