Reply
Thread Tools View Mode
Old 10th May 2012, 16:17   #181
Roboduck
01110001 01110101 01100001 01100011
Roboduck's Avatar
Roboduck has yet to learn the way of the DremelRoboduck has yet to learn the way of the DremelRoboduck has yet to learn the way of the Dremel
They all look great but B is my favorite.
Roboduck is offline   Reply With Quote
Old 10th May 2012, 16:40   #182
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
I was thinking C+X personally
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 10th May 2012, 16:49   #183
kicklOp
What's a Dremel?
kicklOp has yet to learn the way of the Dremel
Definitely B...
kicklOp is offline   Reply With Quote
Old 11th May 2012, 09:57   #184
Phyonics
Modder
Phyonics has yet to learn the way of the Dremel
I think option D is the best!
Phyonics is offline   Reply With Quote
Old 11th May 2012, 10:53   #185
Pelihirmu
Supermodder
Pelihirmu's Avatar
Pelihirmu has yet to learn the way of the Dremel
G and this the reason:
In your case there're this red tubing and those are always found in pairs and apart. So in option G those red sleeves are just like those tubes in your case.
Pelihirmu is offline   Reply With Quote
Old 11th May 2012, 10:59   #186
daletur328
Minimodder
daletur328 has yet to learn the way of the Dremel
Still think F. Too much contrast on a light colour case, if the braiding overall is dark.
daletur328 is offline   Reply With Quote
Old 11th May 2012, 14:59   #187
Blarte
Moderate Modder
Blarte's Avatar
Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!
shut the front door ....how big is that <open mouthed gasp>
__________________
Watering down PC's since 2009....
Blarte is offline   Reply With Quote
Old 11th May 2012, 18:30   #188
stren
Multimodder
stren has yet to learn the way of the Dremel
Thanks to everyone - results are in:
So now we can eliminate the less popular and simulate these with the motherboard tray - yes it's a walk off! Jeppzer's suggestion is now also included:
Option C
Option D
Option G
Option Jeppzer
Let me know what you think - and please keep it to these four only!
__________________
In progress: Project Thief
Big thanks to my sponsors - CaseLabs, Primochill, MonsoonFree and DT Waterblocks
stren is offline   Reply With Quote
Old 12th May 2012, 10:17   #189
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Th3 last one Looks best "Option Jeppzer" But keep going men
dream1 is offline   Reply With Quote
Old 12th May 2012, 19:38   #190
Mizugetsu
Multimodder
Mizugetsu's Avatar
Mizugetsu has yet to learn the way of the Dremel
I'm almost tempted to vote for the fiddliest one to do but I'm going with jeppzer
Mizugetsu is offline   Reply With Quote
Old 14th May 2012, 09:40   #191
daletur328
Minimodder
Another for jeppzer.
Old 14th May 2012, 15:50   #192
n1c3tr1
What's a Dremel?
n1c3tr1 has yet to learn the way of the Dremel
Still Option D.
n1c3tr1 is offline   Reply With Quote
Old 14th May 2012, 20:06   #193
avolla
Hackintosher
avolla's Avatar
avolla has yet to learn the way of the Dremel
looks good so far. keep up the great work.
I'd have to say option D is my favorite. have a nice contrast but isn't as distracting as some other ones.
avolla is offline   Reply With Quote
Old 14th May 2012, 20:08   #194
stren
Multimodder
Thanks everyone for the feedback - in the mean time I'm by Monsoon Free's sexy new rotaries:
Can't wait to use them!
__________________
Old 16th May 2012, 00:19   #195
stren
Multimodder
Thanks for the feedback everyone!
Alright - another diversion to clean up the odds and ends - well I got some packages to help with that:
Inside a box..... is another box:
And inside - the opposite of a CaseLabs case - cheap design, cheap steel, cheap manufacturing:
Despite knowing how badly the edges were finished I still managed to cut myself!
Mounting the old workstation board:
Now let's see what's come in from the egg:
The PSU for that mATX build I did (those photos were slightly out of order), another ssd (because 7 isn't enough) and a cheapo gpu for the 4u case:
Passive GPU is passive, crappy sas card is crappy:
Got those straight to straight sata cables too:
__________________
Old 16th May 2012, 08:54   #196
fr0Zen
sabertooth 990FX
fr0Zen has yet to learn the way of the Dremelfr0Zen has yet to learn the way of the Dremel
lots of good stuff and side projects
__________________
http://forums.bit-tech.net/showthread.php?t=249950the big thing
fr0Zen is offline   Reply With Quote
Old 16th May 2012, 17:26   #197
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for president
cool! always wanted to do build rack mount system...
mnpctech is offline   Reply With Quote
Old 16th May 2012, 17:32   #198
Mosquito
Hypermodder
Mosquito's Avatar
At first,[before reading] I saw those pictures and thought "what, rack mount a server inside in addition to the two computers inside that huge thing already?" And then I got to thinking... why not?
__________________
Mosquito
Old 16th May 2012, 19:28   #199
Raiden
Portuguese reviewer
Raiden's Avatar
Raiden has yet to learn the way of the Dremel
I love that case
Do you really need all those pc´s?
Hoping to see that huge case finished!
Raiden is offline   Reply With Quote
Old 17th May 2012, 11:45   #200
Williz
Supermodder
Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.
Insane case, good job on the progress I'm going to love to see this when it's finished.
__________________
Silverstone RV-02 White edition / Asus Crosshair V / AMD 1090T Phenom @ 4 GHz
RAM 16Gb G.Skill RipJaws Z 1.5v DDR3 @ 1600 / 2x XFX 6870 Black Editions
1x Crucial M4 64Gb /4 x 1Tb Samsung (Need to check what models)
PSU = Seasonic 760w GOLD rated
Williz is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
