Reply
Thread Tools View Mode
Old 29th Aug 2012, 13:22   #241
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.
WOW sub'd this thread is full of hardware goodness and im loving that behemoth of a case, looking forward to the waterfall reservoir...
__________________
Main Rigs:~ i7 4790K @ 4.8 WC'd - 16GB @ 2400 - EVGA GTX 980Ti | Alienware 13 Laptop, i7, Dual M.2 SSD's, 16GB and Graphics Amp
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 29th Aug 2012, 13:58   #242
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
Wow , Its all coming together now ,
SilveR_172 is offline   Reply With Quote
Old 14th Sep 2012, 23:52   #243
stren
Multimodder
stren has yet to learn the way of the Dremel
Yeah me too
Needs more dremel lol!
Another update - big one too!
So this is where we were last time - gaming rig trying to get up and working in a temporary state. Main loop not yet connected:
To finish the main loop we needed to connect the EK400 reservoir with the custom 1" NPT tap to the Iwaki RD-30 pump. First we need to build a T section for the drain port:
These are standard schedule 40 pieces of PVC that I'm gluing together. I took a T junction and two 1/2" NPT reducers as well as a piece of 1" grey electrical conduit for making the 90 degree turn:
This is all based on amuseme's idea except that I'm using 1" pipe instead of 0.75" and I connect to the pump slightly differently. So now we have to connect to the pump:
So we take a 5/8" brass barb from your local hardware store and tape it up with teflon tape:
1/2" tube can be warmed up and stretched over the barb. The idea is that the barb lines up right next to the 5/8" input to the Iwaki giving less restriction to the input feed of the RD30 unlike regular 1/2" tube would. I also added a 2nd barb for the drain tube. This reservoir coupled with the 1" pipe means there is a lot of water that needs draining easily:
Both barbs in:
Now let's hook up the pump:
Add some worm clamps so that nothing flies free when you turn the pump up to 29V:
Now let's add the drain tube, the tube color is temporary for now:
Add the drain port:
Add a worm clamp and we're done for now:
Now it's time to put it in the case. As the reservoir was temporarily mounted we need to fix it first. There's a convenient metal plate in the case that you can unscrew and drill holes in:
Now let's reinstall that in the case:
And done:
The reservoir is fed by two drain ports. When feeding a larger amount of water it's useful to have one for water coming in and another for air coming out:
Now here's the Iwaki Plus feed tube situated in the base. The cardboard box will be replaced with anti-vibration gel soon enough:
Here you see the gap between the Iwaki feeding tube and the tapped base of the EK reservoir:
I cut a piece of schedule 40 tube to size to glue in here:
Later I will paint all of the tubes so it doesn't look so bad The cardboard box doesn't quite raise the Iwaki high enough so we'll need to swap that out:
But here it is fully connected:
And here's the whole side of the gaming case in it's temporary state:
Now we can add the 360 radiator back in quickly (30 seconds) due to the Koolance quick disconnect fittings and the CaseLabs side mount design:
I can't fit a 480 in because of the placement of the radiator and the feed tube. I may move it later, but for now this works. So it's time to fill up with water:
__________________
In progress: Project Thief
Big thanks to my sponsors - CaseLabs, Primochill, MonsoonFree and DT Waterblocks
stren is offline   Reply With Quote
Old 15th Sep 2012, 02:07   #244
Bladesingerz
Hypermodder
Bladesingerz's Avatar
Bladesingerz is the Cheesecake. Relix smiles down upon them.Bladesingerz is the Cheesecake. Relix smiles down upon them.Bladesingerz is the Cheesecake. Relix smiles down upon them.Bladesingerz is the Cheesecake. Relix smiles down upon them.Bladesingerz is the Cheesecake. Relix smiles down upon them.Bladesingerz is the Cheesecake. Relix smiles down upon them.Bladesingerz is the Cheesecake. Relix smiles down upon them.Bladesingerz is the Cheesecake. Relix smiles down upon them.Bladesingerz is the Cheesecake. Relix smiles down upon them.Bladesingerz is the Cheesecake. Relix smiles down upon them.Bladesingerz is the Cheesecake. Relix smiles down upon them.
Awesome to see an update again man! That pump looks powerfull, where did you get it ?
Bladesingerz is offline   Reply With Quote
Old 16th Sep 2012, 06:42   #245
avolla
Mini Water Modder
avolla's Avatar
avolla is the Cheesecake. Relix smiles down upon them.avolla is the Cheesecake. Relix smiles down upon them.avolla is the Cheesecake. Relix smiles down upon them.avolla is the Cheesecake. Relix smiles down upon them.avolla is the Cheesecake. Relix smiles down upon them.avolla is the Cheesecake. Relix smiles down upon them.avolla is the Cheesecake. Relix smiles down upon them.avolla is the Cheesecake. Relix smiles down upon them.avolla is the Cheesecake. Relix smiles down upon them.avolla is the Cheesecake. Relix smiles down upon them.avolla is the Cheesecake. Relix smiles down upon them.
I had forgotten how big this build was until I was your sandals next to that case. Any idea how much this thing is going to weigh when your finished with it?
avolla is offline   Reply With Quote
Old 21st Sep 2012, 09:34   #246
Phyonics
Modder
Phyonics has yet to learn the way of the Dremel
Can you post a vid of the coolant flowing into the res, I want to get an idea of how fast the flow is. Thanks.
Phyonics is offline   Reply With Quote
Old 15th Oct 2012, 18:05   #247
stren
Multimodder
Thanks yes it is, most powerful pump anyone really uses in watercooling as it's a bit of beast. It can crack acrylic or blow tubing off if you don't lock things down right.
Haha I wear size 15s too! I don't know, thank goodness it has wheels. I'd need a buddy to lift it even if it didn't weigh too much just because of the size of the thing. It's bigger than most washing machines and some server rakcs.
I'll try to get one up, it doesn't really show well though. I've hit 3.5gpm before with it.
Well time for a bit of an update! A big thanks to Corsair for sponsoring the build
My original dominators (same part number) came in a much more boring box than this one:
And if you're wondering just how small those overclockable low profile sammy dimms are:
BTW just wanted to add that I started a facebook page so that if you're into that kind of thing you can keep updated on my reviews and other stuff!
https://www.facebook.com/ExtremeRigs
__________________
Old 19th Oct 2012, 13:51   #248
stren
Multimodder
Morpheus from OCN stopped by and gave me some fan splitters which come in very useful for the quick disconnect of the radiators. Each radiator has two 3 pin headers that come from each side. This little PCB is then attached to the backplate of the pedestal:
One for each side of the case. The distance between the two is conveniently sized to feed from a single molex
I also got done painting the 24V Power supply for the Iwaki pump. I don't think I showed a pic of it before, but it looked like a very beat up version of this:
Except that the mesh part was painted black on mine and had been worn off over time.
So I thought I'd paint the whole thing red and then mod a PSU support from the bottom heat chamber so that it can be mounted next to a fan from the HDD rack. I also need to hook up a relay so that it only turns on when the computer is on. Here are the pieces after painting and clear coating:
With the PSU back in and the heatsinks retimmed:
All sealed up:
That's it for now. Now that I have my windows PC up and running I can finally get sketch-up back and running and start playing with ideas for custom blocks and reservoirs!
Don't forget to like my facebook (www.facebook.com/extremerigs) if you want previews of updates, giveaways and also my watercooling reviews (17 cpu block roundup in progress)!
__________________
Old 21st Nov 2012, 01:14   #249
stren
Multimodder
11/20/2012
Well it's been a while - I was busy working on my new website, the CaseLabs Merlin Preview, Spotswood Tech Station Review, the EK X3 Reservoir Preview, figuring out my new Nikon D5100 as well as finishing off the CPU Water Block roundup. I need a break but I'm almost done with all of that! Anyway - to celebrate not being fired yet I thought I'd work (finally) on the waterfall reservoir. This was originally inspired by Cyberdruid, however as he's retired I figured I'd have to make my own, and I suppose that's more fun anyway. I knew I would need a few attempts at this to get it right so I figured I'd make the prototypes out of MDF as it's cheap and easy to work with. So I went to the hardware and picked up a small board of MDF:
Dragged out my lonely tablesaw from the shed and got to work. I cut some 3x 3" strips of the 4ft side of the board:
I then measured the height of the 18 bays in the case and made the cut on one strip:
Then I test fitted in the case which meant undressing the drive bays!
Alright let's take that cover off:
Well that was fast, ok, drive bays next:
Resting the wood on the bottom of the drive bay gives me this much clearance which is about perfect:
So I cut the other side to the same size. Then measured and cut the top piece:
It's ok for both these pieces to be flush because they'll be some kind of joinery action going down. For now I'm thinking a finger joint. Maintaining strength while being able to knock it out on the table saw. I then cut a matching piece for the base so that all the frame pieces were cut:
I then started cutting the pieces that would form the waterfall itself:
Seven down:
Tablesaws make this quick. All done, sitting on the uncut acrylic sheet that will make up the front and back:
That's it for now!
__________________
Old 21st Nov 2012, 07:53   #250
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Thats going to be sweet!
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 21st Nov 2012, 09:16   #251
coolamasta
coolamasta's Avatar
Schweeeeeeeet looking forward to the waterfall
__________________
Old 22nd Nov 2012, 17:16   #252
Bladesingerz
Hypermodder
Awesome to see some progress again Stren! Looking forward to see your waterfall reservoir!
I was wondering though, with what are you going to waterproof it? MDF instantly dies when it touches that much water.
Old 2nd Dec 2012, 02:54   #253
stren
Multimodder
Thanks
Yeah me too!
MDF is only for the prototype, I'll use acetal for the real thing. So it'll be "splashproofed" with some external paint and some polyurethane
It was raining a good bit this week so I didn't work on that, instead I put some painted parts back together. I reassembled the rotors into the housing:
The paint was standard automotive stuff and came out quite nicely the red is metallic:
So it was time to sleeve:
I started with the push fans and mounted them on the pull side of the radiator so that the spacing would be correct. Most of the time sleeving these is really spent soldering wire extensions on:
Slow progress:
Done with the first set of 3:
Mounted the push fans on the push side:
Now it's time to work on the pull fans:
Ran out of red wire so I used yellow:
Done with the pull side:
Now it's time to join both sets of three into one. This is the 360 that will be replaced with the painted one:
All put together on the push side:
And the pull side - which will need some custom stickers to pretty it up:
I also sleeved a matching fan to go on the motherboard tray:
And there it is running:
__________________
Old 2nd Dec 2012, 06:32   #254
dotdrew
Minimodder
dotdrew's Avatar
dotdrew has yet to learn the way of the Dremel
This whole build is incredible, love the fact that it houses two PCs haha. Keep up the good work, by the time you're finished you'll be wanting to swap in some IB-E CPUs and 700 series GPUs
dotdrew is offline   Reply With Quote
Old 2nd Dec 2012, 12:34   #255
KrunchR
Supermodder
KrunchR's Avatar
KrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpit
I love the contrast of the sleeving and the fins of the fans, to the casing colour. Nice.
KrunchR is offline   Reply With Quote
Old 19th Jan 2013, 11:43   #256
stren
Multimodder
Haha yes - that's if IB-E isn't obsolete by the time I'm done
Thanks
Time for another belated update:
Hey everyone - it's been a while. Moving house soon so all I've really done is assemble some parts and do some sleeving. Here's the 24 pin extension. Eventually the PSU will get full sleeeve, but extensions can be trained better, so let's do those first.
Getting ready - cut the wire last night:
Getting my crimp on...
Males done:
Stripping:
Females done so now we our crimping is double-ended:
Heatshrinkless FTW:
Details:
Should have cut the outer run longer than the inner wire otherwise this happens:
I'll either redo or just train the extension to have a hidden double kink that should take it out.
Making progress:
My fingers are definitely burned now:
And done:
Daylight pics:
__________________
Old 19th Jan 2013, 12:59   #257
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
Looks neat dude !
KoSoVaR^ is offline   Reply With Quote
Old 20th Jan 2013, 03:08   #258
Nutman
Never stuck with stock
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Very nice. I like the pattern.
__________________
Best regards, Nutman
Projects: Nutman - Hampen - F.O.B. T.C. - BabyShark - The Scratchbench
Nutman is offline   Reply With Quote
Old 20th Jan 2013, 04:09   #259
siliconfanatic
Johny-come-Lately
siliconfanatic's Avatar
siliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyan
*gulps down mexican coke, waits for updates on res* can't wait to see more!
__________________
Do not let anything good in life pass you by. Cherish it with all of your heart, because before you know it even life will have passed you by. And if you let all those things pass you by? The only thing filling your heart will be deep sadness and regret. So whatever you do, hold on, and never let go.
siliconfanatic is offline   Reply With Quote
Old 24th Jan 2013, 08:26   #260
stren
Multimodder
Originally Posted by KoSoVaR^ View Post
Looks neat dude !
Thanks
Can't wait to have all of them done
Sadly the res has to wait for me to move house in a few weeks, once I'm unpacked I'll have some more garage space to get to work on it
Meanwhile, more sleeving:
Here's some more after finishing up a 6 pin and 8 pin extension:
Also today I finally put the right memory in the gaming rig:
This case now has 14 sticks Dominator GTs running... still needs the memory block and the right fittings though!
Then I messed about with the camera:
Didn't quite work out, but thought I'd share anyway
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
