#261 |
Never stuck with stock@Hotmods.net
Too bad you have to use clamps for the tubing - they look too "ghetto" if you ask me. Hardly befitting of the remaining project.
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#262 |
< Your add here >
Agreed Nutman, Bitspower Luxery tube clamps would look alot better. Not sure if they're available in the right size though.
Other than that, this build is drool worthy!
#263 |
Multimodder
The barbs are temporary. Don't worry they'll all be prettied up with shmexy compression fittings by the end.
__________________
In progress: Project Thief Big thanks to my sponsors - CaseLabs, Primochill, MonsoonFree and DT Waterblocks |
#264 |
Multimodder
MEGA POST!
So it's been a while. Not much progress on the build because I've been busy moving house, securing more sponsors for this build (see below) and getting review samples for future reviews as well as finishing existing reviews. I finally wrapped up my 17 cpu water block roundup which is posted on my website(extremerigs.net) and XS. Next I'm working on a pump/top/res roundup and a Titan water block roundup. In between I'll be slowly finishing this build. So here's everything that's happened in the last two months, some of which is relevant to the build and some of it isn't, but I figured I'd include all of it anyway. Koolance sent some stuff - this is all for review though rather than this build: ![]() PMP500, a D5 top and integerated 120mmx70mm (fat) reservoir and a bunch of the new QD style QDCs: ![]() Let's start with the D5 Top: ![]() ![]() This is a full cover top that completely encloses the pump unlike the EK one that is just a top. A cylinder reservoir can also be mounted directly to the top if you want. With Bitspower you can buy a top and a seperate dress kit but the Koolance has all of it included: ![]() It comes with mounting brackets and plastic thing that I'm not sure yet as to the purpose! The top is pretty serious and bulky like most D5 tops. If you want small, stick with a DDC style pump: ![]() ![]() The reservoir that Koolance sent is their "fat" 70mm ID variety which needs adapters to fit to the pump top: ![]() This should not be used for a frosty beverage: ![]() You can see the threaded adpater which will screw into the pump top. The pump top comes with a base adapter for a "normal" size reservoir. ![]() Here it is fitted - the size actually works because the D5 top is so bulky: ![]() Obviously the ftting at the top of the pump top would need to be removed and moved to the side inlet port. One thing I don't like is that this means you have to use the top port of the reservoir as your return line. I prefer to have that as the fill port. ![]() They also sent a PMP500 for review. This is their all new design that is much more powerful than a D5 or DDC pump: ![]() Came with no instructions: ![]() A mounting bracket and some screws but nothing else: ![]() Integrated heatsink and nice looking top, but the two halves do clash a little in style: ![]() It is however very compact for a more powerful pump. A D5 with a top is considerably larger: ![]() I'll also be reviewing the new QDC's. I'd used the VL4N and VL3N's for a while and my main complaint was that the female connectors were sensitive to being bent out of shape when dropped. The new design should be more robust: ![]() The QD4 series is the larger size that is more designed for industry than us guys. It is marketed as a direct replacement to the VL4N. It's larger and lower restriction than the QD3 and has fewer useful connection options. They do however come better packed: ![]() No way these things will be damaged in transport. The business ends: ![]() ![]() Connected - you simply push the two together: ![]() Disconnected - you simply pull the ring labelled pull: ![]() I have to admit I prefer the new mechanism - there's less time in the zone of being partially open, these really snap on and snap off quickly. No rotation is also a good thing as it lowers the risk of the other end of the tube becoming unscrewed. The QD4 comes with two options for the other end - either 1/2" ID 3/4" OD compression fitting or a male g 3/8" fitting. Note that this is not a standard g 1/4 like 99% of computer water cooling components. However Koolance have an adapter ready for you if you do wish to use these: ![]() It barely adds anything to the length unlike the alphacool adapters that I've used in the past. I also like that they've included wrench flats on the threaded version: ![]() Because these are lower restriction they are more bulky and will not fit on a block even with widely spaced ports like their own CPU-380: ![]() The QD3 series on the other hand is designed for computer enthusiasts. It's smaller and replaces the VL3N line up. These instead get packaged like normal fittings but with a protective rubber.... sheath on the quick disconnect end: ![]() Those were the 1/2" ID 3/4" OD compression fitting ends. These are the male g1/4 threaded: ![]() One of each with their rubber... booties on: ![]() The quick disconnect part is much smaller: ![]() Unlike the QD4's these can be directly mounted on most blocks that can fit 3/4" OD compression fittings as the compression fitting lock ring is the widest part of the QDC: ![]() QDD3 vs QD4: ![]() EK are sponsoring the build so a big thanks to them but also sent some stuff for review in the upcoming pump/res/top roundup: ![]() The RP452x2 I have will actually be removed and replaced with the 400mm reservoirs that EK already sent me earlier in the year: ![]() That RP452x2 will be part of the roundup though lol. EK sent me lots of coolant: ![]() I was trying to take a cooler shot - but it kinda looks like I'm bragging about my car so :shrug: ![]() DDC top - this replaced the XSPC acrylic one that I have so that all my pumps/reservoirs are consistently EK: ![]() Unboxing - ![]() I do love EK's packaging, the best out there to be honest and it makes you feel like you bought a quality product: ![]() Individual baggies: ![]() Sealed with a logo: ![]() There's been a lot of hate on those circles, but EK are changing their designs now thanks to the thinkcell voting: ![]() I have to admit I'm a sucker for the details though: ![]() Not much detail on the inside: ![]() You can see the slight angle upwards to the port: ![]() White D5 top - this replaces my old style EK Black D5 top: ![]() Taking it's shirt off: ![]() ![]() White on white is hard to see: ![]() So let's see it on a metallic grey background: ![]() I think this one unlike the DDC has a few too many circles ![]() Do you spot the white theme: ![]() These will be on the workstation side representing the public "light" image of the thief, vs the gaming side representing the hidden "dark" side of the thief. There is some variation in the white acetal color but it's pretty minor. Hopefully it won't be noticeable: ![]() Lovely detail on the inside though it's hard to see: ![]() Now for that white reservoir that I posted an unedited version of this pic: ![]() Well let's do it properly now: ![]() Comes bubble wrapped and with an optional filter ![]() All the accessories - sadly the mounting clips are still black: ![]() The base has 5 ports on all versions. The difference between the basic and advanced is instead the top. On the basic it only has one port. That's ok for me. I like to use the top as a fill port only and have the return in the base: ![]() ![]() ![]() The anti cyclone works, however bleeding is slightly faster if you use a long tube instead to prevent the bubbles getting back in the outlet: ![]() Dual D5 top - this replaces the bitspower one that I have, but never got to put in build. This will actually replace the Koolance RP452x2 that I'm using right now. Anything pump/top/reservoir will be reviewed in the upcoming roundup lol: ![]() ![]() ![]() ![]() ![]() Underside of the top: ![]() Top of the top, only a few circles: ![]() With the clamp plate that holds the D5 on added: ![]() This one is just for review not the build: ![]() ![]() 2 bay res with integrated DCP 2.2 pump: ![]() Lots of circles: ![]() The bottom bay of the res is actually pretty useless, it's really just filling up the space around the pump: ![]() Lutro0's sponsorship package arrived so that I can finish my sleeving. Got a fancy wire stripper: ![]() It was a bit dusty in the box but who cares about that: ![]() Lutro0's crimper. Supposedly the same as MDPC's but with a bit of milling to make it usable with AWG16. I need to get my MDPC one out to compare: ![]() Comes with two example crimps just like Nils sends: ![]() Flush edge cutters for cutting sleeve *not* wire: ![]() though you can use them for wire, you'll want a 2nd pair for that so they stay sharp: ![]() Molex pin extractor: ![]() Crimps and connectors: ![]() Lots of wire - each one is one spool, I'm not sure why it wasn't left on the spool? Maybe so it is easier to train? I'm going to ask Lutro0 when I get some time. ![]() And an example 24pin extension from the man himself: ![]() Also picked up this fan as a test to see how quiet it can go. I'm thinking of changing out all the fans now and running uber silent now that my long term plan is to use the front bays for 4x360 rads ![]() Goes down to ~400rpm and Martin recommended it as being very quiet: ![]() Also got this as a tester because to be honest LED fans are cooler than white ones: ![]() PWM but only goes to 600rpm and is allegedly a bit buzzy ![]() Has a switch for the LEDs ![]() Also figured I should try PWM control of the existing gentle typhoons and yates in case it's the same volume and I can make my life easier, so I got one of these. Also recommended by Martin: ![]() I got the smallest one that fits in a 3.5 bay but there is a 6 channel one that takes up one 5 1/4" bay: ![]() If I end up using it I will be hiding it because it is pretty ugly: ![]() Welcome to Alphacool also who are sponsoring the build. They sent me some rads as well as other stuff for review: ![]() The monsta'st monsta: ![]() Hard to photo because it's so big: ![]() It's big. Next to an XSPC RX360 with push pull fans: ![]() Comes with copper accessories which sadly don't match my build: ![]() Also the sexy full copper UT60 in white: ![]() Get ready: ![]() Cause it's hot: ![]() And it makes me want to take off all my clothes: ![]() Also the full copper 45mm thick 560 known as the XT45: ![]() Still bubble wrapped - I spot a pattern: ![]() A 45mm rad doesn't normally look thin, but 560's are so big that it does: ![]() Next to the monsta: ![]() Also a thin 360mm, thin is useful for the side mount next to the PSUs where I don't have much room: ![]() This puppy is 30mm thick: ![]() ![]() Looks skinny next to a 60mm UT60 which itself is skinny compared to the monsta... ![]() They also sent some stuff for review in the pump roundup: ![]() This is a single bay res with dual pumps: ![]() ![]() It takes these tiny DC-LT pumps from alphacool also, they're not included with the res: ![]() But they sent me some too: ![]() Box not up to the usual alphacool standard: ![]() Tiny DC-LT pumps, we'll have to see what they can do: ![]() No kidding they sent me more stuff for review: ![]() Well we know it's a pump/res of some kind: ![]() It's a 2 bay res that can mount 2 D5s. It's a similar setup to the RP452x2 that I have: ![]() Alphacool's black/copper theme is very consistent: ![]() This one won't go in the build: ![]() ![]() But it did come with 2 D5's which I may end up using to replace the DDC or Iwaki: ![]() Alphacool's VPP655 is just a bare D5 vario with tach wire: ![]() ![]() Spotswood had also sent me an update for the tech bench after I had some feedback for him: ![]() A new "open" top tray: ![]() Taller posts so that the PSU can be mounted vertically, enabling a 2nd PSU to be fitted: ![]() And a HDD rack: ![]() This is the old one: ![]() Getting taken apart: ![]() Now with more rotation: ![]() I tried the HDD rack at the back: ![]() (I have the case rotated on my bench so that the back is easily accessible). The HDDs slide in on rubber grommets: ![]() Adding the new top: ![]() With boards and gpu: ![]() Nearly done: ![]() In the end I moved the HDDs to the front and mounted the crystalfontz data logger in the back: ![]() This gives me space to get my hands under the motherboard for fitting backplates. I tried mounting a 360 to the side, but had to offset it a little for easy tube routing: ![]() Now you can see the datalogger next to the PSU: ![]() You can also see the GT that I mounted on a sliding arm under the CPU. This cools the VRM's on the back of the board that will cause CPU throttling if they over heat. The sliding makes it easy to move out the way if needed: ![]() ![]() Move views: ![]() I'll be using this just for controlling PWM in the upcoming pump testing lol. Talk about overkill. I have a couple of new cpu blocks to test though and then a titan waterblock roundup to do afterwards so it'll be more useful for that: ![]() The schmexies: ![]() Close up of how Spotswood builds up the frame from all the extrusion pieces:
__________________
#265 |
sabertooth 990FX
you are the king of overkill, and i love it!
__________________
http://forums.bit-tech.net/showthread.php?t=249950the big thing |
#266 |
You give a whole new definition to the term "MEGA POST". O_o
__________________
#267 |
modeteer
I'm not going to lie... this log would be a whole lot more interesting without the 105,345 pictures of tools and kit boxes
![]() We get the point, EK sent you some stuff! Get back to the good stuff! |
#268 | |
Hypermodder
More modding/building progress less "kit". Looking forward to more progress pics, it's looking good so far
__________________
Mosquito Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC |
#269 |
Shut up and Mod
So i guess... since you have sponsors and free stuff, its not called 'Thief' cause its not robbing your wallet trying to make us jealous?
__________________
Life. Liberty. The pursuit of those who oppose it.![]() Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide @furballzen |
#270 |
Modder
Now that I seen your car's wheel, my urge to guess what is has been awakened
if those are still stock wheels, could those be by any chance a 3 series? Sorry for my digression on your build, on the right note, its coming along nicely... all you are missing is a cannon to add onto that caselab case... it could seriously pass off as a case tank because of its size, I knew it was big, but I then realized I was underestimating it after you showed pics of comparisons the recent update took an hour to digest, I oogled at each pic for about an hour nnnnnnngh keep up the good work
__________________
Current Rig: i7 920 oc @ 3.5 GHZ, Evga X58 SLI FTW3, 24 Gb G Skill Sniper Ram @ 1600 Mhz Evga 670 GTX FTW SLI Need to build something new soon... I'm thirsting for a new build
| Thread Tools | |
| View Mode | |
