#21 |
Multimodder
I wish - but no, I might be able to get an SR3 for the workstation, but the gaming rig will stay X58 for now. Later on I may add a 4P folding system but that won't be for a while. Money isn't that flush
Some other TX10-D owners have said they plan to do 2 SR-3 systems, obviously they can't yet but I haven't seen anyone put an SR2 in there yet, I guess people are waiting for the SR3
#22 |
Multimodder
sneak peak
#23 |
Ban-Saber
Moderator
That thing is a monster, I'll be keeping an eye on this one
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home" www.yodasarmpit.com clickr my flickr |
#24 |
Multimodder
Well guess what came today:
#25 |
What's a Dremel?
That case is CRAZY! Really interested to see what you do with it.
I am planning a new rig in the soon future and case labs have really caught my attention. They look like wonderful cases. Althought im thinking more the lines of an MH10. I think trying to make the most out of TX10 is a little outside my budget. All the best with your build. Looks really good so far. |
#26 |
Multimodder
Thanks Mambro. Yes the TX10 is a challenge in many ways lol.
My testpack of monsoon fittings arrived today, these are the 3/8 ID 5/8 OD ![]() ![]() With primochill tube: ![]()
#27 |
Multimodder
Seeing as my boss gave me the week off (why not a raise?) for having to work like crazy the last month I decided to test out some of the components that came in on my workstation. for the last few months it's been running the H100 cooler, now it's time to switch it to partial watercooling.
In the end the workstation will have two loops: 1 - CPU (raystorm) - mora 140.9 - dual D5 varios 2- GPU (8800gt) - GPU (9800gt) - motherboard - DDC-1 - RX360 The GPU's only do 2D, so there's very little heat on loop2. Both loops will eventually run with low speed yates and I'm hoping it should be close to silent while giving excellent overclocking performance on the cpu. As I don't have 4 D5's yet (still one short) I'll be temporarily running this loop with a DDC. I picked up one of the NOS ones from bmaverick, they're not that powerful but this won't be driving a critical loop. I picked up an xspc acrylic top (later I'll run some dye for the money shots): ![]() ![]() However the XSPC screws don't fit the old DDC's so I had to drill out the holes a bit larger ![]() Done: ![]() Then with the EK 250 res fitted. I used a bitspower shining silver male to male rotary fitting to attach them: ![]() Also remember that talk about the acyrylic vs delrin 8800gt blocks, well I ordered the acrylics and they arrived the other day: ![]() They do look sexier! ![]() ![]() Taking apart the 8800gt: ![]() Then I realized I didn't have any non-conductive TIM left, so I put it to the side and put the 9800gt in for now. Built up the temporary cpu loop in the torture rack ![]() ![]() Kind of a funky radiator setup - the torture rack only supports 240 rads, so I ran 2 fans in push and 2 fans in pull. I have 12 more gentle typhoons coming from the ocn group buy: ![]() Then more stuff came: ![]() Fan adapters for the gtx 560, plus rubber fan isolators. Not sure if they'll do much but they were cheap if I bought the adapters, so I picked some up:
#28 |
What's a Dremel?
Just bought a pack of the same monsoon fittings because of this thread. so beast
#29 |
I *am* a Dremel
I need to find a UK distributor of those fittings as they look stunning.
Loving the look of this build will be watching with interest
__________________
Intel i7 2600k | Be Quiet Dark Rock Advanced | ASUS P8P67 pro | Patriot 1600 6GB | XFX 6870 Twin fan | corsair 650W | OCZ Vertex II 30gb | Samsung SP 1TB, Samsung 1.5TB, Samsung 500GB | Lian Li V-1000 | 2x23" screens |
#30 |
Multimodder
Thanks guys
#31 |
Multimodder
So I'd been suffering wrist pain after pulling 20 hour days working on CAD stuff. This isn't unusual when I'm forced to use a bad mouse or a bad setup, but my trusty G5 on a bare desk wasn't cutting it. I decided to try a "gaming" mousepad and thought I'd check out a razer deathadder while I was doing it. After a few weeks of it I actually prefer the feel of it despite the construction feeling less sturdy and having less features than my trusty G5. The G5 now gets relegated to the gaming rig as I game less than I work
![]() ![]() ![]() Also parts for my lightsabre came in ![]()
#32 |
Multimodder
Seeing as we're all a bit bored waiting for the case to come home, here's some more hardware:
#33 |
Multimodder
Tease mode activated
A box arrived ![]() You said flap ![]() ![]() The largest usb flash drives known to man and some awesome sauce: ![]() Sometimes the front view is better than the back: ![]() Opening a door: ![]() Socket 2011 is bigger than I thought: ![]() Inside the box is two more boxes: ![]() - Curiously only a 2x CFX cable, but yet 2/3/4x SLI cables - The sata 6gbps cables are black with partly white connectors as opposed to full black for the rest of the cables. - The OC key that plugs inline with your monitor doesn't support high res monitors - bit of a fail there Asus. Shouldn't affect me as I can use the USB cable from my other rig anyway - It would be nice if the back of the backplate was also black rather than the shiny tin foil like other boards ![]() And the last tease for the night:
#34 |
I'm satisfied with my E5300
OOhh man! giant case, amazing!
#35 |
The modding head is firmly back on.
That caseis just mental...I want 2..
I can't wait to see how this thing turns out |
#36 |
long live the pc
loving this build mate cant wait to see more
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl, ![]() |
#37 | |
Multimodder
Thanks
![]() Quote:
Welll.. hold on one second then.... I'm having second thoughts about letting cheesecake build the res's. I have some interesting ideas myself about what do with them and it'd be nice to have something truly custom and unique. We'll see, I'll do some planning in the background and see what I come up with. |
#38 |
Multimodder
Seeing as Peteski wanted to see more - I had some time for another photo session because the cpu doesn't get here for a few days:
Took the board out: ![]() ![]() Took the ram out, seems to be the fastest I've seen at 1.5V with 4GB sticks. ![]() Installed the ram, note that the polarity is reversed on each side, which makes sense if they flipped the pinout on the chip. ![]() The paint job on the fins wasn't that even - some sticks definitely got more coverage: ![]() Time to take off the heatsink in preperation for the EK full cover block: ![]() Only the VRM area had thermal pads on the back and front of the heatsink: ![]() Looks like Asus have moved away from that horrible yellow TIM they had on the R3E: ![]() The VRM area with heatsink removed:
#39 |
long live the pc
man that mobo is sweet as .cant wait to see the ek block on there
![]() P.S thanks for the pics
__________________
#40 |
Making You Feel Old Since 2010
This is all just, so very insane!
Keep up the overkill!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
| Thread Tools | |
| View Mode | |
