Reply
Thread Tools View Mode
Old 21st Feb 2012, 01:15   #41
stren
Multimodder
stren has yet to learn the way of the Dremel
Originally Posted by peteski View Post
man that mobo is sweet as .cant wait to see the ek block on there
P.S thanks for the pics
Hehe np
Originally Posted by KidMod-Southpaw View Post
This is all just, so very insane!
Keep up the overkill!
Will do!
Chip arrived, motherboard and ram blocks don't come until tomorrow though.
SSD is actually for my wife's rig. I don't have an ssd on my gaming rig yet. I only use it for games so I wouldn't see that much benefit from a boot drive. I use my workstation for web browsing etc as it's on all the time. I'd need a 512gb drive or so to cover my games, so I'm waiting for prices to come down more
Batch on the 3930K is 3152B448, we'll see how it clocks soon
stren is offline   Reply With Quote
Old 21st Feb 2012, 05:22   #42
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
i have that same ssd the differenc in boot time's are unreal compared to a normal drive
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 22nd Feb 2012, 02:29   #43
stren
Multimodder
Yeah I think it should make a huge difference for her.
Some blocks came in
Nickel plexi because I want to run some red dye (on special occasions only for all you dye haters out there)
Finished cleaning the TIM off the south bridge only to find a piece of tin foil with more TIM underneath. Weird.
Pretty easy to install when the block is in two parts, the single piece blocks are much harder:
VRM area:
Full board:
and one more:
That's all for now
Old 22nd Feb 2012, 05:13   #44
peteski
long live the pc
peteski's Avatar
again that board is so sweet it make's my asrock look cheap
__________________
Old 23rd Feb 2012, 16:47   #45
stren
Multimodder
Thanks peteski - the asrock board itself looks sweet though, they've really improved their designs
With ram blocks now, the fittings aren't the final ones, just more for planning. I'm working with Monsoon free to see if something special will make the tube routing super clean
the ram blocks remind me of battersea power station:
Now adding in the gpu makes it look ugly and busy The copper and green pcb really don't match. I called a nickel plating company to get a quote on plating both copper GPU blocks and it was $175 for both! So that's not going to happen. I may switch to the other acetal/copper block and paint the edge of the copper silver. I have another idea for the PCB
Much better with the gpu off again
Old 25th Feb 2012, 00:17   #46
stren
Multimodder
No comments? Come on bit-tech!
Soo like I mentioned before I really didn't like the green/copper look clashing with the black/red R4E theme:
So I started to paint the GPU with liquid tape - first coat:
So here's how it looks now after two coats on both sides:
You can see some of the texture here, liquid tape is hard to work with - either annoyingly thick, or very thin and see through:
From this angle the texture isn't as bad:
However it would look a lot better with a backplate, I'm thinking something like this, smoked acrylic with an etch and a couple of LEDs to light it from the side:
What do you guys think? Feel free to photoshop up your own suggestions
Old 25th Feb 2012, 07:02   #47
peteski
long live the pc
peteski's Avatar
i like it looks better than the liquid tape. what is that stuff anyway and is it safe
__________________
Old 25th Feb 2012, 07:15   #48
xXSebaSXx
Supermodder
xXSebaSXx's Avatar
xXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run Crysis
Liquid tape is safe; it is used for insulating electronic components. Think of it as a more flexible from of the black electrical tape you would normally buy in rolls. We use it quite often in the world of sub-zero benching for protection against condensation.
And I agree; a back plate would look 100 times better.
xXSebaSXx is offline   Reply With Quote
Old 25th Feb 2012, 07:57   #49
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
love this project!
Q. Linux workstation, and the mention of 20 hour CAD sessions... what app do you use? Ares, VariCAD or Catia V6?
Love to know, i switched to ubuntu a year ago for a native enviroment to run inkscape and gimp in but still require my windows box for solidworks which really ruins my productivity
__________________
Project log Mocha70
Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2
Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 25th Feb 2012, 08:43   #50
avolla
Hackintosher
avolla's Avatar
avolla has yet to learn the way of the Dremel
Love what you've done with this so far. I'm envious of your setup. The gpu waterblock does look out of place but it's not bad enough to really worry about. Can't wait to see how this build progresses.
BTW Can you get a straight on shot from overhead of the board? would love to see how the inlets line up.
avolla is offline   Reply With Quote
Old 28th Feb 2012, 00:09   #51
stren
Multimodder
Originally Posted by Burnout21 View Post
love this project!
Thanks - I do chip design, so the layout part of circuit design is similar to CAD, but only really 2D so very different to most traditional CAD tools.
Here you go:
Indeed - I got the idea from you subzero guys
The temporary parts came in to see if I could get some clean routing for the motherboard/ram/gpu loop:
However it didn't quite work as expected- I couldn't get the 40mm extensions to work with the 5 way rotary snake, however a SLI connector did fit.
Now I'm not sure whether to:
- get two more sli connectors (I need this one)
- use two compression fittings instead
- get two of the bitspower crystal sli links to match better
I should probably go with the cheapest as I'm hoping monsoon free's new design will solve the problem for me.
Old 28th Feb 2012, 05:35   #52
peteski
long live the pc
peteski's Avatar
man that looks tight good work mate
__________________
Old 28th Feb 2012, 07:05   #53
avolla
Hackintosher
avolla's Avatar
Thanks for the pic. It looks amazing. I'm sorry if i missed it but what are your plans for the cpu? Keep up the great work.
Old 28th Feb 2012, 08:36   #54
jakobfrimmel
Supermodder
jakobfrimmel's Avatar
jakobfrimmel has yet to learn the way of the Dremel
<3 the build!!!
execpt only one GPU?! with that mobo i was expecting atleast a couple more
but otherwise an amazing build !! keep up the good work!
__________________
Main rig:
CPU: Phenom II 955 @ 4ghz cooled with a H50
GPU: HD 5850 Powercolor (Bricked) awaiting new card to hold me out till August
Motherboard: Gigabyte 890xA-ud3
RAM: 4gb ddr3 1600 OCZ @1600
jakobfrimmel is offline   Reply With Quote
Old 28th Feb 2012, 15:01   #55
Bladesingerz
Supermodder
Bladesingerz's Avatar
Bladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the Dremel
Been following this for a while now, that looks watercooling looks amazing man, especially that last picture! Love the fitting from VRM to RAM block
On your question on the backplate, I would suggest you try to make one! It would look alot better. Couldn't you just get a backplate from EK btw?
Bladesingerz is offline   Reply With Quote
Old 28th Feb 2012, 15:25   #56
stren
Multimodder
The cpu will be on it's own loop with dual d5 strongs @ 24V and a mora 3 pro 140.9 radiator
Originally Posted by jakobfrimmel View Post
<3 the build!!!
Haha actually the full build has 5 gpu's. The half that I'm currently working on will have 2 8800gt's (workstation), the other half has 4 gtx480's (space heater/gaming)
Thanks dude - glad someone likes that fitting - most seem to hate it - let me know what you think of the alternative tubing option below. It looks like I'll have to make the backplate myself, EK doesn't have any on there store, and I can't find any on ebay, so I'll have to do something
Alternative tubing option - gets busy when you add lines for the cpu loop:
Old 28th Feb 2012, 16:48   #57
microsoftPerson
Hypermodder
microsoftPerson has yet to learn the way of the DremelmicrosoftPerson has yet to learn the way of the DremelmicrosoftPerson has yet to learn the way of the DremelmicrosoftPerson has yet to learn the way of the Dremel
Are you going to try any other pipe colors? I really like the way this looks but I almost think clear or a tinted clear would look better because you could see more of the board through the tubes?
Sorry - just my $.02.
Thanks for sharing your project with us, clearly lots of hard work involved.
__________________
ASUS P8P67 Pro - i5 2500k + 8GB Ripjaw X 1333MHZ DDR3
MSI GTX 560 TI Twin Frozr II + Crucial C300 64GB
Samsung F3 Spinpoint 1/2 TB + Fractal Design Define R3 [black pearl]
microsoftPerson is offline   Reply With Quote
Old 28th Feb 2012, 18:33   #58
The Alfred
What's a Dremel?
The Alfred has yet to learn the way of the Dremel
I think with water cooling the less pipes the better, it'd look so awesome with just fittings!
The Alfred is offline   Reply With Quote
Old 28th Feb 2012, 18:37   #59
Bladesingerz
Supermodder
I liked the other tubing layout better, maybe use some acryl piping? Some straight lines will make this look amazing.
On the previeus picture you used some SLI connector going from the VRM to RAM block? If you continue somewhere allong those lines it would so badass!
What GPU is that btw? That doesn't look like a GTX480?
Old 28th Feb 2012, 21:04   #60
stren
Multimodder
I wanted the red to provide a pop of color, with the case colors I didn't want people to think I was going another monochrome murderbox copy type thing.
Yeah I agree - just hard to get the right fittings to work. The extender would have been sweet but the rotaries were just too stiff in the wrong places.
The GPU is an 8800GT. This 3930K + rampage iv extreme combo is for the workstation side - the gaming side is a rampage iii extreme + 990x + 3x GTX 480
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
