Reply
Thread Tools View Mode
Old 16th Mar 2012, 19:57   #101
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Looks good, really - it does!
However, I'm waiting for when you're going to explain what you need so much room for. So far, I've only seen one small mobo and a watercooling loop... ok ok, it's got 24 fans, so that's kinda crazy, but still... what's more in store for us?
Oh, and on a sidenote: You got all those nice nickel-plated fittings and watercooling blocks, and still you go with a copper block for the GPU? I don't get it?
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 16th Mar 2012, 20:11   #102
stren
Multimodder
stren has yet to learn the way of the Dremel
See this post for the gaming rig that will be transplanted in addition:
http://forums.bit-tech.net/showpost....73&postcount=8
As for the nickel blocks - No one in the US has EK nickel 8800gt blocks. I've been looking for a while. I'm planning on getting those copper blocks nickel plated by a local shop along with the custom waterblocks I'll make So don't worry everything will match, but it's a long road to travel yet
stren is offline   Reply With Quote
Old 16th Mar 2012, 21:53   #103
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
starting to look real sweet now mate keep up the good work
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 21st Mar 2012, 22:45   #104
stren
Multimodder
Thanks dude!
Here's a pic of the iwaki next to a D5
Then I put the dvd drives in. These will eventually be hidden
Then I starting putting in the new ssds into the hdd side mount:
I have another 3 ssds and 5 hard drives to put in later on, when I really transplant everything over:
And now a tease of the case with the panels:
More to come soon
Old 21st Mar 2012, 22:52   #105
Nutman
Nutman's Avatar
Dear God, it's a fortress!
__________________
Old 21st Mar 2012, 23:02   #106
xXSebaSXx
Supermodder
xXSebaSXx's Avatar
xXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run Crysis
LOL... stren could probably rent out the unused space in that case to a friend of his as a studio apartment.
And I thought that the case I'm designing was big when I measured it and it tipped 600mm in height...
xXSebaSXx is offline   Reply With Quote
Old 23rd Mar 2012, 07:55   #107
Overminde
Multimodder
Overminde's Avatar
Overminde has yet to learn the way of the Dremel
wow that pump is sick
Overminde is offline   Reply With Quote
Old 23rd Mar 2012, 16:22   #108
wilkinson001
What's a Dremel?
wilkinson001 has yet to learn the way of the Dremel
You could probably use the case as a cupboard as well as a case for 2pc's. Its humongous. :O
wilkinson001 is offline   Reply With Quote
Old 27th Mar 2012, 17:43   #109
stren
Multimodder
Lol, this way no one can steal your computer
Haha yeah this case is pretty insane, the wife is not a fan.
Yeah I can't wait to test it and see how high the flow is. I'm a little worried about breaking the gpu blocks with it.
Yeah we are short on closets, maybe I can add some hanging space haha.
Old 27th Mar 2012, 17:44   #110
stren
Multimodder
So the only thing I got done this week was changing the switch plate to one that matched the exterior color. Here's the original:
The cover is held on with two nuts:
Put the new one on:
Reattach the switches:
Install it:
And put the panels back one:
That's probably it for the next week at which point a large order of parts should be coming in
Old 27th Mar 2012, 17:48   #111
Nutman
Nutman's Avatar
Love the 2x5 stack o' fans in there. Somehow, they're very befitting of the case.
__________________
Old 27th Mar 2012, 18:52   #112
stren
Multimodder
Haha yeah - this is one of the few cases that can act as a storage cupboard for the build parts before assembly haha.
Old 27th Mar 2012, 20:17   #113
Nutman
Nutman's Avatar
Or even act as storage for lesser builds after completion!
__________________
Old 3rd Apr 2012, 22:03   #114
stren
Multimodder
Alrighty the fedex guy came, so here's some unboxing action:
Woooh packing
Opened some boxes - the front rad is an ex560 - not quite sure why this was the first 560 rad that XSPC made.
Mora 140.9 revealed - way thicker than the EX of course
Can you say quick disconnects?
Old 3rd Apr 2012, 22:21   #115
Nutman
Nutman's Avatar
You could use those radiators to heat up your house.
But then again, the case is going to BE your house, right?
__________________
Old 3rd Apr 2012, 23:15   #116
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
Why not add more than one loop , Add loads , with the amount of space you got in there , =)
SilveR_172 is offline   Reply With Quote
Old 3rd Apr 2012, 23:51   #117
stren
Multimodder
Already have 4 loops
Old 4th Apr 2012, 04:48   #118
stren
Multimodder
2nd update of the day:-
So I played around with my own version of the big slappy mod for the Iwaki - the idea is you tap the cylinder res for a much larger feed for the pump. The pump can't be on it's back so you need a nice slow 90 degree bend. The tough part is then getting down to the 5/8 OD pipe that is the inlet to the Iwaki. Here I used 1" pipe going to a 1/2" female converter fitted with a 5/8" brass barb. I butted the barb up right against the inlet and stretched some 0.5" tube over it:
The feed may not be quite as good as the original big slappy as that only had a bout 3/4" of 5/8 inlet tube, vs this 2.5" on this version. However the downpipe is 1" instead of the 3/4" that was used. So hopefully the extra width balances it out a bit. Here's a photo of the original big slappy:
and amuseme's version:
We'll see I might change to what they did, I feel like it might have better performance.
Also started spray painting test colors on a dead GT. I made a quick spray booth:
Done - there's some metallic flake in the paint, the color isn't quite as orange as the tube though:
Reassembled (kinda)
Then a final comparison with it mounted on the 120 rad (this rad is just for the motherboard block loop). The rad will be painted silver to match:
So what do you think? Are the colors close enough? Both are slightly off. I wonder if I can get a color match from the powder coat supplier. I think I'll look for a different red at the least tomorrow. The match does depend on the lighting though.
Old 4th Apr 2012, 05:38   #119
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
Lighting and each of our own monitors may not show what your real color is. Most powdercoaters have the ability to match their colors to yours, just like paint people need a small sample and they canmake gallons to match. Computer imaging.
This is really looking good.
john
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 4th Apr 2012, 11:24   #120
peteski
long live the pc
peteski's Avatar
looking good mate rep to you
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
