Reply
Thread Tools View Mode
Old 6th Jan 2012, 00:10   #41
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
Originally Posted by l3p View Post
The worlds fastest modder! Love your work Richard!
I would rather say like this:
-I hate you Richard !
I had the exactly same idea for the top and the bottom chamber(almost) but with an tripple rad-guard instead ;D
Keep on the good work mate and good luck !
KoSoVaR^ is offline   Reply With Quote
Old 10th Jan 2012, 09:36   #42
JdotH
What's a Dremel?
JdotH has yet to learn the way of the Dremel
Kier, I am very pleased to see your efforts.
Are you going to do a window?
Seeing as there isnt one, and most people want to actually see their nifty/expensive stuff inside, you should do an uber window.
Like maybe a window that is double paned so that the liquid cooling can go through it....and in the window you could have your sponsors or some feature for the liquid to pass around/over....oh and quick disconnects so the door can still be removed.
Either way...I am thrilled to see you hadeling this case.
Cheers.
JdotH is offline   Reply With Quote
Old 10th Jan 2012, 14:57   #43
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
Subbed!!
Based on your previous work this is going to be an amazing mod!
Looking at this case more and more and thinking of getting one myself as it look's like it could, hold a Quad 120mm rad at the top and 1 in the bottom with a Dual 120mm rad as well.
Still trying to decide what case to use for my next build, but it need's plenty of space for all the rad's I want.
Anyway will be keeping an eye on this.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 17th Jan 2012, 22:33   #44
kier
kier's Avatar
kier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for president
Update: The front
These last few days i've continued with the appearance of the case. I want the front to turn black / white. So I have sawn a piece 3mm black acrylic, the same pattern as the white plate. Only now with the recesses 5mm smaller.
White plate on it
I like the looks of it. Also have now some great air in/ outlets, finishing of this part later
I previously mentioned that the controller is coming in the upper 5.25 compartment togheter with the I/O stuff, all of this in the black and white theme
So marked a 5mm white acrylic piece
To keep everything in place there is coming a piece of black acrylic behind it with recesses for the controller and I/O stuff
Witch is placed like this
To get a nice contrast around the controller, I've cut and filed a edge of 3mm black acrylic
And also made two black strips cut for the I/O stuff
And placed in the Cosmos
For the lower I/O section cut rectangles and circles for the USB and audio
And after some carefully filing
Top I / O section also done, and put everything in it for the looks
Above the Cosmos controller is still a big white surface, this seems to me a nice place to put a display.
For this the perfect display: The Aquaero 5 XT. So ordered and received
Hmm that's a unpleasant surprise, the controller with touch buttons isn't black anymore (like the older version) but Aqua Computer has replaced / filled this with stainless steel buttons.
Itself is looking very nice with the new buttons... but not for this build. So first i'm going to try to get an "older" version. Until I know more I will stop working out the display.
That's it my modding friends
__________________
kier is offline   Reply With Quote
Old 18th Jan 2012, 03:34   #45
dmcgrath
Master of Pancakes
dmcgrath's Avatar
dmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremel
Ah wow, I love the treatment you did on the front there. I'm still mulling around where all my connectors are going to go back into my mod. This is noteworthy
dmcgrath is offline   Reply With Quote
Old 18th Jan 2012, 05:28   #46
dark4181
Ero-sennin-tebayo
dark4181's Avatar
dark4181 has yet to learn the way of the Dremel
Wow.. just.. wow O.O
__________________
New X99 build in progress!
Intel Xeon w3250 (cooled by Titan Fenrir 'Special'), EVGA Classified e760, XFX Radeon HD 5870, Corsair Dominator 3x2gb, OCZ Vertex 120gb, Silverstone Strider 1kw Plus, Silverstone Fortress 2
Heatware: dark4181
dark4181 is offline   Reply With Quote
Old 18th Jan 2012, 09:02   #47
Sarakon
The German
Sarakon's Avatar
Sarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming Saiyan
That front is really awesome, suits the case really well
__________________
Corsair 650D| Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Crucial BX100 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC
Sound Blaster Z | Cooler Master 850W Silent Pro M
Sarakon is offline   Reply With Quote
Old 18th Jan 2012, 11:16   #48
weatherdown
What's this button fo......
weatherdown's Avatar
weatherdown has yet to learn the way of the Dremel
love the contrast look
__________________
EVGA X58 4 Way SLI Classified Mainboard | Intel® Core™ i7 975 @ 3.8GHz | Corsair Cooling Hydro Series H50 | Corsair CMD 12GB DDR3 1600MHz | DUAL NVIDIA GeForce GTX 275 896 MB GDDR3 SLi'd | (2) WD 300GB VelociRaptor SATA III | WD 2TB SATA II | WD 3TB SATA III
weatherdown is offline   Reply With Quote
Old 18th Jan 2012, 16:10   #49
kier
kier's Avatar
Update
Just a small update about the cover at the right bottom.
First idea was to make this cover with a angle just like the other side, but a change of plans.
This is now becoming a straight cover, but with 2 HDD attached to it. The place for the HDD's was a bit limited because I removed the HDD cages and almost all the space is occupied by the water cooling products
So this is a nice solution. There will also be a SSD, but this is placed on the side of the 5.25 bay
For the cover I sawn a piece aluminum and marked it
Bent it
Cut out the Fanholes again
And drilled the holes for the HDDs. Of course I will make some adjustments for noise reduction
All placed like this
Also made the recess for the cables
__________________
Old 18th Jan 2012, 16:12   #50
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan
Looking good Kier!
__________________
ZiiP Gaming Community
Sui Generis: i7 5820K, Corsair H105, 16GB Kingston 2133, ASUS X99-S, Samsung 950 Pro 512GB M2, Samsung 850 1TB EVO, Corsair F3 120GB SSD & Samsung EVO 250GB SSD, MSI GTX 970, Corsair HX850W, Corsair Obsidian 800D, AOC 34", Logitech G15, Shogun Bros Ballista Mk-1, Corsair 1500.
[ZiiP] NaloaC is offline   Reply With Quote
Old 18th Jan 2012, 18:49   #51
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
looking very nice =)
i want to get sponsored by cooler master for a Cosmos 2 Got loads of ideas floating around !
SilveR_172 is offline   Reply With Quote
Old 18th Jan 2012, 20:45   #52
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
So there's enough space in the bottom chamber to mount drives vertically? -friggen HUGE, man! Brilliant placement, BTW.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 19th Jan 2012, 05:17   #53
r1sKas
Orange or White? Lets mod!
r1sKas's Avatar
r1sKas is a Super Spamming Saiyanr1sKas is a Super Spamming Saiyanr1sKas is a Super Spamming Saiyanr1sKas is a Super Spamming Saiyanr1sKas is a Super Spamming Saiyanr1sKas is a Super Spamming Saiyanr1sKas is a Super Spamming Saiyanr1sKas is a Super Spamming Saiyanr1sKas is a Super Spamming Saiyanr1sKas is a Super Spamming Saiyanr1sKas is a Super Spamming Saiyan
Your just:
**** YEA xD
Great job, will follow it for sure
r1sKas is offline   Reply With Quote
Old 19th Jan 2012, 22:51   #54
kier
kier's Avatar
Just a small addition
I've covered the two plates with black vinyl, which gives the same black color as the rest of the case
And placed them
Pics with the white front
__________________
Old 19th Jan 2012, 23:05   #55
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Good job. Now,please MOAR.
Pranja is offline   Reply With Quote
Old 4th Feb 2012, 00:34   #56
Nutman
Never stuck with stock
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
That looks OSM!
Subbed without a doubt.
__________________
Best regards, Nutman
Projects: Nutman - Hampen - F.O.B. T.C. - BabyShark - The Scratchbench
Nutman is offline   Reply With Quote
Old 4th Feb 2012, 20:55   #57
renrenderla
What's a Dremel?
renrenderla has yet to learn the way of the Dremel
Looking Good! More updates please!
renrenderla is offline   Reply With Quote
Old 5th Feb 2012, 21:16   #58
kier
kier's Avatar
Update!!!
I would like to welcome a great sponsor for this build, the shop that has everything .... IT-Service.be
IT- service/ Eddy Thanks for the nice discounts.
For this build I purchased a nice new mobo: The Asus SABERTOOTH X79
Really a great motherboard, here some pics:
Some standard stuff
And the motherboard
Placed right away in the cosmos
So the Sabertooth, really is a beautiful mobo
I also bought some beautiful rams to fill up the sabertooth, 3 x the Corsair 4 GB DDR3-1600 Kit
I will place EK ram coolers on these.
En last but not least, the white Xigmatek XOF-F1251 fans, which fit perfectly with this build
Placed on top
360 rad fits
In the last update I had shown you the white midplate, Ive adjusted it a bit for 2 pumps
Which will be placed like this
Received approval from my great friend
And also cut a white acrylic plate for the mobo tray
Beneath and beside the motherboard I have a lot of space, this will be filled up
I would like the same line as the EK tops, and I want a nice light distribution in terms of the illuminated midplate. For this I am going to raise the midplate about 4 cm, for this I have sawn and bent an aluminum strip cut
Behind it I placed 2 CFL lights, and we have an illuminated midplate
For an even better light distribution I will do some adjustments, but more on this later.
I've made a bracket for the rad
I still need to make the top bracket but this I will do later
Enough room for the fittings
And here the radiator with fans
Applied a layer vinyl coating to the strip
Looking good I think
Grtzzz
__________________
Old 5th Feb 2012, 21:22   #59
dark4181
Ero-sennin-tebayo
dark4181's Avatar
Holy crap O.O
__________________
Heatware: dark4181
Old 5th Feb 2012, 21:26   #60
r1sKas
r1sKas's Avatar
Love your fans m8!
Keep going your good work ;D
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
