#62 |
What's a Dremel?
Lovin the vent design on top
#63 |
Professional Sleever & Modder
it looks very good
, cant whait for more updates
#64 |
Never stuck with stock@Hotmods.net
Kier, this looks awesome.
As you know I'm quite keen on getting details on how you did that luminous panel for the floor - and I'm not that much wiser after having read this update. Which is why I created this thread tonight: http://forums.bit-tech.net/showthrea...28#post2958528 Hopefully, I'll get some answers that I can use
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#65 |
Mad FPS Gamer
Looking excellent up to now mate.
Loved the last mod and this is looking like it's going to be better. Keep up the excellent work.
__________________
Core I7 3930K, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 680 SLI, Corsair Force 3 250Gb SSD, Creative Sound Blaster X-Fi Titanium, NZXT Switch 810, XSPC RX 360mm + Alphacool 240mm All Copper, 10x Scythe Kazi Jyuni 1900rpm 5v & And It's Silent!!!!!!!!! . Market Place Feedback http://forums.bit-tech.net/showpost....&postcount=104 |
#66 | |||
Modding and coffee
I''m also very pleased with the fans, think this was a good choise ![]() Quote:
Thanks This week the EK products should be coming in...so more updates coming up Quote:
![]() Quote:
#67 |
Minimodder
For the cover I sawn a piece aluminum and marked it
![]() Bent it ![]() Cut out the Fanholes again ![]() Hi do you have a template for the fan cut out. Tony |
#68 |
Sweet! Can't wait.
__________________
#69 |
Making You Feel Old Since 2010
Why, and how did I miss this!? Great work!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#70 | |
Modding and coffee
It,s not to difficult: put white sheet on the bottom from the original midplate and lifted the acrylic 4cm up, but i will show some pics
#71 |
Modding and coffee
Sponsor Update !!!
![]() Hi fellow modders. It took a while since the last update, but today I have received a lot of watercooling products ![]() What would it be... a lot of boxes ![]() ![]() ![]() To begin EK-PSC Fitting 10mm - G1/4 Black ![]() ![]() Also the EK-PSC Adapter 45° G1/4 Black ![]() ![]() and some beautiful EK-PSC Adapter 90° G1/4 Black ![]() ![]() A great CPU block: the EK-Supreme HF - EN ![]() ![]() ![]() and two EK-RAM Dominator X4 ![]() ![]() ![]() For the 2x ZOTAC GTX580 gpu's iv'e got 2x a EK-FC580 GTX+ - EN ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Also with two EK-FC580 GTX Backplate - Black ![]() ![]() ![]() 2 great tops with res: the EK-DDC X-RES 140 - Acetal ![]() ![]() ![]() ![]() To cool everything I ordered 2x EK-CoolStream RAD XT (240) ![]() ![]() ![]() ![]() For the top of the Cosmos I''m gonna place a EK-CoolStream RAD XT (360) ![]() ![]() ![]() ![]() And for the sabertooth board iv'e picked the EK-MOSFET ASUS X79 ![]() ![]() ![]() Another great sponsor for this build is...... ZOTAC ![]() For this build I may use 2 x the ZOTAC GTX580 1536M 348BIT DDR5 ![]() ![]() ![]() ![]() Some specs: Specs: Chipset : -Chipset Manufacturer NVIDIA® -GPU GeForce® GTX 580 -Core clock 772 MHz -Stream Processors 512 -Shader Clock 1544 MHz Memory : -Memory Clock 4008 MHz -Memory Size 1536MB -Memory Interface 384-bit -Memory Type GDDR5 ![]() ![]() ![]() ![]() ![]() Chris, Craig and Carsten Thank you again for these great cards It's ashame that I need to undress the cards, but it needs to be done ![]() ![]() ![]() And placed the EK-FC580 blocks ![]() ![]() ![]() ![]() Placed the backplates ![]() ![]() ![]() That's it, tomorrow more about the other blocks |
#72 |
Ooooook. I just wet myself.....
__________________
#73 |
The modding head is firmly back on.
Nice kit, going to be awesome. I use the EK coolstream rads myself and they are excellent.
#74 | |
Modding and coffee
Be sure to do a leaktest before using
![]() Quote:
#75 |
The German
![]() Its so pretty!
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M |
#76 |
Orange or White? Lets mod!
Those GPUS will rock so hard =P
Regards |
#77 |
What's a Dremel?
exellent parts, excellent project
#78 |
Modding and coffee
#79 |
Pump Killer
That's some motherf***ing BLING you got going there!
Well deserved man!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#80 |
Modding and coffee
Thanks Angel
I must admid....I wet myself after installing the blocks
| Thread Tools | |
| View Mode | |
