#121 |
Modding and coffee
Thanks y'all
#122 |
Modder
Looking sweet
#123 |
Dremel?
Thats one sweet case, if prices come down, I'm snapping one up!
Builds looking good mate! |
#124 |
Modding and coffee
#125 |
Supermodder
Would have gone with black in the 2nd loop , But thats all good project , Like it alot , you got it all up and running now ?
benchmarks ? :P |
#126 |
Never stuck with stock@Hotmods.net
Wonderful, wonderful.
What tube is that? EDIT: Nevermind... found the answer by actually READING the worklog. What gives??? How does it hold up when the fluid heats up? You make some pretty tight bends in some of your builds. Ever had it kink up on you when the fluid gets hotter?
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks Last edited by Nutman; 1st May 2012 at 22:20. |
#127 | ||
Modding and coffee
#128 |
Modding and coffee
![]() ![]() ![]() Tonight I spent some time to the front. I changed the plan to put the usb and other stuff into the front regarding the looks and the space behind the panel. ![]() I think this looks better now without the, usb stuff and without the touch buttons from the Aquaero. These doesn't look good and do not work properly in my opinion So i've cut 3 pieces of 3mm acrylic. The first one looks like this ![]() And two of them like this. One of them with a smaller recess for the display ![]() Everything put together ![]() The touch buttons I do not need because I can set everything with the remote control. And once set I usually do nothing more with it, just look at the temps. The remote has a good range like this, so it's okay ![]() Placed in the Cosmos ![]() ![]() ![]() Power on ![]() ![]() I doubt whether I'm going to put black or carbon on the acrylic. |
#129 |
Multimodder
Absolutely beautiful. You are a true modding genius.
__________________
Intel i5 3570K - ASUS Maximus V Gene - ASUS GTX 560 Ti DCII TOP - Patriot Viper Xtreme 8GB RAM - OCZ ZT 750W Power Supply - OCZ Vertex 4 128GB SSD - Gelid Tranquillo |
#130 |
Modding and coffee
Thanks m8
#131 |
No disassemble!
Lovely build. Your cable management is stunning.
I too was wondering about the tight bends in the tubing - which looks great BTW. Have you had any experience with Tygon laboratory grade tubing?
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|240 UT60 |
#132 |
I unsuccessfully then tried again
So crisp! I love the individual holes for the cable management, just so over the top
__________________
Mac:Macbook Pro 7,1 w/Samsung 830 256GB, ML xbmc:Windows 8 x64, Fractal Design Node 304, MSI Z77IA-E53, G2120 fanless, 2x2GB, 3TB, Samsung 830 256GB dazzypops:Win8Prox64, i5-2500k@4.3, MSI Z77A-GD65, 8GB, 4TB, Samsung 840 Pro 256GB, 2 x MSI GTX660 (+110core, +535mem), LG IPS 24", Z5400 5.1 |
#133 |
Multimodder
kier - a quick question mate, how do you keep all the cables parallel without any zip ties or anything?? my cables always seem to do there own things.
cheers |
#134 | |||
Modding and coffee
Feser, Masterkleer and Tygon for testing the curves. Feser was the one with the most stiffness Quote:
![]() Quote:
Do you mean the Sata, GPU or 24pins cable? The Sata is done with zip ties behind the mobo tray, the gpu and 24pins are holding the parallel position because the individual holes. Straight lines from hole to connector. |
#135 |
Modding and coffee
![]() ![]() ![]() The wurst thing happened to me .... lost the flat cable connecting the PCB push button and the controller. In the beginning I was thinking that I must put the flatcable somewhere save before I lose it. So I've lost it . Fortunately there was Ruud from Coolermaster, who still has parts of the CosmosCooler Master Europe Store for all your spare parts. Ruud... thanks man! ![]() ![]() And everything is online again ![]() ![]() ![]() Inverse color display is a nice thing ![]() slide panel closed again, nothing to see anymore ![]() Cable management is still a big mess, but this is how I placed the controller ![]() ![]() ![]() This will become more organised ![]() Drilled a hole for the switches and HDD LED ![]() And I have cut a 3mm black piece of acrylic to make a cover for the side bay, I don't like holes and slots So this will disappear.![]() Made a second layer and cut out the form of the CM push buttons. ![]() Placed the first layer back ![]() Second layer on top ![]() Past some black film on the second layer ![]() And the result ![]() Nice, tight and the good color. I also been busy with the XL window for the Cosmos. What appeared to be quite a challenge because lots of plastic and little space The acrylic window I've made 1cm larger as the existing hole. ![]() ![]() ![]() ![]() ![]() Need to put more pressure on the edges , but this is how it becomes For pasting the metal cover back on the plastic, I used contact adhesive. This is because I don't have to much space for double sided tape, and it just needs to be good. Placed everywhere clamps and other stuff, which will stay on for a night. And need to make the inside a bit nicer. Ofcourse after installing the window wanted to see how it looks. ![]() ![]() ![]() And also have been playing with the enlightened midplate for some nightshots. I'm also thinking to put some lights in the midsection or top. ![]() ![]() ![]() ![]() ![]() That's it for now...Grtz. |
#136 |
+1 rep for using the word "wurst"!!!
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#137 |
The Keeper of History
+rep
john
__________________
My deepest gratitude to this community.
#138 |
Minimodder
So clean, looks fantastic.
#139 |
Modding and coffee
Thanks for the repThanks John Have change the front a little bit. The made the white acrylic black. Hope you like it ![]()
#140 |
Multimodder
Wonderful build this is looking just great
__________________
Urban Camouflage
| Thread Tools | |
| View Mode | |
