Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 3rd Jan 2012, 18:14   #1
dramatik
Multimodder
dramatik's Avatar
dramatik has yet to learn the way of the Dremel
Xonar DS or Xonar DX/D1
Hey guys, was wondering what would be better suited for my needs. My speakers are Logitech Z506 and I won't be upgrading these for a while (5-6 months). Onboard sound currently being used is Realtek's ALC889. Main use will be for movies, games and music. I have no care for headphone benefits whatsoever. Just not sure if the price for the DX is worth it over the DS. Brand new I can get a DS for £35 whilst the DX is pushing the £58 barrier. My budget till next month is £40 so should I wait and get the DX or will the DS suffice till I get better speakers?
I have also found a D1 on ebay for £35, and I do have 2 PCI slots on my motherboard so this is an option, but I'm always cautious about buying second hand PC parts from Ebay. Do I have any kind of warranty, should the item be DOA or die within 3-4 months? Lastly, I've seen the Xonar DG but everyone who has been advised to purchase it have been people who want the headphone amp, which I have no care for. That £18 would be nice on the wallet though lol
Cheers
__________________
Cooler Master HAF 922 | i7 950 @ 4Ghz (1.25v) | Gigabyte X58 UD3R Rev 2.0 | Corsair XMS3 DDR3 1600mhz 3x2 | Sapphire 6950 2GB (1.195v - 930 Core - 1375 Memory) | Prolimatech Megahalems With Gentle Typhoons x2 (1850rpm) | Corsair 750W HX Modular PSU | Samsung F3 1TB | Western Digital 500GB Green Power |
dramatik is offline   Reply With Quote
Old 3rd Jan 2012, 18:29   #2
MSHunter
I *am* a Dremel
MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!
As far as I know the DX is "just" the DS on PCI Express.
Here is the info links:
http://www.asus.com/Multimedia/Audio_Cards/Xonar_DS/
http://www.asus.com/Multimedia/Audio_Cards/Xonar_DX/
__________________
PC: Silverstone TJ08B-E, 2500K, Corsair H80, 120GBVertex 3 MAX IOPS,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711
PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X
Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1
MSHunter is offline   Reply With Quote
Old 3rd Jan 2012, 20:36   #3
dramatik
Multimodder
dramatik's Avatar
The DX has higher quality components as far as I'm aware, it also has a better signal to noise ratio. Just not sure if it's needed for my setup
__________________
Old 3rd Jan 2012, 20:46   #4
MSHunter
I *am* a Dremel
Unless you connect to a good HiFi you will not hear a difference.
__________________
Old 3rd Jan 2012, 21:55   #5
dramatik
Multimodder
dramatik's Avatar
So would your recommendation be that I stick with the onboard till I upgrade my speakers?
__________________
Old 3rd Jan 2012, 22:29   #6
BennieboyUK
CPC Folder of the Month Sep 2011
BennieboyUK's Avatar
BennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for president
Do you use Headset?
If you have a decent heatset a Xonar will make a huge difference.
__________________
i7 980x @ 4.4Ghz|12GB Dominator GT 2133mhz|Rampage III|4gb GTX 680 Classified's SLI|830 256GB|Antec 1200w|PF1000|R3|U2711 Hyper-V 2012: Dell 1900 | Dual Xeon E5320 | 32GB DDR2 ECC | LSI @ Raid5 5.452tb WHS: 8gb HP N40L 10tb x8 WD 2tb RED's Raid 6+1 on SRCSASBB8I with BBU
BennieboyUK is offline   Reply With Quote
Old 3rd Jan 2012, 22:43   #7
dramatik
Multimodder
dramatik's Avatar
Nah I NEVER use a headset, strictly 5.1 with my logitechs
__________________
Old 4th Jan 2012, 03:20   #8
MSHunter
I *am* a Dremel
No I meant you will not hear the diff. between the Different models of Xonar.
__________________
Old 4th Jan 2012, 03:27   #9
Malvolio
Keep calm and canter on.
Malvolio's Avatar
Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.
Even with poor quality speakers you should hear a marked difference in quality between onboard and discrete, to what degree that difference will be depends upon the rest of your audio kit (most notably will be background hiss and general interference). To be perfectly honest I'm quite happy with my DG hooked up to a Sony micro hifi with a set of Kenwood (I think) monitors for my everyday usage with a solid 4 speaker surround system (Pioneer receiver, Nuance speakers) in my home theatre for films and such run off the same card, so I think either card you get will work excellently. For the price the Xonar series is very hard to beat, if you're looking for a card that can work with games that is. Audiophiles tend to look elsewhere (from what I've read, anyway).
But as with any piece of audio equipment: nobody can tell you what will sound best to your ears, so give it a try for a few days before you make your mind up (most retailers have excellent return policies, after all).
Edit: though I do feel as though I may have sidestepped your initial question a bit... So if I were to chose between the DS or DX I would just go for whichever option best worked with my system and wallet! For the simple fact that I am running CF I'd opt for the PCI-E option, as I've an open 1x port just above my first video card, rather than the PCI slot below my second, which chokes it's intake slightly (my second card runs a few degrees hotter than my first due to this). From the reviews I've read there isn't much of anything between them, making the price difference one primarily of convenience.
__________________
MC and Ellie FIX it!
It's a comic I do. With dolls.
Occasionally it's funny.
Malvolio is offline   Reply With Quote
Old 4th Jan 2012, 04:42   #10
dramatik
Multimodder
dramatik's Avatar
@MShunter - My dreams were nearly shattered when I thought you meant I wouldn't hear a difference between the Xonar's and the onboard lol.
@Malvolio - Luckily I'm running the one HD6950 so I can go for a PCI or PCI-E card. I guess the next question now would be, should I opt for the brand new DS at £35 or the secondhand D1 (Basically the DX with PCI instead of PCI-E) for £38
__________________
Old 4th Jan 2012, 20:34   #11
dramatik
Multimodder
dramatik's Avatar
Bumpity Bump
__________________
Old 4th Jan 2012, 20:51   #12
pete*
Still a PC n00b after 3yrs.
pete*'s Avatar
pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.
Get the DS or DX. Forget about the e-bay second hand if you're worried about warranty and
the like.
Personally i'd go for the DX because I have a PCI-E slot free. But it is totally up to you. The diff.
in sound between the two (as others have said) would, I expect, be neglible. And also, as others
have said, the DX has newer parts/better specs. But real-world difference I don't think there
is much. If you don't mind waiting. Wait and get the DX. Thats my opinion anyway.
You won't need to upgrade it when/if you upgrade your speakers.
Not that you would need to upgrade the DS either though.
__________________
| Add a noob.. BF3: sl1ps or 1.6/DODS Steam: Pete |
| Intel i7 3770K | ASUS Maximus V Gene | 16GB Corsair Vengeance | GTX580 1.5 |
| Samsung 830 256GB | 3x 1TB F1, 1TB F3, 2TB F4, 2TB Ext. WD | Silverstone PS07-W | Corsair AX850 | BenQ XL2420T / Dell U2410 Monitors |
pete* is offline   Reply With Quote
Old 4th Jan 2012, 20:53   #13
OYUNCAK
What's a Dremel?
OYUNCAK has yet to learn the way of the Dremel
the like
OYUNCAK is offline   Reply With Quote
Old 4th Jan 2012, 21:23   #14
dramatik
Multimodder
dramatik's Avatar
hmm I'll probably wait and splurge on the DX then, thinking of the D1 as well though since I would like to have my second PCI-E slot free in the future to crossfire.
__________________
Reply
Tags
ds, logitech, sound, xonar, z506
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
