#61 | ||
Supermodder
![]() Quote:
#62 |
↓ Don't trust that face!
It's always neat to see a pro welder's work. Have you thought about welding a stainless steel reservoir instead of using stock WC gear? -It could be awesome.
__________________
#63 |
Supermodder
Thanks mate and i already weld a couple of custom stainless steel reservoirs.Here is one of them.
![]() ![]() ![]() Im gonna think about it to use 2 of them in this project.
#64 |
Keep calm & mod on. =)
Damn those look awesome. ![]()
#65 |
Hackintosher
Absolutely love what you're doing with this. I'd kill to have your welding skills. It is a shame to sand them down.
#66 |
Supermodder
#67 |
The modding head is firmly back on.
Oh yeah!!! Another epic desk mod by the looks of it. Looking forward to this one.. Looking really neat and tidy .
#68 |
Squid
Fantastic Paslis!!!
__________________
Revelation (in progress) R-KAID-Я (on hold) / The Shrine / REDELUX / 4M / R-kaid-6 http://www.facebook.com/enannanvision |
#69 |
Supermodder
Update 4. 12 Feb 2012
This weekend i made some progress.I started to work on the frame for the cables etc. M5 thread rivets ( dont know the english word ) ![]() The pneumatic tool. ![]() I made a short movie how this tool works. http://www.youtube.com/watch?v=EVyycuAtFKM Finisht the frame. ![]() ![]() After that i made the mounting plate for the frame out of 3mm aluminium and bend it. ![]() ![]() Then i drilled and countersunk the holes and mounted the plate on to the frame. ![]() After that i drilled and countersunk the holes inside the desk body and mounted the frame on the desk body. ![]() ![]() ![]() Now thats finisht i can start to make the bracket for the lifting column.For this i used 3mm aluminium. First some cutting. ![]() Then i drilled and countersunk the mounting holes. ![]() ![]() ![]() ![]() ![]() Time to mount the bracket on the frame and mount the column on the bracket. ![]() ![]() ![]() ![]() ![]() ![]() Now its time to test the column.I'm very happy with the result.Ofcourse i made a small movie while testing the column. http://www.youtube.com/watch?v=XuQd1qhDOtk This was it for today.
#70 |
Supermodder
#71 |
long live the pc
Paslis again you amaze me with your skill. you must have a good boss aswell to let you use your work place at the weekends. keep up the good work mate
![]() P.S +rep and 5 stars
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl, ![]() Last edited by peteski; 12th Feb 2012 at 13:23. |
#72 |
Supermodder
Thanks peteski and your right about my boss he gave me a key to the shop so i can use it whenever i want.
![]() Thanks for the rep and stars. Last edited by Paslis; 12th Feb 2012 at 15:33. |
#74 |
Supermodder
Thanks craig and yes that will go easily as it can handle 800N.And your right the controller is for both leg and panels.
#75 |
Hypermodder
Verry nice paslis!!
![]() Hihi !![]() gogogo
#76 |
Nut rivets are great, I need to practice more at it on countersunk ones, can do flanged ones no problem but countersunk ones went in awful for me with a manual tool, looks like the air tool does it nicely.
#77 |
Professional Sleever & Modder
Make me one too , pleasee!
this is just fantastic, i think that you should use a lot of coppar details into this build, bitspower has some awsome copper oldtime looky fittings |
#78 | ||
Supermodder
Thanks mate and yes you got my custom welded reservoirs.
![]() Quote:
If you can get hold of a air tool use it mate it works like a charm.![]() Quote:
I will look at the bitspower fittings for sure.
#79 | |
#80 | |
I think that alphacool has a lot of copper fittings, tube reservoars etc aswell check them out aswell, they have started to really use copper more and more on thier products now |
| Thread Tools | |
| View Mode | |
