#121 |
Tremendously Difficult Lifestyle
Damn I wish I had access to a workshop like that .... err well maybe not it'd be wasted on me , great skills mate
__________________
Finished Project : D33P THOUGHT Finished Project : THING Current Project : Mini Moto Mayhem |
#122 | ||||
Supermodder
![]() Thanks AnG3L. ![]() Thanks waynio. ![]() Quote:
![]() Quote:
![]() Thanks mate. ![]() Quote:
![]() Thanks Selfmindles.
#123 |
Supermodder
#124 |
Supermodder
Update 7 - 11 March 2012
Last week i received a very nice package from Noiseblocker with the multiframe casefans for my desk.Noiseblocker sponsord me with a huge discount. ![]() The package with the multiframe casefans. ![]() ![]() ![]() ![]() Thank you very much Noiseblocker and specially Andreas. This weekend i made the bracket for the column to mount my lcd panels.First i collected all the materials i needed and cutt,drilled and welded them. ![]() ![]() ![]() ![]() ![]() ![]() ![]() All parts are finisht. ![]() Now its time to putt them together and mount the bracket onto the column. ![]() ![]() ![]() ![]() Now thats finisht i can mount the panels and this is how it looks. ![]() ![]() ![]() ![]() ![]() ![]() ![]() I also made a short movie of the panels in action.I was suprised how smooth they move.The column makes no noise and it lifts the panels roch solid. http://www.youtube.com/watch?v=m0Xyn...d2AUAAAAAAAAAA This was it for today and more to come.
#125 |
↓ Don't trust that face!
__________________
#126 | |
long live the pc
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl, ![]() |
#127 |
Very smooth, loved the vid. Does the column have a lower limit ? Those panels would look even better if they went low enough to hide behind the desk. The visual impact of them appearing from the back would be stunning. Love the engineering on your build
__________________
#128 |
Supermodder
And HOW did i miss this!?!?!?!? Fantastic work mate! Have done a little tig welding, sell the machines so need to know what im selling... :-) Have also worked as field mechanic so there i used a lot of arc welding in steel but not much tig, that's is to bad because i wan't that knowledge now and need it to build alu stuff :P
At my work we just call those rivets (the threaded ones) pop-nut :-P that might be becuse in swedish the common name for a rivet is pop-nit (nit=rivet) and then pop-nut comes very handy even tho it's english :-P do you still have some leftover pci bracket? |
#129 | |
Modder
#131 |
Keep calm & mod on. =)
Superfine work Paslis & that monitor setup is pure cheesecake
& then the super smooth motion of the lift, man this really is a dream rig dude. ![]() Really fitting name for the project. rep
#132 | |||||
Supermodder
Didnt see it that way but your right it needs a hug.
Thanks Cheapskate. ![]() Quote:
![]() Quote:
![]() Nice to know. ![]() Quote:
![]() Quote:
#133 |
May contain traces of sanity.
Very neatly done, very impressive
#134 |
Squid
Amazing work as always there Paslis!!
#135 |
Supermodder
#136 |
Supermodder
Update 8 17 March 2012.
Today i started with the foot for the desk.Im gonna use a frame with plastic feet and 2 mount plates for mounting the columns.On top of the frame there will be a cover. First i cutt the pieces im using for the frame. ![]() Then i drilled the holes for the M8 rivet nuts and put them in. ![]() These are the plastic feet im gonna use. ![]() Then i drilled the holes in the mounting plates for the columns.The holes are 12,5mm and thats the hole i need for a M10 stainless steel welding nut. ![]() ![]() Welded the nuts. ![]() All parts are finisht so now its time to put all the pieces together. ![]() ![]() ![]() ![]() Then i mounted the plastic feet and the frame is finisht. ![]() ![]() ![]() ![]() ![]() ![]() This was it for today and more to come. |
#137 |
That is an awesome pile of progress,
think my motivation is really high now to get back onto doing mine. ![]()
#138 |
long live the pc
![]() i did wounder what the hols were for and now i know great work +rep to you
__________________
#139 | |
Supermodder
I guess he also have a couple of extensions to "build" things in 3D?
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#140 | |||
Supermodder
Go for it mate. ![]() Quote:
kelmannen's explanation is right so i dont have to tell anything more. ![]() Quote:
| Thread Tools | |
| View Mode | |
