Reply
Thread Tools View Mode
Old 19th Mar 2012, 14:47   #141
Shurika
Multimodder
Shurika's Avatar
Shurika has yet to learn the way of the DremelShurika has yet to learn the way of the Dremel
epic project!!! 5 stars & subed! One question: I have not used Noiseblocker fans ever, are they realy very quiet?
sorry for my English
Shurika is offline   Reply With Quote
Old 19th Mar 2012, 15:00   #142
myrizzle
Modder
myrizzle has yet to learn the way of the Dremel
Noiseblocker are the best fans out there, IMO atleast. And iv'e tried alot But theyre also pretty expensive..
myrizzle is offline   Reply With Quote
Old 20th Mar 2012, 13:05   #143
Paslis
Supermodder
Paslis's Avatar
Paslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run Crysis
Thanks Shurika. Well you have them in different speeds with different dBA.I think they are really silent.
Indeed myrizzle.
Paslis is offline   Reply With Quote
Old 25th Mar 2012, 13:30   #144
Paslis
Supermodder
Paslis's Avatar
Update 9. 25-3-2012
Yesterday i find out i was totaly of with a measurement of the desk foot.Luckely it was simple to fix.Today i went back to the shop to work on the desk because i really wanted to test de columns.
First i drilled the holes for the columns into the desk body and the holes for the column covers.
Now its time to put it all together.First i mounted the feet for the desk foot.
Then it was time to mount the columns.
After that i mounted the body on to the columns.
Then i mounted the frame for the panels etc to the desk body.
Time to put the wires in place.
Time for testing and here is a small movie of the test.
http://www.youtube.com/watch?v=BH9GD...ZqiyO8loyjo1k=
This was it for today and more to come.
Thanks to my sponsors :
Old 25th Mar 2012, 14:58   #145
voigts
Hypermodder
voigts's Avatar
voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.
Your desk/mod is looking sweet. I do wonder though on a practical level how much you will actually use the ability to raise and lower the desk. It seems to me that you would tend to find a comfortable height and stick with that.
__________________
Previous Project: Zenith Antique Radio Scratch Build
Current project: Project Quintessence
voigts is offline   Reply With Quote
Old 25th Mar 2012, 15:35   #146
craig - toyoracer
Supermodder
craig - toyoracer's Avatar
craig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremel
Altogether now that looks sweeeeeeet. Great proportions too.
__________________
octTower
craig - toyoracer is offline   Reply With Quote
Old 25th Mar 2012, 18:34   #147
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysis
Party trick maybe I´ve been wondering the same. Not that there have to be a practical reason for everything... Up and down might be good against repetitive strain injurys though
__________________
R-KAID-Я (in progress)
The Shrine / REDELUX / 4M / R-kaid-6 / Sputnik 0667
quizz_kid is offline   Reply With Quote
Old 25th Mar 2012, 19:08   #148
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
I'm guessing there will be preset settings for the Wife & various munchkins.
Cheapskate is offline   Reply With Quote
Old 25th Mar 2012, 19:14   #149
The_Gnu
8-bit addict
The_Gnu's Avatar
The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.
I would guess it's main use will be to switch from sitting to standing position. I got this feature at work and my back loves it after several hours curled up on a chair.
And Paslis, this is a truly amazing project. Your metal work is truly amazing, Im pretty shure everyone here on this forum wish they could have your skill and acess to that workshop aswell.
Im really looking forward to see this one finished, but make shure it will take a long time because I want to have time to enjoy all the awesomeness.
__________________
Project: ProtoHype (paused)
Project: GET A LIFE (Complete)
Project: Widescreen Projector(Complete)
Guide: How to brush Aluminum
The_Gnu is offline   Reply With Quote
Old 25th Mar 2012, 20:00   #150
Paslis
Supermodder
Paslis's Avatar
Thanks voigts and my wife and 2 kids will use the desk also so i guess it will move more then i expect.
Thanks craig.
Makes me think.
Makes me thinking again.I think i can use this desk for allot of things.
Your right about that Gnu.Here is a short movie with the same column and were you can use it for.
http://www.youtube.com/watch?v=61hPwaFKs1E
Thanks for the compliment and this project is long from finisht.
Old 25th Mar 2012, 20:25   #151
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
looking good mate keep up the good work
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 25th Mar 2012, 20:49   #152
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.
Damn you and your welding skills!
Oh, and the design is not half bad either!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 25th Mar 2012, 23:18   #153
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
I think you should massproduce theese ones at the factory ^^!
It looks great!
KoSoVaR^ is offline   Reply With Quote
Old 25th Mar 2012, 23:54   #154
Karrek
Multimodder
Karrek's Avatar
Karrek has yet to learn the way of the Dremel
I can definitely see the sitting and standing configurations. Also lowering it for children would be useful. Also, if you had a large monitor, it could become like an adjustable entertainment center - i.e. raise it for viewing from a nearby couch or bed.
Looks like a lot of fun - and thanks for the video...the visual is very helpful!
Karrek is offline   Reply With Quote
Old 26th Mar 2012, 02:38   #155
voigts
Hypermodder
voigts's Avatar
I hadn't thought of the convenience of being able to adjust it for your wife and kids. Hmm, then again, it may not be a good thing if it is so convenient as you may have to take a number to get to use your own desk!
__________________
Old 26th Mar 2012, 06:53   #156
thegyufi
on air
thegyufi has yet to learn the way of the Dremel
lol +1 voigts, I think you must use a pasword to control the acces
Amazing work by the way, I which I could use the same tools
thegyufi is offline   Reply With Quote
Old 26th Mar 2012, 12:00   #157
Trevor28
Where is the cow?
Trevor28's Avatar
Trevor28 is a hoopy frood who really knows where their towel is.Trevor28 is a hoopy frood who really knows where their towel is.Trevor28 is a hoopy frood who really knows where their towel is.Trevor28 is a hoopy frood who really knows where their towel is.Trevor28 is a hoopy frood who really knows where their towel is.Trevor28 is a hoopy frood who really knows where their towel is.Trevor28 is a hoopy frood who really knows where their towel is.Trevor28 is a hoopy frood who really knows where their towel is.Trevor28 is a hoopy frood who really knows where their towel is.Trevor28 is a hoopy frood who really knows where their towel is.Trevor28 is a hoopy frood who really knows where their towel is.
This is fantastic. I look forward to seeing the finished build.
__________________
Look at him now, disappearin' a cow
Trevor28 is offline   Reply With Quote
Old 26th Mar 2012, 18:35   #158
Paslis
Supermodder
Paslis's Avatar
Thanks mate.
Thanks mate and no sanding this time.
It looks great!
Thanks for your compliment mate.
Thanks Karrek and your right it has multiple use.
Well they hardly use my current desk so i think they will use this one not much more.
Thanks thegyufi and there are desks now that can be programmed.You walk towards the desk and sit down and typ your name and the settings will adjust like you have enterd them.
Thanks Trevor.
Old 27th Mar 2012, 10:08   #159
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Nice
Waynio is online now   Reply With Quote
Old 27th Mar 2012, 10:20   #160
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
This thing is just crazy...Love it, can't wait to see it all finished.
bulldogjeff is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
