#161 |
Supermodder
#162 |
Linux User!
That looks great! Really solid and stable too!
__________________
Main Rig Phenom II X4 | Dark Rock Pro | GA-880GA-UD3H | GTX 460 | 2x2Gb HyperX Blu & 2x4Gb XMS3 | 250GB 840 SSD | 1TB + 3TB HDD | CM 690 II Advanced Laptop i5 24320M | nVidia GT540M | 4Gb RAM | 500GB HDD Steam, Origin, BFBC2, WoT: Pyr0660
#163 |
Supermodder
Thanks and yes i was very suprised in how stable the columns are and the same with the column for the screens.
#164 |
↓ Don't trust that face!
OK, that last reply to what I said was... I wasn't saying use it on your wife.
(You must've read 'preset' and thought 'speeds' or something...I really jumped in because I noticed the base has a lot of toe-stubbing potential with those points out front. That looks like it would hurt.
__________________
#165 |
Supermodder
Your right about that Cheapskate and thats why the cover gets a round shape on the corners because i dont want anyone in my family to hurt a toe.
#166 |
Supermodder
Update 10.
This weekend it was time to do some modding again.The mobo tray en the cover for the 4 casefans at the front were cut on the lasercutter. ![]() ![]() Then i bend the 2 pieces. ![]() ![]() ![]() Then it was time to make the standoffs for the mobo.For this i used 8mm stainless steel with M4 thread. ![]() ![]() ![]() After that i drilled the holes for the mobo in the mobo tray and mounted the standoffs on the mobo tray and placed it inside the desk. ![]() ![]() ![]() Time to mount the mobo on the tray. ![]() ![]() ![]() Time to mount the fancover and this is how it looks at this point. ![]() ![]() This was it for today. Thanks to my sponsors: ![]() ![]() ![]()
#167 |
Keep calm & mod on. =)
Awesome update, that's 1 very neat looking mobo tray.
__________________
Air Cube v2 and gaming tower (Fin Aug 2010) Stealthlow (Fin Sep 2011) Lean & Green - Modular Dual PC Paused Midlag Crisis Last edited by Waynio; 11th Apr 2012 at 23:04. |
#169 |
Multimodder
looks interesting, i will be following...
#170 |
Supermodder
nice progress! senses awesomeness! =)
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#171 | |
Supermodder
Thanks Waynio.
![]() Quote:
![]() Thanks dirky90. Thanks kelmannen.
#172 |
The Keeper of History
Just keeps getting better.
Oh, and nice motherboard choice too. john
__________________
My deepest gratitude to this community.
#173 |
Hypermodder
Looks great mate, I love your work still its insanely detailed and neat love the idea too, keep it up!
__________________
Project in progress: Bitfenix Prodigy Stacker
Interior Des(k)ign | BitPac | Bitfenix Prodigy Stacker Modding is addictive!! |
#174 |
still thinking....
I've been watching but I'm always stumped for words.
Clean, precise work and nice design too.
__________________
stillthinking |
#175 | |||
Supermodder
![]() Quote:
#176 |
Supermodder
Update 11.
This weekend it was time to start working on the cover for the back side.For this i used 3mm aluminium. First i cut a piece of the right measurements and bend it. ![]() I want the cover to go with the design so i cut the pieces for the corners. ![]() Then i weld the pieces together and did some finishing. ![]() ![]() ![]() Then i made the side pieces for the cover with the holes in them for the 80mm casefans.I was so busy making them that i already finisht them and then i realised that i forgot to make some pictures.At that point i spotwelded all the pieces together. Spotwelded the side pieces on the cover and finisht welding them and some sanding ofcourse. ![]() ![]() ![]() Time to fit the cover and this is how it looks. ![]() ![]() ![]() ![]() ![]() ![]() The cover is stil not ready but im satisfied how it looks so far. More to come. Thanks to my sponsors : ![]() ![]() ![]()
#177 |
Bending 1mm perfect is nice but 3mm that is 1 heck of a beauty of a bending brake bet that piece is wickedly strong, that table is fantastic also & perfect work to match the awesome gear.Simply beautiful fabrication all the way. ![]() Seriously drool worthy desk case & that's without the hardware. ![]()
#178 | |
Supermodder
__________________
#179 |
Minimodder
You got a subscribe. I love this build and I wish i had such a table for my self. Keep up the good work..
#180 |
on air
it seem to be so ... perfect !
love your work, keep going this way ! |
| Thread Tools | |
| View Mode | |
