Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 11th Jan 2012, 17:03   #21
Pookeyhead
It's big, and it's clever.
Pookeyhead's Avatar
Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.
I'd still go out of the back. Just neater in my mind. More accessible if there are quick release barbs there too.. No need to lift or tilt the case to access them.
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ 4GB EVGA GTX670 Superclocked SLI ¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦ Logitech Z623
EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS8704EM2 ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered
MOON | Thecus N3200pro 3TB RAID5
Pookeyhead is offline   Reply With Quote
Old 11th Jan 2012, 17:46   #22
KayinBlack
I Endure
KayinBlack's Avatar
KayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for president
Kolance has a PCI pass-through plate, and it may have QDCs, if I'm not mistaken.
Also, that height won't bother the pump. It's a closed loop, which means any water pushed down the tube simply forces that already there back around. Water is incompressible. The only time pump head matters is an open loop where it gets no help from the returning fluid.
KayinBlack is offline   Reply With Quote
Old 11th Jan 2012, 17:51   #23
Ant1981
Supermodder
Ant1981 has yet to learn the way of the Dremel
If it hasn't been suggested, don't use 90 degree bends as they significantly reduce flow. Use tube with an anti kink coil wrapped around it.
__________________
Kawasaki Ninja ZX6R - Water cooled
Ant1981 is offline   Reply With Quote
Old 11th Jan 2012, 17:54   #24
Spreadie
No disassemble!
Spreadie's Avatar
Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.
Originally Posted by .//TuNdRa View Post
From what I can find from other sources (As EKWB still refuses to load for me); The Pump is capable of 800L/h up to a height of 4M, would that not be sufficient?
Doesn't that kit have the EK-DCP 2.2 Pump?
I thought that was rated at 400lph.
I'm probably wrong, but it's worth checking.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60
Spreadie is offline   Reply With Quote
Old 11th Jan 2012, 18:40   #25
thetrashcanman
Angel headed hipsters
thetrashcanman's Avatar
thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.
If he doesn't use the pcie bracket out the top of the case route, I don't think he would have a choice in using 90 degree fittings, as from what he said there is very little room underneath the RV02 he wouldn't have a hope in hell of making the bend with just tubing and an anti kink coil
__________________
i7 3930k/watercooled on 360 rad/Asus Rampage IV Extreme/16Gb Corsair Dominator GT 2133Mhz/Gtx 480/2 x Corsair Force GT 240Gb RAID0 /Silverstone TJ11/Enermax Platimax 1500W
thetrashcanman is offline   Reply With Quote
Old 11th Jan 2012, 18:51   #26
.//TuNdRa
Resident Bulldozer Guru
.//TuNdRa's Avatar
.//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is.
Not without having to raise the case. It's an inch, or less, of room underneath the case, and the grommets are in the floor, set about two inches back from the closest edge. Hence why I leaned towards using the top.
As far as I can find: Anyone who actually has the kit (Although the closest review I can find is of the Supreme HF 240) has remarked it comes with the 4.0, not the 2.2. However; the 4.0 is somewhat cheaper than buying a D5, so I could swap them out if I absolutely have to.
Edit: Bugger. It does come with the 2.2, Might have to see how it performs before I bin it, however. I'd rather not chuck out a perfectly good pump.
Suppose I could spend an extra £30 and get the Supreme HF variant, as it comes with the 4.0, and the better heatsink. What do you lot think?
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Xonar DX/XD | 2X SLI KFA2 550Ti White Edition | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | OCZ Agility 3 60GB | 1.5TB in Drives | Lite-on Blu-ray ROM
Dell 1908 | Sennheiser HD 485s | Creative Gigaworks T40s | Logitech G13 | Microsoft Sidewinder X6 | Cyborg R.A.T 9
.//TuNdRa is offline   Reply With Quote
Old 11th Jan 2012, 18:59   #27
shaunster1011
Multimodder
shaunster1011 has yet to learn the way of the Dremel
However the D5 is much much better pump and will serve you well for many years
__________________
My PC in a desk
shaunster1011 is offline   Reply With Quote
Old 11th Jan 2012, 19:14   #28
.//TuNdRa
.//TuNdRa's Avatar
And £70 for a version that won't force me to use 1/2" to 3/8" converters. I've thought about this. The lower the price I achieve; the better. I'm setting myself a challenge to see how cheaply I can get a very good watercooling loop, while still using quality components.
The D5 would be very, very overpowered for my purposes. I don't believe I'll need 1500L/hr flow in order to smoothly cool a Processor, a VRM block and a NB, perhaps if I added GPU sinks to the loop as well, but the beauty of the Raven is that it's happy enough for GPU's on air that I shouldn't need to go to those lengths unless I'm seriously pushing an overclock on whatever GPU i'm using.
__________________
Old 13th Jan 2012, 20:53   #29
.//TuNdRa
.//TuNdRa's Avatar
Oh snap. Having a look around; I'm concerned that the waterblocks in the EKWB GA AMD kit won't actually fit the board. From what I can see; the NB block will fit without issues, but if the sizing of the VRM heatsink and its' mounting points are to go by; That won't fit on this board.
Does anyone have the dimensions of the Stock VRM heatsink used? I'll try and dig out a tape measure soon and get in there to check, but until then; i'm hanging in uncertainty.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
