#21 | |
Multimodder
thanks bro
i am glad you like it same as me and too many love this awesome game ![]() Quote:
![]() glad you like it more pic will add this week |
#22 |
Fake potato
Innnnnnteresting! Sub'd want to see how that rust goes
__________________
Masara: i5 2500@4.2Ghz | Asus P8P67LE | EVGA GTX460SC | 8Gb Corsair 1600 | 1TB WD-C BLACK | Fractal R3 | LG 23" IPS
LEGO Ghetto HTPC: Broken-ass laptop pulled apart, now a HTPC... made of LEGO. UNDER CONSTRUCTION |
#23 |
Multimodder
thanks man a lot of update i will add today
#24 |
Covered in rockwool dust.
Nice idea/build, but couldn't you have made the rig's health meter into some kind of reservoir or large flow indicator, assuming you'd be looking at water cooling ? now that would be cool !
__________________
Ignorance is bliss ..... 'til it breaks, leaks, catches fire, explodes, maims pets and loved one's, deletes the internet and divides the universe by 0 ............. then it's expensive
#25 | |
Multimodder
![]() what sup every one here some pic for i have done mask is 80% done all is just paint it and health bar done but need to get paint too like dmcgrath say make it change color i got bro here it is will paint the case and make the magic happen ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#26 |
Loading...
Amazing progress! looks great!
#27 |
Multimodder
thanks bro same to ur kb
#28 |
Multimodder
Back here with some real rust on the case may be the first real rust paint on a case some of other modders made it but with paint this may be new idea for modders to keep this idea in mind
![]() will add more rust effect to get more rust ![]() hmm do you see this real iron ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() more pic will be add very soon thanks for looking |
#29 |
Multimodder
here is a lot of rust made on the top of the case looks like i got what i am looking for this a really nice effect i have never try this with paint and never see this result
painting the mask was hard to paint very well but i have try my best to look like but the color of the mask looks different in to many photos some is green and other gray i have done the green ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() it's coming tighter very soon thanks for looking |
#30 |
I Mod, Therefore I Own
Looking good so far dude!
__________________
ZiiP Gamestore [ZiiP] Gaming Community - IW BlackMailers and loonies abound! Sui Generis: i7 920, Corsair H50, 6GB Dominator C7 1600, EVGA x58 SLI LE, Corsair F3 120GB SSD, Samsung F3, Sapphire 5870 Vapor-X, Corsair HX850W, Corsair Obsidian 800D, Iiyama 26" Prolite, Logitech G15, Logitech G5, Sennheiser PC350. |
#31 |
Multimodder
thanks bro
#32 |
What's a Dremel?
Can you made some kind of reservoir flow indicator rigs health meters, assuming that you are looking for water cooling?
#33 | |
Multimodder
![]() here after put the side of the windows and using the multiply color light are very cool next step will add the mask ![]() ![]() ![]() ![]() ![]()
#34 |
Multimodder
hello every one few day srr for late i was working on my newer mod under the hood will post it soon i done here
i add the mask and add the laptop skin i was selling them so i decide to use one it for the same game so it way looks scary to me look he is will come out the case :S ![]() work on the side health find a way more easy to cut the Styrene Sheets using a hot wire the same using for foam cutter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() more very soon |
#35 |
Multimodder
work on the light take it a part and make the wire more longer and add the health par to the case and lighting it up
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() it's almost over
#36 |
What's a Dremel?
looking good well done
#37 |
Multimodder
Thanks man
#38 |
Minimodder
Nice work. The health bar lamp is pretty cool...
#39 |
Multimodder
thanks man
after painting here how it look like the final pic very soooon ![]() ![]() ![]()
#40 |
Keep calm & mod on. =)
Oooooh, me likey, this is low on stars also, have some.
| Thread Tools | |
| View Mode | |
