Reply
Thread Tools View Mode
Old 17th Jan 2012, 15:07   #1
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on you
Project: 4M (9/3 - F I N A L S ! ! !) > Completed
Project: 4M
Some of the final pictures, check page 9 for more of them
My mom's computer broke down the other week. Since I am such a loving son I have to
give her a new one. And since she´s not picky when it comes to performance,
I´m going to use these modest components:
Spcs:
ITX MSI H61I-E35
CELERON G530 2.4GHZ
Zalman 9500A
4 gb RAM
CLUB 3D GF 210 512MB
WESTERN 500 Gb
The idea is to get done by her birthday in mid-February, so expect something relatively simple.
Design
Delivery
I ordered a 430W, but since I want to keep the volume down as much as possible,
I now think I´m gonna use my old shuttle-250W instead
Modified Zalman 9500
Found a new bracket fortunately
For mom, this mediocre card will do the trick
Mobo
Mock-up for start button
__________________
Tempel / Revelation / The Shrine / REDELUX / 4M
Follow me on facebook or Instagram
https://www.facebook.com/lovehultenau
@lovehulten
quizz_kid is offline   Reply With Quote
Old 17th Jan 2012, 15:31   #2
Jay_UK
What's a Dremel?
Jay_UK has yet to learn the way of the Dremel
Hi there,
Intersting project...
I believe you should be able to just cut the pins and remove the VGA connector (any reason you arent using the IGP?)
In your config, a 20 pin PSU into a 24 pin Mobo should be ok (low power requirements)
J.
Jay_UK is offline   Reply With Quote
Old 17th Jan 2012, 16:28   #3
Shuttlemodder
Mod Master
Shuttlemodder's Avatar
Shuttlemodder is a Super Spamming SaiyanShuttlemodder is a Super Spamming SaiyanShuttlemodder is a Super Spamming SaiyanShuttlemodder is a Super Spamming SaiyanShuttlemodder is a Super Spamming SaiyanShuttlemodder is a Super Spamming SaiyanShuttlemodder is a Super Spamming SaiyanShuttlemodder is a Super Spamming SaiyanShuttlemodder is a Super Spamming SaiyanShuttlemodder is a Super Spamming SaiyanShuttlemodder is a Super Spamming Saiyan
Personally i would cut the pins with a set of wire side cutters..
put some 1mm heatshrink over them one by one to protect them.
Though not sure why you would need to remove them??
Shuttlemodder is offline   Reply With Quote
Old 18th Jan 2012, 01:15   #4
quizz_kid
Squid
quizz_kid's Avatar
Originally Posted by Jay_UK View Post
Hi there,
J.
Thanks! The reason is a backplate design I´m working on... But I might leave it there. Don´t know yet.
Thanks for the tip mate
__________________
@lovehulten
Old 18th Jan 2012, 01:24   #5
quizz_kid
Squid
quizz_kid's Avatar
Another question, this time about the C14 plug in the PSU.
What is that green thingy under the question mark? I´m a bit confused...
The thing is that I want to extend the cable. Can´t I just cut the blue/brown and add Gnd to a new plug?
__________________
@lovehulten
Old 20th Jan 2012, 00:41   #6
quizz_kid
Squid
quizz_kid's Avatar
Joystick ingredients
Some drilling
Alu fittings
This is the constuction inside. The placing of the metal spring had to be precise and it took some time to get the right resistance when pulling the ballhead
Close up
Also made two simple HDD mountings
Aslo started on the wood work. I changed the shape a bit. Less width / more depth
For an idea of the size... It´s not the smallest htpc, but it´s no monster
Layout on the roof. Mobo will hang upside down
Here´s where the GPU´ll be. Going to use pci extensions later. This will be left side, and the only side with attributes (such as mesh, DVD, USB-panel, fan controller etc) I want to keep it a clean build so nothing on top and right side. Front will just be joystick and brass window...
Right side with HDD
__________________
@lovehulten
Old 20th Jan 2012, 00:43   #7
quizz_kid
Squid
quizz_kid's Avatar
Btw, sorry for changing the title all the time...
__________________
@lovehulten
Old 20th Jan 2012, 19:20   #8
ASPHIAX
Hypermodder
ASPHIAX's Avatar
ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!
Nice start man !
KUTGW !
__________________
Sander van der Velden
ModWithMe Concept Founder
E. Sander@ModWithMe.com
FB. https://www.facebook.com/ModWithMe
ASPHIAX is offline   Reply With Quote
Old 20th Jan 2012, 20:44   #9
The_Gnu
8-bit addict
The_Gnu's Avatar
The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.
Awsome work, m-itx AND mdf, two of my favourite things.
Regarding the cutting of the VGA port. I did the exact same thing on my project. First I cutt the small connectors with a plier and then desoldered the rest of the connector. Your connector is however of another kind but you should be fine just to cut the VGA piece away. Might be tricky to remove the remaining pins since that black casing seems to cover their solderjoints. You could try and heat them from the other side while pulling with a plier.
Just make shure to preotect the mobo from any metall/solder debris but i guess you already know that.
Good luck
__________________
Project: ProtoHype (paused)
Project: GET A LIFE (Complete)
Project: Widescreen Projector(Complete)
Guide: How to brush Aluminum
The_Gnu is offline   Reply With Quote
Old 20th Jan 2012, 20:45   #10
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Your mom must be proud to have son like this.
Pranja is offline   Reply With Quote
Old 21st Jan 2012, 16:09   #11
quizz_kid
Squid
quizz_kid's Avatar
Originally Posted by ASPHIAX View Post
Nice start man !
KUTGW !
Thanks mate!!
Good luck
Thanks Gnu! Yeah, hate those covered solder joints. But thanks for the tip buddy. Will try that heating and pulling later
It´s the other way around, but I think she´ll like it
__________________
@lovehulten
Old 21st Jan 2012, 16:16   #12
quizz_kid
Squid
quizz_kid's Avatar
Made new plates for the joystick today. Some perfection this time. All but painting left now.
Made some spacers
Cut some lumber today. Walnut of course =)
Made front/back frames
Also made some simple fittings for DVD and graphics
Just one last check before putting the box together. Drill some, mill some... Can´t miss anything here since it´ll be too tight for machinery use in there later.
Box glued!!
__________________
@lovehulten
Old 21st Jan 2012, 21:28   #13
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
This will be good & in a short time frame . 5 stars & rep
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 22nd Jan 2012, 09:59   #14
quizz_kid
Squid
quizz_kid's Avatar
Much appreciated Waynio
__________________
@lovehulten
Old 22nd Jan 2012, 11:50   #15
KidMod-Southpaw
KidMod-Southpaw's Avatar
KidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming Saiyan
This is definitely a great idea for such a small build- love the power switch!
__________________
Project Logs: Refraction - Steampunk Flash Drive - Steel; Sleek; Slate
BitFenix Prodigy - Gigabyte Z87N - Intel 4670K - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - M4 128GB - WD Red 1TB X2 - H60 - Antec 650W - Dell U2312HM - Poker MX Red - Sennheiser HD 598
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 22nd Jan 2012, 20:55   #16
quizz_kid
Squid
quizz_kid's Avatar
Thanks KidMod!
__________________
@lovehulten
Old 22nd Jan 2012, 21:05   #17
quizz_kid
Squid
quizz_kid's Avatar
Sunday. Just sitting here trying figuring out what foot stand design to use. I have 3 options so far... Any thoughts are welcome!
A simple elegant wooden stand
A metal stand inspired by old industrial stools, painted in a color matching the front panel maybe
A stand with angle / nose pointing up
__________________
@lovehulten
Old 22nd Jan 2012, 21:31   #18
Pranja
Blackwolf
Pranja's Avatar
2 would be my choice because it is most stable.
Old 22nd Jan 2012, 23:36   #19
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Really nice idea, perfected execution, what else can I ask? Just mod on my friend, this looks awesome!!!!! +rep
AnG3L is offline   Reply With Quote
Old 23rd Jan 2012, 17:16   #20
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Something that sticks out further in the front would be good. The handle gives you the potential to topple forward when pulled.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
