Reply
Thread Tools View Mode
Old 23rd Jan 2012, 21:49   #21
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysis
Originally Posted by AnG3L View Post
Really nice idea, perfected execution, what else can I ask? Just mod on my friend, this looks awesome!!!!! +rep
Thanks mate
Originally Posted by Pranja View Post
2 would be my choice because it is most stable.
Originally Posted by Cheapskate View Post
Something that sticks out further in the front would be good. The handle gives you the potential to topple forward when pulled.
I think I´ll go with option nr 3, for now at least. I find the angle interesting. And with that stand I could build in a weight of some kind to keep it steady and avoid a possible fall on the nose. I´m also thinking about placing an accessible usb-port on the foot. Helps me keep the main build clean...
Anyway, some todays work:
Front and back frames glued and sanded
Veneering time. But first, cover those holes
Little pieces of MDF did the trick
Veneer under pressure
Cut some support pieces for the roof veneer
Glue
Support
Squash it!
Also got rid of the VGA port today. Tore it! Got kinda violent. Cutting the pins was not enough. I had to get the damn toolbox. Well well, it´s done. Don´t know if I´m gonna try heating the pins off. Maybe just put some protection on it.
__________________
R-KAID-Я (in progress)
The Shrine / REDELUX / 4M / R-kaid-6 / Sputnik 0667
quizz_kid is offline   Reply With Quote
Old 23rd Jan 2012, 21:52   #22
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!
I still don't understand why did you remove VGA port.
But,everything else i cool.
Pranja is online now   Reply With Quote
Old 23rd Jan 2012, 21:58   #23
quizz_kid
Squid
quizz_kid's Avatar
It was badly misplaced by the manufacturers
__________________
Old 24th Jan 2012, 11:28   #24
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Looking perfect .
Waynio is offline   Reply With Quote
Old 24th Jan 2012, 11:31   #25
ASPHIAX
Beyond Complexity Lies Simplicity
ASPHIAX's Avatar
ASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the Dremel
lol, my kind of modding !
__________________
Current Build : BORG COSMOS II
Current build : 2001 - A Case Modyssey
Finished build : IMPERIAL AT-AT
Finished Build : USS EURISKO - Intrepid Mark II Class
www.asphiax.wordpress.com
ASPHIAX is offline   Reply With Quote
Old 27th Jan 2012, 00:13   #26
quizz_kid
Squid
quizz_kid's Avatar
Got some work done today
Pieces
This is how I solved the usb issue, with a hidden canal
On the other side
Glue
The rest of that canal, hidden in the top piece
veneer
I decided to make a classic profile on the base. Looks good IMO
The two feet. They´re only 20x20mm thick so I hope they´ll carry. We´ll know soon...
I also made a hole straight thought one of them for the usb wire.
This is how it´ll look
Made the bottom also
Here´s that well needed weight. 160x120x17mm, and quite heavy for its size...
I aslo leave you with a question, this time regarding the DVD eject button.
Going to make extension. I´m looking for soldering spots. The circled ones seemes right... or??
__________________
Old 27th Jan 2012, 01:27   #27
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
Theres actually 3 on that switch.
Im glad you went with the last design on the feet, makes it look a bit 'alive' cartoon wise, like something from Pixar
__________________
Life. Liberty. The pursuit of those who oppose it.
Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide
@furballzen
Furball Zen is offline   Reply With Quote
Old 28th Jan 2012, 16:40   #28
quizz_kid
Squid
quizz_kid's Avatar
I don´t like Pixar, but it seemes like a compliment ... so thanks!
__________________
Old 28th Jan 2012, 16:44   #29
quizz_kid
Squid
quizz_kid's Avatar
Arrrrgh! I think my mobo´s fu**ed... Did a testrun today and there´s this repeating on/off thing going on. I get the two beeps and fans running for 3 seconds, then dead, over and over again. I´m guessing it´s the mobo, but who can be sure
__________________
Old 28th Jan 2012, 16:53   #30
Waynio
Waynio's Avatar
Oh I hate difficult to diagnose problems & not having enough spare parts to mix match to find the actual offending piece .
Certainly had that problem you mention & like said can't really find the fault without spare parts .
Old 28th Jan 2012, 22:56   #31
j0rd
FLOSS folder
j0rd's Avatar
j0rd has yet to learn the way of the Dremel
might be a stupid question but have you tested the individual components against known good hardware. other than the mobo the first thing i would look at is the PSU, the issue you describe sounds alot like one i had ages ago running a newer mobo on an older PSU. the ATX PSU spec has changed over the years and newer mobo's are not always compatible with PSU's bassed on older versions of the spec.
__________________
Word Press blog
Losias stats tracker (under development) is here
‾pɹ0ɾ
j0rd is offline   Reply With Quote
Old 29th Jan 2012, 00:03   #32
Gtek
Supermodder
Gtek's Avatar
Gtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run Crysis
Nice job so far man! Walnut is beautiful
Like you, Wayne and j0rd, I'm sure I had this problem before, just can't remember what it was, apart from that mobo was actually ok.
__________________
***gtek-computerdesign.com***
Gtek is offline   Reply With Quote
Old 29th Jan 2012, 09:06   #33
Waynio
Waynio's Avatar
What j0rd said sounds just like a prob I had a while ago & same symptoms as this, older but great PSU just not playing ball properly with the newer mobo, PITA without spare parts .
Old 29th Jan 2012, 10:03   #34
quizz_kid
Squid
quizz_kid's Avatar
Yeah. this really sucks!
I thought about it... The Shuttle 250W was kind of a try out. But since I tested with a corsair 430(same issues there), I don´t know. Should I go as far as try with an even newer power supply?
Thanks Gtek.
I´m looking for some luck out there
__________________
Old 29th Jan 2012, 10:27   #35
quizz_kid
Squid
quizz_kid's Avatar
Found some of that luck... It was one of the RAMs actually, missed double check there I guess.
Feel kinda stupid... But thanks for helping me out there mates!
Bad guy below
__________________
Old 29th Jan 2012, 21:01   #36
quizz_kid
Squid
quizz_kid's Avatar
After a rough weekend filled with computer issues I started this afternoon with some more woodwork.
I milled the DVD slot with high precision... Perfect! ... wait a minute ... its... its...
... ON THE WRONG F*CKING SIDE! Reminder for future projects: THINK!
To hide the mistake I did some more milling Thinking of having some mesh in there.
I also made the front.
Joystick slot
The front will have some kind of stain later
Here´s the beautiful brass window. "Steampunkish" some might call it...
Got my risers aswell.
__________________
Old 29th Jan 2012, 21:27   #37
penryn 2 hertz
Hey, ho, pip and dandy moment's...
penryn 2 hertz's Avatar
penryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for president
Grate job but next step is de solder the dvi/vga port all together so look's neat and tidy...
__________________
Under progress...
penryn 2 hertz is offline   Reply With Quote
Old 30th Jan 2012, 01:23   #38
j0rd
FLOSS folder
j0rd's Avatar
good luck de-soldering anything on a ROHS compliant mobo
__________________
Word Press blog
‾pɹ0ɾ
Old 30th Jan 2012, 03:26   #39
CrowAT
What's a Dremel?
CrowAT has yet to learn the way of the Dremel
Lots of good stuff here. Nice progress.
CrowAT is offline   Reply With Quote
Old 30th Jan 2012, 08:05   #40
j0rd
FLOSS folder
j0rd's Avatar
hmmm, a set of side cutters would prolly get the pins down to uber short though
__________________
Word Press blog
‾pɹ0ɾ
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
