Reply
Thread Tools View Mode
Old 30th Jan 2012, 18:43   #41
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysis
Originally Posted by penryn 2 hertz View Post
Grate job but next step is de solder the dvi/vga port all together so look's neat and tidy...
Thanks.... But de-solderingīs not an option here.
Originally Posted by j0rd View Post
good luck de-soldering anything on a ROHS compliant mobo
hmmm, a set of side cutters would prolly get the pins down to uber short though
That is my plan!
Originally Posted by CrowAT View Post
Lots of good stuff here. Nice progress.
Thanks Crowat!
__________________
R-KAID-Я (in progress)
The Shrine / REDELUX / 4M / R-kaid-6 / Sputnik 0667
quizz_kid is offline   Reply With Quote
Old 30th Jan 2012, 19:15   #42
quizz_kid
Squid
quizz_kid's Avatar
Tried a new stain today... A bit more reddish than the one Iīve been overusing last 2 years
I think I like it.
Anyway, tried it on the front...
This is a design for the footstand Iīve worked with during the weekend.
Since I have to keep the mothership unsullied, Iīll use the foot for an excuse to do something artsy
The illustration is based on circuit boards, in case anyone didnīt noticed
Then I painted certain parts off the main inside. BLOOODY RED!!
This is where I am right now, the finishing. Danish oil as usual Two days maybe...
The small pieces to the left are an idea I have for fixing that DVD-slot-mistake I made yesterday
I have like 3 weeks left, which means Iīm doing pretty well. This means Iīve got time for an associated monitor mod also
This is my old screen. Going to look into it more tomorrow
__________________
Old 30th Jan 2012, 19:37   #43
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Totally gorgeous work mate .
Like the look of that brass thing with window & that circuit stain rocks . rep
Waynio is offline   Reply With Quote
Old 31st Jan 2012, 20:04   #44
quizz_kid
Squid
quizz_kid's Avatar
Thanks man! Try my best here
__________________
Old 31st Jan 2012, 20:21   #45
quizz_kid
Squid
quizz_kid's Avatar
No update today, I just want to give some cred to all the people here... Iīm relatively new to the modding scene, and as a noob Iīve never encountered as much indulgence and humility as here. Iīm very proud of being among you guys! Big up for this nerd platoon!
__________________
Old 1st Feb 2012, 12:51   #46
Vo0Ds
Fake potato
Vo0Ds's Avatar
Vo0Ds has yet to learn the way of the DremelVo0Ds has yet to learn the way of the Dremel
Wow, nice little project! I love wooden mods. Hope the wooden monitor bezel is nice and thin ;-) Have you any plans for lighting the brass window?
__________________
Masara: i5 2500@4.2Ghz | Asus P8P67LE | EVGA GTX460SC | 8Gb Corsair 1600 | 1TB WD-C BLACK | Fractal R3 | LG 23" IPS
LEGO Ghetto HTPC: Broken-ass laptop pulled apart, now a HTPC... made of LEGO. UNDER CONSTRUCTION
Vo0Ds is offline   Reply With Quote
Old 1st Feb 2012, 16:58   #47
quizz_kid
Squid
quizz_kid's Avatar
Thanks friend! Hard to go thin with wood, but itīll be fine I think. No light on the window itself, but inside
__________________
Old 1st Feb 2012, 17:07   #48
quizz_kid
Squid
quizz_kid's Avatar
Basic sketch for monitor. The idea is to have VGA/power supply through the "legs" as shown below. Could be too much work, but Iīd like getting rid of that cable mess...
Framework
Mmm... Lovely knags!
Bought myself a fine big screw in brass for the back mounting. Made two alu-fittings aswell
Something like this
Started working on a mock up for the fot itself, just to set the weights right
__________________
Old 1st Feb 2012, 17:59   #49
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
love your skills mate
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 1st Feb 2012, 18:38   #50
Waynio
Waynio's Avatar
Love this new monitor case & stand, I've never modded a monitor before but think I'd enjoy it a lot when thinking of all the possibilities .
Old 1st Feb 2012, 19:49   #51
Monsieur R.
In cornichons I trust.
Monsieur R.'s Avatar
Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!
I missed your circuit pattern on the wood. I love it !
Monsieur R. is offline   Reply With Quote
Old 2nd Feb 2012, 09:40   #52
Vo0Ds
Fake potato
Vo0Ds's Avatar
Wow, monitor looking great! Would it suit a slight bevel on the inside edge? I think it's a trick manufacturers use to make things appear smaller (well, on my Dell anyway). How are you going to mount the buttons?
__________________
Old 3rd Feb 2012, 06:45   #53
quizz_kid
Squid
quizz_kid's Avatar
Thanks peteski!
Thank you!! I've never done this either. But yeah, monitors seems to have a bit of modding possibilities
Thans again Vo0Ds! I think a bevel WOULD suit, only problem is thereīs not much material to bevel on. Backside frame is like 2 mm Can show pictures later. Maybe I can do something similar. Ragarding buttons Iīve decided to use only the on/off switch and a led. They+ll be mounted in the stand aswell. Cheers
__________________
Old 3rd Feb 2012, 22:39   #54
quizz_kid
Squid
quizz_kid's Avatar
Wanted brass mesh, but couldnīt find any so brought my magic can
Golden!!
Also painted some of the mountings/fittings
Backside of the monitor
Underneath... had to use some real precision here. Lot to think about
Cut some pieces for the stand aswell
Made holes for VGA and C14 socket
Something like this
Feet parts with holes for housing lots of cables later. This is going to be tricky!
I was promised a set of 8gb RAMs from the Custom PC article I did some time ago. Havenīt seen them yet. I just hope theyīll show up in time for the upcoming birthday
__________________
Old 3rd Feb 2012, 23:05   #55
quizz_kid
Squid
quizz_kid's Avatar
BTW... thinking about getting a new GPU. The fan sounds like a friggin rocket launch and Iīm having a hard time finding a passive solution out there that fits.
__________________
Old 3rd Feb 2012, 23:33   #56
Darkwisdom
Retro Fan
Darkwisdom's Avatar
Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.
If you don't need much power, how about a HD6450, they'll do everything but high res gaming (obviously). They're low profile, and Passive.
__________________
~Intel Core I3 3220 ~8GB Corsair Vengeance 1600Mhz~ CorsairCX600w ~ Asus GTX560ti Direct CUII Core @ 950Mhz Memory @ 2250Mhz ~ P8H77 ~ 128GB Samsung 830 SSD ~ Gelid Tranquillo ~ USB modded NES, Master System, Mega Drive and N64 controllers for Emulation~
Darkwisdom is offline   Reply With Quote
Old 4th Feb 2012, 06:49   #57
Waynio
Waynio's Avatar
Sounds it
Me too dude, how long ago was the article featured mate? I think the RAM came first for me when I done one, I'll PM Combatus to see if it's been sent out, that's also strange as your meant to be in moty if you get a mag feature with custom pc .
Old 4th Feb 2012, 18:47   #58
quizz_kid
Squid
quizz_kid's Avatar
Thereīs a cheap passive GT 210 on sale out there, might get that one...
Sounds it
It was the 100th issue I think... Donīt know the date of release since I wasnīt able to get hold on a copy myself The MOTY was a bit of slap in the face yeah. Was told Iīd be a candidate, but hey, maybe next time. Canīt complain though, life is great
__________________
Old 5th Feb 2012, 14:18   #59
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
really nice progress! wrote a comment about which feet you should choose... didnt see there were more pages!
=P
kelmannen is offline   Reply With Quote
Old 5th Feb 2012, 14:46   #60
Bladesingerz
Supermodder
Bladesingerz's Avatar
Bladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the Dremel
Thats a pritty neat idea for that monitor! I got to ask, was it difficult to do the disassembly of the old one? Just got me thinking of you could put 3 monitors side by side with almost no framework between them...
Bladesingerz is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
