#81 |
Squid
Thanks guys!
Hereīs the DIN-trident! And I said Iīll never sleeve First timer here, donīt know the techniques but I think I managed ok.![]() ![]() ![]() ![]() ![]() Had to go through hell just to get the 15 wires through. Came up with a screwing-pushing-technique that worked after a while. ![]() ![]() Glue ![]() ![]() Some sleeving on the AC too ![]() Mounting of the foot. Iīm really satisfied with it. Perfect weight and surprisingly good stability ![]() ![]() ![]() ![]() ![]()
#82 |
The modding head is firmly back on.
Some really nice work going on here. Really different to most builds..Like it. Top modding dude.
#83 |
long live the pc
looking sweet quizz_kid keep up the good work
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl, ![]() |
#84 |
Keep calm & mod on. =)
Your cable work, wood work & ideas are flipping awesome mate, wow.
#85 | |
Squid
Thanks! Thanks Waynio. Appreciate it alot! |
#86 |
Squid
Back piece. Will be painted in a darker brown
![]() Made some holes in the monitor backplate, for 3xDIN and AC ![]() All the wooden parts gather for some of that danish ![]() Ok, almost done now. A few layers of oil, maybe 3 days. Some cable work left, but I feel kinda empty inside already Modding syndrome I guess... Itīs been such a lovely project for me, hate to see it come to an end. But putting it together will be fun.Final assembly coming up, the weekend maybe ![]() ![]() ![]() Looking forward to it, big time! |
#87 |
Squid
Weight for monitor. The 30mm hole is for powerswitch
![]() I also finished the joystick ![]() ![]() ![]() And then I got an idea for front-/back-panel: More circiut-painting! ![]() GOLD!!! ![]() ![]() This is what it looks like with/without the decoration ![]() I donīt know. I like the golden circuits a lot. It gives the build itself another dimension IMO. But at the same time itīs not as aesthetically sparse and could maybe be a bit over-techish for my mom. Thoughts? |
#88 |
8-bit addict
Love this build as much as all the others you have done. I especially like your way of creating patterns. And I love PCB track art, it looks so damn good.
Btw.. excuse me if I have missed it in the text but when you stain the pattern, do you prep the surface before with anything to prevent the color from creeping under the pattern? Also how do you cut your patterns, laser? Btw, I bet your mom will love the gold, I think it's something in a womens gene Awsome build as always, yours are the best woodcomputer builds there is.
__________________
Project: ProtoHype (paused) Project: GET A LIFE (Complete) Project: Widescreen Projector(Complete) Guide: How to brush Aluminum |
#90 | ||
Squid
Regarding the stain pattern making I do not prep the surface at all. Iīm just very very careful using a dry sponge with very little stain on it. Same thing with spray, just a very thin layer. But preppin the wood might be a good idea. Got any suggestions? The stencils are made in a cutter plotter we have in school. Quote:
#91 |
Squid
Iīm still confused regarding the front... But maybe Iīll stick with the golden pattern til itīs finished and see then what.
#92 |
Ultimate Modder
This thread is full of WIN!!!!!
Mod on brother this looks more than amazing!!!!!!
#93 | |
Squid
#94 |
Squid
This is for lighting inside. Cheap LED-stripe in red. Sexy... I like sexy!!
![]() Had to mod the fan controller a bit and extend the knob 15mm ![]() 6mm wood plug, a toothpick and some glue did the trick! ![]() VGA... VGA... VGA... Sat more than an hour with this one. Hate 'em!! ![]() Toggle switch for monitors ON/OFF ![]() This is what the cable management looks like from under. Wonīt do it again, so Iīll pray for succes Also drilled 15mm holes for furniture pads.![]() Rubber pads ![]() ![]() Put the weight in place and screw it all together. ![]() Mmm... I think I like it!! ![]() ![]() ![]() Final monitor assembly tomorrow I hope. See you then!! |
#96 |
8-bit addict
That monitor foot turned out really nice. I totally dig the plain and simple LED + switch and how you have made them part of the circuit graphics. Cool idea
__________________
#97 |
So much eye candy but not overkill, just perfect mate, looks a beautiful classic piece, I agree with what gnu said. ![]() ![]() Ugh, just noticed the stars on this, this is easily a 5 star project.
__________________
Air Cube v2 and gaming tower (Fin Aug 2010) Stealthlow (Fin Sep 2011) Lean & Green - Modular Dual PC Paused Midlag Crisis Last edited by Waynio; 16th Feb 2012 at 21:25. Reason: Ugh, just noticed the stars on this, this is easily a 5 star project. |
#98 |
Making You Feel Old Since 2010
Why is it, that I only ever find these great projects of yours about 5 pages in!? I've missed out on so much.
![]() So I'll just comment on that I've seen on this page: Absolutely beautiful stuff! Your sleeving is fantastic and the rest is purely marvellous eye candy, a big well done!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#99 |
Supermodder
I just love this monitor stand!
#100 |
Fenrir The Wolf
This looks fantastic. Your mom will be so happy.
| Thread Tools | |
| View Mode | |
