Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 18th Jan 2012, 09:39   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Is it time for the hard disk to die?
Hard disks: should their days be numbered?
http://www.bit-tech.net/blog/2012/01...d-disk-to-die/
brumgrunt is offline   Reply With Quote
Old 18th Jan 2012, 09:55   #2
Cei
pew pew pew
Cei's Avatar
Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.
HDs will be around for a good while yet, simply due to capacity and price for that capacity.
My gaming PC has a 60GB SSD and a 500GB mechanical drive - I'm using the SSD almost to capacity (due to BF3 install), and the 500GB drive is 2/3 full due to Steam. As such, if I was to move to an SSD only solution, I'd need a 60+512GB setup (320+60 is too small) - a very expensive proposition.
This is without considering other media types. My main workstation has a 120GB SSD for boot, but then has another 8TB of spinning disk space. Add in the 4TB NAS and you start to get the picture. Even if SSDs halved in price, which they will over time, they are still going to be much more expensive than mechanical storage.
From where I sit, an SSD+HD set up is the best possible solution - you get the speed of the SSD when you want it, but can pile your data on to a cheap drive .
SSDs will take over, eventually, but it's going to take a long while to get there, simply due to the sheer capacity of mechanical drives.
EDIT: Saying all that, I can foresee SSD only in laptops in the very near future. We've always been used to lower capacity drives in laptops (they're still only just struggling to hit 1TB, and I remember when 80GB was pretty reasonable), so people will accept a smaller SSD. My MacBook Air has a 256GB drive for starters, which I'm finding is plenty for mobile use.
__________________
Join the BitSec organisation in Star Citizen! | Fleet Roster
i7 3770K | Asus RoG Maximus V Gene | 16GB 1866Mhz Vengeance | Crucial M4 256 & Samsung EVO 500 | Corsair H105 | Corsair AX860 | GTX 1080 FE | Air 240
i5 4670K | Asus RoG Maximus VI Impact | 8GB 1866Mhz Vengeance LP | Samsung 840 EVO 128GB | Noctua NH-U9B SE2 | GTX 770 SC 2GB | EVGA Hadron Air
Cei is offline   Reply With Quote
Old 18th Jan 2012, 10:06   #3
User-sam
The force is strong with this one.
User-sam's Avatar
User-sam is a Super Spamming SaiyanUser-sam is a Super Spamming SaiyanUser-sam is a Super Spamming SaiyanUser-sam is a Super Spamming SaiyanUser-sam is a Super Spamming SaiyanUser-sam is a Super Spamming SaiyanUser-sam is a Super Spamming SaiyanUser-sam is a Super Spamming SaiyanUser-sam is a Super Spamming SaiyanUser-sam is a Super Spamming SaiyanUser-sam is a Super Spamming Saiyan
Off with there heads!
User-sam is offline   Reply With Quote
Old 18th Jan 2012, 10:09   #4
alpaca
llama eats dremel
alpaca's Avatar
alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.
Usually, your blog posts are good, Antony, but this one... It does not say anything. It does not add anything to the SSD vs HDD discussion.
__________________
my English may not be as good as I think it is...
alpaca is offline   Reply With Quote
Old 18th Jan 2012, 10:14   #5
scott_chegg
Hypermodder
scott_chegg's Avatar
scott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on you
The increasing popularity and ease of use of home NAS systems will help keep traditional spinning disks going for a long time. The enterprise storage sector still use disks extensively for primary storage, backup and archive. Modern storage systems have automatic tiering where your storage array will have a bunch of SSD as tier 1, a bunch of 15K spinners for tier 2 and a massive bunch of SATA for tier 3. Data will be moved up and down the tiers depending on access frequency.
I have 3 ssd's and a 500 GB spinner in my main rig. 64 GB crucial sata 3 for OS and apps, 60 GB OCZ vertex 2 for selected game installs and steammover target, 30 GB corsiar ssd that I use as a fast scratch drive and the big spinner for main data storage.
__________________
My System: i5 2500K @ 4.7Ghz | MSI P67A-GD65 (B3) | 16GB Crucial Ballistix Sport 1600MHz | Corsair H-50 Push-Pull with Silent Eagle 2000's | Silverstone Raven RV03 | EVGA 670 FTW | Dell SP2309W | Antec 750W TruePower Blue | Win 7 x64 | Crucial 64GB C300 for OS | Samsung 830 256GB for Active Games & a 1TB Samsung for Steam. Perphiperals: Roccat Kone+ Max V2 | CMStorm Quickfire Pro with Cherry Reds | Cyborg F.L.Y 5 stick for flying and a Logitech DF GT for driving.
scott_chegg is offline   Reply With Quote
Old 18th Jan 2012, 10:43   #6
SpAceman
Supermodder
SpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpit
My 500GB Steam library will be on mechanical for some time yet. Will possibly get an SSD for my next build.
__________________
i7 4770K | Asus Z87-Pro | 16GB Gskill DDR3-1866 | EVGA GTX 760
Silverstone Raven RV02 | Coolermaster V8 | Crucial M4 256GB | Corsair TX750
Dell U2412M | LG W2253TQ | Ducky DK9008 Pro PBT MX Cherry Greens | Naos 7000 | Logitech X-540 5.1 | Logitech G930
SpAceman is offline   Reply With Quote
Old 18th Jan 2012, 10:45   #7
billysielu
Multimodder
billysielu has yet to learn the way of the Dremel
Hard Drives will die when SSDs stop dying. Nowhere near stable enough for the price.
billysielu is offline   Reply With Quote
Old 18th Jan 2012, 10:58   #8
countstex
Minimodder
countstex's Avatar
countstex has yet to learn the way of the Dremel
Perhaps the answer lies elsewhere. At present we still require quite a lot of local storage on our systems, keeping HDDs popular. But in a future were cloud computing is far more prevalent an local storage needs are massively reduced then pure SSD devices become more viable. Technically you could do this now if we weren't the performance freaks that most of us on this site are. You could quite easily run Win7 from an SSD and use Google Apps, Flickr, YouTube, Onlive and various other online/cloud solutions and have very little need for local storage.
__________________
Twitter | Facebook
countstex is offline   Reply With Quote
Old 18th Jan 2012, 11:05   #9
Bungletron
Ultramodder
Bungletron's Avatar
Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.
Quite right, SSD and cloud storage might be viable but now internet connection reliability and bandwidth become the issue, something we lagging on (lag! ) in the UK.
__________________
Main rig: i7 2600K + Corsair H75 | P8Z77-M Pro | 8GB DDR3 | MSI GTX 970 4G + NXZT G10 + Corsair H75 | Xonar DX | 840 EVO + 850 EVO RAID0 1TB stripe | F4 2TB | NXZT Hale 650W | Carbide 240 Air | U2713HM
HTPC: A10 5800K | GA-F2A75M | 8GB DDR3 | EVGA GTX 950 SuperClock+ | Be Quiet! TopFlow | M4 512GB | F4 2TB | Lian Li PC-V355B
Server: Xeon E3-1240L v3 | ASRock E3C226D2I | 16GB ECC DDR3 | Fujitsu D2616 RAID | Seagate XT 500GB | MX100 256GB | 5 x 4TB HDD (RAID 5) | SilverStone DS380
Bungletron is offline   Reply With Quote
Old 18th Jan 2012, 11:07   #10
steve30x
Multimodder
steve30x has yet to learn the way of the Dremel
When I can get a 250GB SSD for 125 euro or less then that will be the day I will move from HDD. SSD's are too expensive at the moment and I am hoping they go low enough in price soon , because I want to have my computer as quiet as possible and my three HDD's are the loudest part of my computer.
__________________
CPU : Intel Core I5 760 @ 3.9GHZ
GPU : Palit GTX580 (with palits dual fan cooler)
Motherboard : Asus Maximus III Gene
RAM : 4GIG Kingston ValueRam 1333MHZ @ 1224mhz
Power Supplie :Corsair HX1000
steve30x is offline   Reply With Quote
Old 18th Jan 2012, 11:16   #11
yodasarmpit
No longer the other Brett.
yodasarmpit's Avatar
yodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyan
We live in a high definition world, we have ever increasing data storage requirements, and until SSD's can be produced and sold for less than the mechanical equivalent you won't see a massive sea change.
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home"
yodasarmpit is offline   Reply With Quote
Old 18th Jan 2012, 11:32   #12
Siwini
What is 4+no.5?
Siwini's Avatar
Siwini has yet to learn the way of the DremelSiwini has yet to learn the way of the Dremel
Sure if you start selling reliable SSD 1TB for $100 but we all know that’s not going to happen for another decade, so no HDD will stick around.
__________________
Win7 Pro 64Bit | I7 860 @4.0Ghz XSPC RS240 | Gigabyte P55-UD5 | 8GB G.Skill 1600 7 8 7 24| Crucial C300 64GB SSD | 2x 1TB Samsung F3 RAID0 | Asus GTX 570 | Asus Xonar DS 7.1 | Logitech Z-2300 | Corsair CMPSU 850 ATX | Xigmatek Utgard | Dell U2410
Siwini is offline   Reply With Quote
Old 18th Jan 2012, 11:43   #13
Scarlet0pimp
Minimodder
Scarlet0pimp has yet to learn the way of the Dremel
I'm having great results personally using the z68 chipset and the Smart Response Technology (SSD Caching). Using 640Gb IBM WD and 64Gb M4.
My boot time is fast 34 seconds and my popular games load very fast in comparison to my old system. In worlf of tanks i'm normally the first in to a map and have to wait 20 seconds before the game timer even starts to count down.
Scarlet0pimp is offline   Reply With Quote
Old 18th Jan 2012, 11:46   #14
Jim
Ineptimodder
Jim is the Cheesecake. Relix smiles down upon them.Jim is the Cheesecake. Relix smiles down upon them.Jim is the Cheesecake. Relix smiles down upon them.Jim is the Cheesecake. Relix smiles down upon them.Jim is the Cheesecake. Relix smiles down upon them.Jim is the Cheesecake. Relix smiles down upon them.Jim is the Cheesecake. Relix smiles down upon them.Jim is the Cheesecake. Relix smiles down upon them.Jim is the Cheesecake. Relix smiles down upon them.Jim is the Cheesecake. Relix smiles down upon them.Jim is the Cheesecake. Relix smiles down upon them.
Even now, as a 'performance freak', it's more than possible to do basically the same thing with a pure SSD device plus a NAS.
Jim is offline   Reply With Quote
Old 18th Jan 2012, 12:02   #15
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.
I'll let the sloppy grammar pass and say that was actually pretty amusing :-)
__________________
mclean007 is offline   Reply With Quote
Old 18th Jan 2012, 12:03   #16
countstex
Minimodder
countstex's Avatar
Indeed, but then that's HDDs in your NAS right?
__________________
Twitter | Facebook
Old 18th Jan 2012, 12:05   #17
countstex
Minimodder
countstex's Avatar
Maybe I'm spoilt being on Virgin (he says the night after a major outage) but I loose internet maybe once per year, and can get up to 100Mbit if I choose to pay for it. I don't, I pay for 10Mbit as that fits my needs. But I could. Internet access would be towards the top of my check list whenever buying a new property to live in.
__________________
Twitter | Facebook
Old 18th Jan 2012, 12:07   #18
Indra EMC
Like Modding my PC
Indra EMC has yet to learn the way of the Dremel
I didn't think so, because :
1. SSD still too damn expensive
2. HDD Price is high, but it begin to decline because WD and Seagate factory on thailand now can operate.
3. SSD capacity is still too small compare to HDD capacity.
if manufacture can make an SSD as cheap as HDD, and also have huge capacity (1 TB / 2 TB for example) but 10 times faster than regular HDD, i can say "HDD will die" just like Floppy disk when flash drive take over.
Indra EMC is offline   Reply With Quote
Old 18th Jan 2012, 12:32   #19
NethLyn
Hypermodder
NethLyn's Avatar
NethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for president
Interesting cross-comparison but CRT to TFT was more about the means of disposal and waiting for dead pixels to stop being an issue - now you only have to worry about them if a flat screen's damaged in transit compared to when they launched, and only the IPS screens are expensive anymore, but it's taken a good decade.
SSD? Not quite yet. We'll have to wait for April to see what the HDD supply chain looks like, but the floods might still put the kibosh on the traditional price crash for Easter unless production's fully restored by then. Whenever it recovers, you know they'll sell stackloads, can't wait to get back to WD.
NethLyn is offline   Reply With Quote
Old 18th Jan 2012, 13:04   #20
theprodigalrebel
What's a Dremel?
theprodigalrebel has yet to learn the way of the Dremel
My boot drive is a Seagate 7200.12 500GB disk - 235GiB used (that's just Program Files, Windows and Games). About 50% full. (All UserData - Docs/Pictures/Music/Videos/PST - points to a 2TB drive. Pr0n has a dedicated 1TB drive. Backups, copies of large redistributables, installers and disk images that I would not want to download again/lose-the-DVD are on another 500GB drive)
However, if I wanted every game I own (I still have a lot of older games that I haven't reinstalled since my last clean wipe of the OS drive) to be readily available and still have some breathing space for future installs, I would want nothing smaller than 360GB.
I remember 10 years ago, when the family computer had a 40GB drive and every time a new game came out, I would have to spend a lot of time figuring out what movies/pr0n to delete, what game to uninstall, what was valuable/expendable etc. I do not want to do that again (even if it means shuffling data between disks as opposed to outright deleting it).
Even when SSDs come down to 1 USD per GB in Q3 of this year (as predicted by lots of people), ~$350 would still be a lot of money for storage for a mild improvement in the user experience.
theprodigalrebel is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
