Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 19th Jan 2012, 19:51   #1
TheOneReedy
What's a Dremel?
TheOneReedy has yet to learn the way of the Dremel
Freezing ever since SSD installed
Hi everyone i am new to the forums, ever since i install a new OCZ 60GB Agility 3 SSD i have been getting these constant freezing, it starts by the program not responding but the mouse still moves then it just hangs and does not respond, if i have sound playing at that time through the speakers it just plays the same bit in a loop, i have waited 10 minutes to see if it catchs up but to no avail, then i have to restart all together, it happens when browsing the web, while playing a game 10 minutes to 1 hour in, it has happened when the computer has just got to the desktop and is loaded, i have made sure TRIM is enabled made sure i turn SSD defrag off, tryed a different sata port, i operating system is installed onto the SSD and all my other files on the HD.
My specs
gigabyte 880GM-UD2H
MSI HD TWIN FROZR III POWER EDITION
AMD Phenom II x6 1055t @ 2.8ghz
4GB of Kingston HyperX blu 4 GB : 2 x 2 GB Memory - DIMM 240-pin - 1600 MHz ( PC3-12800 )
Corsair 650watt psu(cant remember exactly and don't have the box anymore)
Western digital 232GB Harddrive dont know a specific name.
thank you.
TheOneReedy is offline   Reply With Quote
Old 20th Jan 2012, 16:20   #2
PhoenixTank
From The Ashes
PhoenixTank's Avatar
PhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the Dremel
Have you looked for a firmware update for your SSD?
__________________
i7 980x @4.27Ghz | Asus Rampage 3 Extreme | Corsair H50 W/ 2x Sharkoon Silent Eagles SE
6 x 2GB Corsair Dominator GT (CMT12GX3M6A1866C9 kit) | 2x Samsung F3 1TB | 2x Crucial C300 256GB (Boot & Steam)
XFX 5970 BE | HP ZR24w | 32' Samsung B550 | Formac Gallery Xtreme 20.1" MVA
Scythe Kaze Server (fan controller) | Lian Li PC-A77FB | W-75BT Side Panel Window
PhoenixTank is offline   Reply With Quote
Old 21st Jan 2012, 18:32   #3
Pookie
Need's a Holiday!
Pookie's Avatar
Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!
Try unindexing the drive followed by a reboot and reindex again. Also was this a fresh install or did you clone from another drive?
__________________
Fractal R4/ GA-X58A-UD3R / i7 920@3.8Ghz / Corsair H60 (2013 Model) with 2 x Corsair SP120 / Corsair Force GT 120 SSD /Sapphire 6950 (6970 mod) / 12GB (3x4GB)Corsair Dominator 1600mhz with Airflow Kit / AOC i2757fm 27" IPS Monitor
http://www.compu-care.co.uk/
Pookie is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
