Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 23rd Jan 2012, 09:20   #1
TobletDanillio
Supermodder
TobletDanillio has yet to learn the way of the Dremel
Needed: Mini ITX
Hello lady and gentlemen,
I'm in the market to find a Mini ITX motherboard for use in my car .
I have a custom case and PSU.
I would like this Mini ITX motherboard to have;
dual core atom or I3
Passive heatsink
DDR3 RAM min of 2GB
Two Sata2 connectors
Two USB2
VGA or DVI output will be using integrated graphic.
This will be used for movies for my son or internet browsing for the wife.
The output doesnt need to display 1080p but the higher the better as I haven't got the displays and I will get them when I know what output is needed.
thanks for your help
__________________
Xigmatek ELYSIUM | I7 2600K | Be Quite Dark Rock Pro | Asus P8P67 Pro | G-Skill RipjawsX 8GB 1600 MHz | MSI 560GTX-Ti Twin Frozr II 2GD5/OC | Samsung F3 1Tb | Samsung 830 256GB
TobletDanillio is offline   Reply With Quote
Old 23rd Jan 2012, 11:17   #2
Bindibadgi
Omnipwntent
Bindibadgi's Avatar
Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.
Intel D330 mini-ITX, fully passive cooling (replaced coolers with Zalman ones)
Two SATA + PCI SATA card with 5 ports
No DVI out but it does have VGA out.
2GB DDR2 (single low profile DIMM)
I'm not sure if it can do that much multitasking though - most Atom boards cannot. I've also got a muuuuuch more powerful quad core H55 system too, but you'd need to change the CPU to Clarkdale instead of Llynfield.
__________________
Slash88: That kettle video just made me go death thanks.
Fizzban: And it is being panda'd to..lame.
Bindibadgi is offline   Reply With Quote
Old 23rd Jan 2012, 11:47   #3
TobletDanillio
Supermodder
what that called?
__________________
Old 23rd Jan 2012, 12:33   #4
MSHunter
I *am* a Dremel
MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!
I would go with an AMD E-350 or 450 ITX board, zotac make some all-in-one systems with this board otherwise would take an Asus board.
http://www.amazon.co.uk/Asus-E35M1-I...325242&sr=8-11
http://www.amazon.co.uk/ASUS-E35M1-I...325242&sr=8-10
Hope this is helpful
__________________
PC: Silverstone TJ08B-E, 2500K, Corsair H80, 120GBVertex 3 MAX IOPS,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711
PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X
Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1
MSHunter is offline   Reply With Quote
Old 23rd Jan 2012, 19:30   #5
TobletDanillio
Supermodder
Asus E35M1-I DELUXE Zacate
I love the look of this one but I have no idea about AMD and it thats any good
__________________
Old 23rd Jan 2012, 19:33   #6
TobletDanillio
Supermodder
Review of E-350 vs an atom
__________________
Old 23rd Jan 2012, 20:20   #7
MSHunter
I *am* a Dremel
review is misleading or out of date or its a codec issue because a friend of mine uses the Asus netbook with E-350 and plays 1080p without any issues. The main benefit is out of order execution. That and with up-to-date drivers / codecs it is much faster then Atom.
__________________
Old 23rd Jan 2012, 21:57   #8
TobletDanillio
Supermodder
Very good to know I will be saving up for this then
Send from HTC DESIRE HD
__________________
Old 23rd Jan 2012, 23:42   #9
Mac_Trekkie
Source Engine's #1 fan!
Mac_Trekkie's Avatar
Mac_Trekkie has yet to learn the way of the DremelMac_Trekkie has yet to learn the way of the Dremel
Woah woah woah don't discount the VIA Nano X2 based system! It's faster than the Atom and E-350 by a ton! It also has better multitasking than either. Options for boards are slightly limited for now as it's not in mass circulation yet, you're pretty much limited to the VIA EPIA-M900, which is actively cooled. It's also more expensive than an Atom or AMD-APU based system, but it will play 1080p media well, has VGA and HDMI out and has an extraordinarily low power draw. But it isn't passive so I guess that puts it out of the question so I guess do discount the Nano X2 based system.
__________________
The Brass Balls: i7 870 @ 4.2ghz | Cooler: CM Hyper 212+ | 8gb G.Skill Ripjaws DDR3 1600 | GPU: ZOTAC GTX 560 Ti 448-core 1,280mb | Motherboard: MSI P55-GD65 | Case: ThermalTake Element G | ThermalTake 850w PSU | Samsung Spinpoint F3 1tb | Corsair Nova 32gb SSD
Mac_Trekkie is offline   Reply With Quote
Reply
Tags
car dvd player, car electronics, mini itx
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
