Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 24th Jan 2012, 01:07   #1
GeorgeStorm
Aggressive PC Builder
GeorgeStorm's Avatar
GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.
Is a 128gb SSD enough?
As above basically, I'm having a bit of a move around computer wise, and I'm upgrading my media pc to become me new main pc after selling my current one.
I'm considering using just a 128gb C300 as my boot/everything drive, would this be enough?
This is with all media on 4 2tb drives also in the PC.
So would just be OS, games, programs etc on the SSD.
I'd then put my OCZ Core V2 30gb SSD in my laptop, since I don't do a lot on there apart from browse, and it would hopefully make it a little snappier
Other option is to use the OCZ as my boot drive, then use the C300 for programs/games.
But then I think the PC would feel slower, since the OCZ is a slower SSD in comparison to the C300.
I also have a 64gb C300, but was thinking of selling that to go towards funding my upgrades to the media pc (2 new 2tb drives, new psu, new gpu)
Opinions?
GeorgeStorm is offline   Reply With Quote
Old 24th Jan 2012, 02:14   #2
IvanIvanovich
будет глотать вашу душу.
IvanIvanovich's Avatar
IvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming SaiyanIvanIvanovich is a Super Spamming Saiyan
Really only you can answer if it is big enough for your usage scenario. However 120/128gb size point is usually the minimum baseline for best performance, though most are optimized for best performance at 256gb+. Using a small drive for boot and a larger newer drive for static data would be a waste. That needs to be the other way around.
I am looking to step up to larger drive as well, as I keep running into issues with some of these newer games pushing 30gb size requirements... let alone the higher iops that come with 120gb+ drives. Doing lots of homework on what is around now, and also around the corner for next quarter.
__________________
intel xeon e5-2630l @2.7 | gigabyte g1.assassin.v2 | 16gb mushkin blackline 2133 | evga gtx970 ssc | kingston hyperx predator 240gb | seagate 600 240gb | seasonic ss460fl2 | nzxt s340 | gh60 keyboard | logitech g700 | achieva shimian qh270
IvanIvanovich is offline   Reply With Quote
Old 24th Jan 2012, 02:30   #3
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.
I wouldn't consider it enough. I'm waiting for reasonable prices on 512GB SSD's before thinking of buying one.
I couldn't care less about boot speed since my PC goes to sleep more often than it ever actually gets turned off. Fast data read and write are what SSD's are good for and if it can't actually store enough data to make a difference it's worthless.
__________________
The Box:i7 2700K@5.3GHz|EK Supreme LT+Coolstream XT 360|16GB HyperX DDR3@1866MHz|EVGA GTX780 ti+EK FC780ti|MSI P67A-GD55||M5 512|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Perixx MX2000 + Intuos 4M
Audio: PC->TosLink->TEAC UD-501->Fostex TH600|InEar LivePro 3|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 24th Jan 2012, 05:34   #4
microsoftPerson
Hypermodder
microsoftPerson has yet to learn the way of the DremelmicrosoftPerson has yet to learn the way of the DremelmicrosoftPerson has yet to learn the way of the DremelmicrosoftPerson has yet to learn the way of the Dremel
I bet you'll be waiting for quite a while Tangster but I wish for that day to come ASAP as well. On the other hand, I find 64GB is enough to shred at least 10 minutes off of a long work day in the time saved opening/closing various production programs. 6 or 7 seconds here and there really add up. Also - when you have the ability to open programs so quickly it becomes less of a pain to close all the programs other than the one you are using to dedicate RAM/CPU for renders.
All on ~45GB: Windows 7, Microsoft Office, Steam & Counter Strike 1.6, Illustrator, Photoshop, Flash, Cinema 4D, FTP programs, several websites, quite a few files/renders. Of course... you can still have your HDD. A few settings were changed to make my Windows installation smaller but I also still have super-fast hibernation enabled which is great for my laptop.
__________________
ASRock Z97X + 16GB RAM
MSI GTX 560 TI Twin Frozr II + 2x840EVO 250GB SSDs (RAID0)
Samsung F3 Spinpoint 1/2 TB + 2TB + Fractal Design Define R3 [black pearl]
microsoftPerson is offline   Reply With Quote
Old 24th Jan 2012, 10:19   #5
KryptiK
Minimodder
KryptiK has yet to learn the way of the DremelKryptiK has yet to learn the way of the Dremel
Simple answer is yes,
because 128Gb is enough for the OS + a few games + a few applications and your 4x2TB should be used for general files/media. You could also get a mobo that supports SSD as a cache and make your 8TB feel like a huge SSD.
I personally only have a OCZ Vertex 3 60GB as main drive and a 1TB as general storage and this setup works great on my budget.
KryptiK is offline   Reply With Quote
Old 24th Jan 2012, 11:34   #6
richythomas
Multimodder
richythomas has yet to learn the way of the Dremelrichythomas has yet to learn the way of the Dremelrichythomas has yet to learn the way of the Dremelrichythomas has yet to learn the way of the Dremelrichythomas has yet to learn the way of the Dremelrichythomas has yet to learn the way of the Dremel
I've been using a Crucial C300 128GB SSD in my main desktop computer for a year and a half now and it's been more than adequate except that I installed Steam and all games onto a 300GB WD Velociraptor (this will change as I've bought a 240GB SSD). All personal data is on a 1TB Samsung HDD.
Windows 7 HP with all of its updates, Visual Studio Professional 2010, Adobe Web Premium CS5, Microsoft Office Plus 2010 (inc. Visio and Project) as well as a number of other utilities and I have around 50GB free. The same applications are on my laptop and that is running with 35GB free from a Corsair F120 SSD but that does have some data stored on it too and a second profile for my wife with her storing some data on it too.
As others have said only you can decide whether 120GB is enough for your own circumstances.
__________________
CPU: i7 4970K Cooler: Corsair H100i RAM: 32GB DDR3 Corsair Vengeance 1,886MHz MB: ASUS Maximus VII Gene GFX: ASUS GTX 980 4GB STRIX Sound: Sound Blaster Z BOOT: Plextor 256GB M2 PCIE SSD SSD: 2 x 256GB Crucial M4 HDD: 2TB WD Green Case: Corsair 350D PSU: Corsair AX760 DISPLAY: 2 x Dell U2515H 2560x1440 OS: Windows 10 Pro
richythomas is offline   Reply With Quote
Old 24th Jan 2012, 11:51   #7
xaser04
Ba Ba Ba BANANA!
xaser04's Avatar
xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.
My desktop has a single 120GB Vertex 2E and I find it enough for general use + a few games.
I do sometimes wish it was bigger but I have most of my Steam games on an external HD so they can be loaded in 15 minutes or so if required.
I am waiting for 240/256GB SSD's to drop below the 200 mark so I can upgrade though. The 120GB will then be solely used as a Steam drive again with games loaded Ad Hoc.
I should note that all of my media, documents & misc downloads are on my NAS so my system drives only have to deal with the OS, programs, system downloads (drivers etc) and games.
__________________
Daedalus - Clevo P170SM | i7 4700MQ @ 3.4Ghz | GTX780M 4GB @980/6000 | 16GB DDR3 | 17.3" 1920x1080 |
ZPM "VIVE" Mini - Fractal Node 202 | i7 4770S | GTX1070 | 8GB DDR3 | 4K TV / HTC VIVE |
Consoles / Retro - PS4 Pro | PS4 | Xbox One x2 | Dreamcast x2 (VGA) | WiiU | Retron5 |
xaser04 is offline   Reply With Quote
Old 24th Jan 2012, 12:30   #8
GeorgeStorm
I've currently got a 64gbC300, and a 640gb WD drive,
Got 15gb left on the SSD, and 510 (out of 596 usable) left on the WD.
So I reckon the 128gb will be enough for me
I don't have many games that I play, and can uninstall/reinstall games if needed, since I tend to go through phases of playing them.
Thanks for the advice
Old 24th Jan 2012, 12:39   #9
bdigital
Is re-building his PC again
bdigital's Avatar
bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.
Steam mover is your friend!
Ive got loads of games installed but only a choice few on the ssd itself. Steam mover is so useful.
__________________
My photography website: http://www.polarityphoto.co.uk Please share! || Follow me @polarityphoto on Twitter|| My Flickr ||Facebook||
Check out my Apline White TJ07 - Case Mod and Water cooled build. http://www.flickr.com/photos/6188486...7631486959032/
bdigital is offline   Reply With Quote
Old 24th Jan 2012, 12:40   #10
GeorgeStorm
My aim is to only install things on the SSD, otherwise I'll end up picking another HDD probably, my OCD won't let me install stuff onto the 2tbs, they're media drives :P
Old 24th Jan 2012, 12:45   #11
j4mi3
Ultramodder
j4mi3's Avatar
j4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysis
yes if you plan to put applications as well as os on it, imo that is the minimum
i regret very much buying a 64gb ssd instead of a bigger one, i can only put like 5 or 6 big apps on it as well as windows
__________________
BF3: Pr0_snipe
i7 2600k @ 4.6 | Asus P8P67 Deluxe | Asus GTX 670 Direct CUII TOP | Gskill Ripjaws x 16gb 2200mhz | Noctua nh-d14 | Antec 1200 | Enermax Revolution87+ 850w | Samsung 840 Pro 128gb | Crucial M4 64gb | WD Caviar Black 500gb | Dell U2711 |
j4mi3 is offline   Reply With Quote
Old 24th Jan 2012, 14:58   #12
Yslen
Lord of the Twenty-Seventh Circle
Yslen's Avatar
Yslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming Saiyan
I'm using a 64GB SSD with Windows, League of Legends, Battlefield 3 and all my programs (photoshop etc) on it. 10GB or so left over.
__________________
Asrock Z77e-ITX - Intel i5 3570k - Corsair H100i - G.Skill Ripjaws X 2133MHz - MSI GTX 970 - Crucial M4 - 530W ThermalTake SS PSU - Corsair 250d - LG IPS231P - Logitech G302 - Many, many keyboards
Take a look at my Photography portfolio, here.
Yslen is offline   Reply With Quote
Old 24th Jan 2012, 15:24   #13
yassarikhan786
Ultramodder(Not)
yassarikhan786's Avatar
yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.
I've got all my games on a HDD, with the OS and a few essential programs on the SSD.
__________________
|| Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: Gigabyte GTX 580 Super OC || Memory: Mushkin Blackline 8GB || SSD: Corsair Force 3 120GB || HDD: WD Caviar Black 2TB || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v || Keyboard: Logitech G510 || Mouse: Razer DeathAdder
yassarikhan786 is offline   Reply With Quote
Old 24th Jan 2012, 23:03   #14
Cleggmeister
Of reasonable knowledge...
Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.
Yep, 128 is fine for your OS and apps, plus a few games if you like. I've been running a 120GB SSd for a couple of years and never used more than 50%.
__________________
Pooting: Antec 300, P6T SE, i7 920 (3.20), Corsair F120SSD, 3x1TB HDD, 9Gb (1600XMP), GTX560Ti 2Gb (880/1760/2100), Win7 x64. Raspberry Pi B with OpenElec.
Grooving: Linn LP12, Klimax DS, Klimax Kontrol, Aktiv Akubariks. Linn Sekrit DSI +104's + Velodyne sub
Watching: Raspberry Pi running OpenELEC to 50" Panasonic.
Serving: HP Proliant Microserver N40L running Openmediavault.
Cleggmeister is offline   Reply With Quote
Old 24th Jan 2012, 23:31   #15
mystvearn
any-may
mystvearn's Avatar
mystvearn has yet to learn the way of the Dremelmystvearn has yet to learn the way of the Dremelmystvearn has yet to learn the way of the Dremelmystvearn has yet to learn the way of the Dremel
How about an OCZ synapse? Its not an SSD. More like a huge cache
mystvearn is offline   Reply With Quote
Old 25th Jan 2012, 03:18   #16
donok
Every Little Helps .....
donok's Avatar
donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.donok is the Cheesecake. Relix smiles down upon them.
I waited until I saved up more and in that time prices fell alot. Then I got a 256gb SSD and I use it for everything on my pc. Windows, office, games. Recent documents, photos etc. the rest is in a Synology nas unit which houses 3x 3tb Hdds with 2 spaces empty. This runs off my wired network so is pretty fast. I can watch a hd movie via nas both upstairs and downstairs simultaneously.
I choose this way for Afew reasons.
- small pc case due to lack of internal HDD
- raid redundancy on the nas drive
- remote login to access files.
- I will also be using it for CCTV as soon as I get brave enough to mount the camera outside up the ladder.
__________________
The Cookie Monster
donok is offline   Reply With Quote
Old 25th Jan 2012, 03:26   #17
IvanIvanovich
Oh, to sum up my research... for current available, the mushkin Chronos Deluxe is a top contender. Yes, expensive, but sandforce controller and 32nm Toshiba async toggle nand is a pretty good combo with potential for 560mb/s and 90,000 iops. It may not be king of the hill in raw performance, but a decent price point and 32nm toggle nand is a HUGE point over much of the (affordable) competition.
For next gen OCZ looks like they have some potentially interesting cards up their sleeve with a new indilinx controller with a speculated 115,000 iops pushing 590mb/s. It's hard to speculate on next gen real world performance advantages, but it is just around the corner...
__________________
Old 25th Jan 2012, 08:49   #18
Cookie Monster
Your cookies belong to me!
Cookie Monster's Avatar
Cookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming Saiyan
This roughly, but I don't game.
I run a 120Gb OCZ with Win 7, Office, Adobe CS5 Master collection, few different browsers, then your generic iTunes, CD burning software ect and I still have 50Gb left.
__________________
Big Bird - Arc Midi | 790fx-GD70 | 955BE | 8Gb RAM | 2 x HD4890 | 120Gb SSD | 3.5Tb HDD's | 3 x Dell U2412M
Cookie Monster is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
