Modding The Bit-Tech case mod index
Discussion in 'Article Discussion' started by brumgrunt, 24 Jan 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Jake123456
    Jake123456 Surprise!
    25 Jan 2011
    This is brilliant, excellent stuff! I hope my upcoming hopefull Raspberry Mod can get in here...;)
  3. KryptiK
    KryptiK What's a Dremel?
    12 Jan 2012
    no scratch build index?
  4. matee
    matee What's a Dremel?
    12 Feb 2003
    Great idea!
  5. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Brilliant idea !
  6. brumgrunt
    16 Dec 2011
    All Antony's, and my thanks to him. We'll be keeping it up to date, too.
  7. David
    7 Apr 2009
    I agree - excellent idea. :thumb:
  8. Jake123456
    25 Jan 2011
    Just a quick question Brumgrunt, will this be a Tab on the on the top?
    I'm finding this hard to explain....In the modding tab, where Case Mod, Guides and Mod of Month and so forth, will this Case Mod Index be a option in there? For easy access?
  9. alain-s
    alain-s Minimodder
    12 Jan 2011
    lovely idea looking forward to brows true the completed mods.
  10. Combatus
    16 Feb 2009
    We'll certainly look at integrating it onto the site somehow, probably exactly how you described. We'll see how popular it becomes first. I've attached stickies to both the project log and modding forums too.
  11. greypilgers
    greypilgers What's a Dremel?
    23 Jan 2011
    A really simple, but really brilliabnt idea. Give that man a biscuit!
  12. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    Excellent way to showcase the mods on here etc..
    does it exclude custom builds though?
  13. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Does there have to be a log? Ive finished my tj mod but I didnt keep a comprehensive log of its progress
  14. Parge
    16 Jul 2010
    Wowza, this is just excellent!
  15. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    What a wonderful idea. Just a thought though, are you using the Tags on the forum posts? If you were to have a selection against each project log etc where you specify these tags from a defined list, you could get these pages to be generated dynamically - Saves someone having to maintain them.
  16. Vo0Ds
    Vo0Ds Fake potato
    6 Feb 2004
    Your talking loco and I like it! (Get some Fractal up!)
    Agree a scratch build section would be a great source of inspiration; possibly split by mobo size?
  17. Combatus
    16 Feb 2009
    It does unfortunately - you need a common feature such as case manufacturer or case model - something that scratchbuilds by their nature don't have as they're custom designs! They would only benefit from a gallery or list of projects although you perhaps you could use categories such as mini PC, HTPC, water-cooled tower etc. If anyone has any ideas how we might approach things from a scratchbuild point of view, do let me know!
    . People need to see how you built your project - that's the idea - the index isn't a way to showcase your work, it's purely a source of information.
    Tags are a good idea but unfortunately, very few people use them. If you search for SilverStone or Antec, only a fraction of projects actually show up - even less if you specific exact case models. If we made people specify these things prior to posting a project log - case make, model etc, that could work.
  18. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Im first my project is there i cant believe it!!!!
    Although i have to point out mine isnt watercooled.
  19. andrew8200m
    4 May 2009
    Why not just add a "Custom" as a brand or make. Easy to distinguish the difference that way but it does exclude the better builds as hardly any of the case mods will ever actually match a scratch build of the highest quality.
  20. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    Like the idea. It would be cool to have a "mod database" where you can search by case. Hope to see more of this in the future!
    yassarikhan786 likes this.
