Closed Thread
Thread Tools View Mode
Old 24th Jan 2012, 08:47   #1
Combatus
Custom PC/bit-tech modding sections
Combatus's Avatar
Combatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for president
Case Mod Index and Scratchbuild Index - submit your projects!!
We've recently launched the bit-tech case Mod Index, which is a database of mods, sorted by case manufacturer and case model. The idea behind it is that if you're looking for inspiration with your case when it comes to modding or installing water-cooling hardware, you'll be able to quickly find projects that have used your particular case.
We've also launched the Scratchbuild Index - you guessed it - an index of scratchbuilds. They sorted by motherboard size, case type and materials used. Wanna see what mini-ITX cases people have made? Maybe all the cases that use composite materials? Head over to the Scratchbuild Index to see.
We need your help to grow the databases so if you'd like submit your mod or scratchbuild, email us at modding@bit-tech.net with 'Submit My project' in the subject line.
With mods, they must be complete with noticeable modifications (these can include spray paint/powder-coat or installed water-cooling hardware. You'll also need to include the following information:
  • Forum name
  • Case (make and model)
  • URL to your project log (which must be in bit-tech's project log forum)
  • Whether or not your PC is water-cooled
With scratchbuilds we need:
  • Your Forum name
  • Project name
  • Motherboard type (ATX / Mini-ITX / Micro-ATX / Other)
  • Case type (tower/cube/desk/HTPC/Other
  • Primary material (acrylic/metal/wood/composite/other)
We'll be adding to the databases regularly so be sure to check back to see all the new projects!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES! | Mod of the Month March 2013 is here! Vote now!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline
Closed Thread
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
