Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 25th Jan 2012, 16:40   #1
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
[Tute] Remove foam pad from Sunbeam fan controllers
Or, anything that has this type of insulating foam over the circuit board.
So, i got a 3 channel RheoSmart for playing around with to see if it will 'fit' into my upcoming mod, but i couldnt have that horrid grey foam lurking about, and simply covering it with acrylic wasnt going to work because its amazingly resilient and would bend the acrylic trying to smoosh it down.
Items needed:
fan controller
screw driver
rubbing alcohol (i have 91% on hand, but the regular 70% should work)
cotton swabs
patience, it may take up to an hour
The patient:
Pour enough alcohol onto the foam to fairly soak it, use your finger to spread it around, making sure it reaches the edges
I had the older 4 channel one that needed the same treatment for my wifes pc, so i started on it while the 3 channel soaked
Make sure you dont let the alcohol sit too long, itll start to evaporate, after about 5 minutes you should be able to just peel the foam off
It should look like this
Use additional alcohol and the swabs to clean the remaining glue residue (this stuff is pretty nasty, sticky and dries fast if not soaked) and youll end up with this
Enjoy!!
Furball Zen is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
