Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 26th Jan 2012, 21:31   #1
The_Crapman
Don't phone it's just for fun.
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
How to Get a FREE (sort of) Hard Drive and Other Small Parts.
Before I go on can I just state that THIS IS NOT A SCAM!!! I don't want you to click on a link to register at a website and I do not want any of your personal details. I'd also like to apologise in advance for the piss poor quality of the photo's, as I had to use my ShatBerry
Now that's out the way, let me begin. As I'm sure you're all aware, the horrific landslides in Thailand have sent Hard Drive prices through the roof. So what can you do? Easy! All you need is one of these.
Yep, a Sky+ box. Now, you can flog these on Ebay, but I'd been keeping an eye on prices they sell for. But, for all the hassle of having to post it and deal with dodgy nigerians who want to send you more by cheque and you return the difference and with Ebay taking their cut, it's not really worth it. Besides the fact that it's just not as fun as taking them apart and smashing stuff So if you've got one lying around, or know a friend or family member who does, go grab it!
The first one I'm going to show you is a fairly old one, left behind by a former housemate (the dark grey one at the bottom in the first pic).
You'll also need some screwdriver heads like these, with star and hexagonal heads. I won't explain which one i used and where, as both boxes had different screws in different places and yours might be different than mine. If you've got a few like in this set then you'll be fine.
First I took out the 3 screws holding the lid on circled in red. Then slid the lid back 'side panel style' to take the lid off completely.
This particluar model has it's Hard Drive inside a 2 peice case. Remove the 3 screws circled above, unplug the IDE cable from the motherboard and lift back the lid to reveal your new Hard Drive. Then simply unplug the 4pin molex power cable and take it out! The one in this case is a 40GB Maxtor Fireball 3 made by Seagate. Although initially I thought 'what a cool name', on second thoughts referring to anything as a 'fireball' in a PC just doesn't sound good. "Introducing the new CPU cooler from Zalman, The Furnace!" No, just not good.
Now while we've got the lid off, have a poke around and see if there's anything esle you fancy salvaging for your current build or future projects.
I'd never turn down a free fan and with just 2 screws removed from the backplate, this little 60mm beauty was mine!
I also quite liked the look of these heatsinks from the PSU. Once I'd undone a couple more screws i took the hole thing out to find they were soldered to the PCB
This is the only soldering iron I have. A hideously old 25W jobbie that used to be my dads.
Now, I would have taken pics of me removing the heatsinks, but on my first attempt to do so burned myself rather stupidly and had to do the rest while holding an ice cube.
As you can see he wasn't impressed either.
So, I'll just have to talk you through it. I held the iron onto the part of the heatsink poking out underneath (about 1mmx2mm) until it had heated up enought to melt the solder, then did the same to the other side and went baqck and forth till i had the solder on both sides in a fluid state. But it wouldn't budge.
On closer inspection, the clip attaching the heatsink to the chip it was taking the heat from was incredably tight. As I had no intentions of using any of the capacitors or anything, i just cut through the 3 pins attaching it to the PCB. With a little more heat and a bit of waggling it came out.
When I finally got the first one off i saw that the parts sticking through the PCB were something that had been stuck onto the heatsink and not part of it. If I were to use them in a build I'd want to file those bits off, so for the others I just clipped the pins for the chip and snapped the heatsink off. Sometimes brute force is the best option!!!
Now onto the second box.
This is the newer white model and according to the details on the back, has an 80GB hard drive at least. Super! I'd Actually fished this one out about a week ago, so had to reverse the process to get pics. There may be a few small parts missing from the pics that i yanked out and chucked, but shouldn't be too much
Remove the lid same as before (although there were 4 screws not 3), and inside you'll find your Hard drive housed in a more familier fashion. 4 screws with anti vibration gromets hold this one in place and it's a sinch to get out. Remove the IDE and 4 pin molex from the back of the Hard Drive first, then take out the 4 screws and it'll pretty much just drop out. Easy peasy
When I pulled it out I got a nice little surprise. It's actually a 160GB Seagate drive from the DB35.3 Series, Product code ST3160215ACE.
There was also a little fan in this one (40mm), but was a bit more of a pain in the arse to get out.
This one was held in with 4 screws and even after cutting out the power cable, i just couldn't get the bottom left one, so the whole mid beam would have to come out.
There was a screw mid way along attaching it to the base through the motherboard. Simple enough for even Sergei the Meerkat to get out. But there was also a screw ncoming through from the front of the case, so the front panel would need to come off.
There were 8 little clips that needed to be pulled back to get it off. 3 on the bottom, 3 at the top accessed through the inside of the case and one on each side. These were really annoying. I had to get a flat-head screw driver to prise them up. I started on one of the side ones, then went along the front of the case doing each top and bottom pair before moving to the next.
Once I'd finally got that off (and taken it to the back garden to give it some Office Space style treatment to vent my frustrations so I didn't let loose on something I wanted) I got the screw out. I had to lift the mid beam up through a gap in the top rail to release the tabs that stuck through the front panel you can see above. It took a fair bit of wiggling and a wee bit of bending but I could finally get to the screw and get the fan out.
Yeh, it was a lot of effort for a crappy little 40mm fan, but hey, not everything you do is gonna be easy. And if it is then you must leave a really boring life . I also got another heatsink from this one today, just the one, but in a nice adonised dark blue.
So here it all is. And it didn't cost me anything!
I hope ya'll enjoyed the thread. Special thanks go out to longweight and mosquito who helped me in my previous thread with getting pics embedded.
http://forums.bit-tech.net/showthread.php?t=224803
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 26th Jan 2012, 21:48   #2
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyan
Yeah, it can be surprising what you can get from dismantling disused equipment. I had about 10 pounds (5 Kg) of screws from old equipment - I threw them all out a few months ago and started again And a crate of fans/motors/etc from tape recorders, dead drives, etc (always good for scrap if you can't use them!). I never throw anything away if it is worth collecting for a scrap run, including old circuit boards.
The bits that pass through the board on those heatsinks are to keep the heatsink grounded, and that also helps to dissipate the heat.
__________________
HeatWare
debs3759 is offline   Reply With Quote
Old 26th Jan 2012, 21:54   #3
The_Crapman
I'm a terrible horder. I've got a nylon cord from a camera i lost on holiday years ago that i've kept. i've no idea what happened to the camera but i might need that strap sometime. maybe.....
i flogged the empty cases to the scrap man who comes round my area, but you could keep them for odd bits on mods and scratch builds. Hell, the older one was big enough to fit an ATX board in! Dam why'd i get rid of it
__________________
Old 26th Jan 2012, 22:01   #4
Nealieboyee
Packaging Master!
Nealieboyee's Avatar
Nealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming Saiyan
Ice cube.
Lolz were had
__________________
CLARISSE
G4560 | Gigabyte GA-H110M-S2H | 8GB Kingston HyperX | GTX550ti | Sandisk Plus 120GB | Corsair CX430 | Cooler Master Hyper 212 PLUS
Nealieboyee is offline   Reply With Quote
Old 26th Jan 2012, 22:38   #5
russ555
Supermodder
russ555 has yet to learn the way of the Dremel
Originally Posted by Nealieboyee View Post
Ice cube.
Lolz were had
Indeed
I will have to give this a try. I have got an old sky+ box but I think the HDD drive in that one died which is why I got a HD box which no longer gets any use so I'm going to see what's in that
EDIT: How do you give rep?
__________________
i5 2500k @ 3.4GHz - Arctic cooling freezer - GigaByte GA-Z68AP-D3 - 8GB corsair Vengeance - MSI GTX 970 - 650W Antec Truepower - Antec One Hundred.
russ555 is offline   Reply With Quote
Old 26th Jan 2012, 22:44   #6
mikeyman198
Lets pretend this is hilarious.
mikeyman198's Avatar
mikeyman198 has yet to learn the way of the Dremelmikeyman198 has yet to learn the way of the Dremelmikeyman198 has yet to learn the way of the Dremelmikeyman198 has yet to learn the way of the Dremelmikeyman198 has yet to learn the way of the Dremelmikeyman198 has yet to learn the way of the Dremel
Originally Posted by russ555 View Post
Indeed
On the left where their name is, at the bottom of the box there is a small person, click that
mikeyman198 is offline   Reply With Quote
Old 26th Jan 2012, 22:46   #7
dancingbear84
error 404
dancingbear84's Avatar
dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.
depending on the model I would say either 250gb or 500gb from memory. Don't forget this is not just Sky boxes but any PVR...
__________________
It doesn't matter if you make a mistake, it only matters if you don't learn from it
dancingbear84 is offline   Reply With Quote
Old 26th Jan 2012, 22:46   #8
The_Crapman
Indeed
Thanks. I try and add a little humour just to make things a bit more interesting. especially in a ridiculously long post like that.
I'd try and research online what hard drive is in them, as the HD boxes do go for a bit more than the older models, anything up to £100. even with ebay taking a cut that's still enough for a nice 60gb ssd. although if you want a good amount of storage i think they've got 1tb drives in.
__________________
Old 26th Jan 2012, 22:48   #9
The_Crapman
Small person. Massive yellow cock. He should really get that checked out
__________________
Old 26th Jan 2012, 23:54   #10
mikeyman198
HAHAHA
Old 2nd Feb 2012, 00:36   #11
IamJudd
Ultramodder
IamJudd's Avatar
IamJudd is a Super Spamming SaiyanIamJudd is a Super Spamming SaiyanIamJudd is a Super Spamming SaiyanIamJudd is a Super Spamming SaiyanIamJudd is a Super Spamming SaiyanIamJudd is a Super Spamming SaiyanIamJudd is a Super Spamming SaiyanIamJudd is a Super Spamming SaiyanIamJudd is a Super Spamming SaiyanIamJudd is a Super Spamming SaiyanIamJudd is a Super Spamming Saiyan
Post 29 in this thread... http://forums.bit-tech.net/showthread.php?p=2761421
But well done for the pictures and walkthrough...
__________________
i5 4690k | HyperX 32GB 2400| ASUS Maximus VII Gene | Antec Kuhler 920
Asus 780Ti Matrix Plat 3GB | Silverstone FT03 | Enermax Revolution 85 920W
IamJudd is offline   Reply With Quote
Old 2nd Feb 2012, 02:37   #12
The_Crapman
Just just an excuse to pull something apart really. always more pleasurable when you dont have to waoory about putting it back together again.
__________________
Old 2nd Feb 2012, 02:56   #13
Throbbi
I Mod, Therefore I Own
Throbbi's Avatar
Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.
I pulled apart an old sky+ box not so long ago to find it was housing a 2.5" Ultra ATA drive which surprised me somewhat. I must get around to taking apart various other bits and pieces which are lying around in boxes lol
__________________
Steam - Throbbi ::WoT -Unpainted_Target ::BF3 - Throbbi
AMD FX-6300-Gigabyte 990AX-UD3-EVGA 660Ti Signature 3GB-Momentus XT-be quiet! E7-600W-Avexir 2x4GB 1600
Share And Enjoy!
Worklog - The Amputer!
Throbbi is offline   Reply With Quote
Old 2nd Feb 2012, 08:15   #14
Wozza365
Modder
Wozza365 has yet to learn the way of the Dremel
just thought id ask, has any actually had successful results with one of these in their PC? they are meant to be encrypted
Wozza365 is offline   Reply With Quote
Old 2nd Feb 2012, 09:28   #15
The_Crapman
Yeh I've got the 160gb one runnin fine. The 'encryption' people have come across is probablywhere they've tried to read stuff that's saved on there
Their encryptions are nothing to the power of my formatting! Muwah ha ha ha haaaaaaaaa
__________________
Old 2nd Feb 2012, 09:51   #16
wodgah
Supermodder
wodgah is the Cheesecake. Relix smiles down upon them.wodgah is the Cheesecake. Relix smiles down upon them.wodgah is the Cheesecake. Relix smiles down upon them.wodgah is the Cheesecake. Relix smiles down upon them.wodgah is the Cheesecake. Relix smiles down upon them.wodgah is the Cheesecake. Relix smiles down upon them.wodgah is the Cheesecake. Relix smiles down upon them.wodgah is the Cheesecake. Relix smiles down upon them.wodgah is the Cheesecake. Relix smiles down upon them.wodgah is the Cheesecake. Relix smiles down upon them.wodgah is the Cheesecake. Relix smiles down upon them.
Nice guide i do have my old sky+ box laying around somewhere! ill see if i can find it!
wodgah is offline   Reply With Quote
Old 2nd Feb 2012, 09:55   #17
suenstar
Collector of Things
suenstar's Avatar
suenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyan
The encryption is really just everything being stored in a file-type that only the software within the Sky box is able to read.
I'm sure a skilled programmer, if enough effort was put in could make the files readable on a PC but it isn't worth it.
As mentioned by The_Crapman, a simple format of the drive and you have a nice empty drive which will function perfectly fine in any machine.
__________________
PSN: suneai | Steam: Critical Clicks | Origin: suenstar | Elite Dangerous & Star Citizen: surren starr
suenstar is offline   Reply With Quote
Old 2nd Feb 2012, 16:10   #18
Wozza365
Modder
I read that it was encrpyted to just be read on a sky machine, and isnt visible to any PC/Mac or whatever, and this makes sense seeing as the 1TB box (which is actually 2TB due to on demand thingy) is only £50 and 2TB HDDs are probably around £100-200
Old 2nd Feb 2012, 18:50   #19
Fizzban
Man of Many Typos
Fizzban's Avatar
Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.
Pretty sure you could still use a nuke program to wipe the drive in dos and make it usable again. Never tried however.
__________________
-Banana in disc drive error-
To win the battle, is to be prepared to die - Miyamoto Musashi
Originally Posted by RedFlames View Post
Asking to pick between the main parties is like asking which testicle you want to be kicked in, you're gonna get kicked the nuts whoever you pick... Just have to hope whoever you pick aren't wearing steelies...
Fizzban is offline   Reply With Quote
Old 2nd Feb 2012, 21:21   #20
Wozza365
Modder
but thats a bit of work just to get what will most of the time be an old 80gb SATA1 hard drive, although i suppose i could put a backup on one of these
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
