Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 27th Jan 2012, 15:47   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Micron's Hybrid Memory Cubes win tech award
Micron's three-dimensional Hybrid Memory Cube technology has won it an award from The Linley Group.
http://www.bit-tech.net/news/hardwar...mc-win-award/1
brumgrunt is offline   Reply With Quote
Old 27th Jan 2012, 17:12   #2
azazel1024
Supermodder
azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.
This doesn't sound remotely like FINFET technology (Intel's trigate transisters). One is a 3 dimensional interconnect instead of being planar (2d interconnect). This is actual interconnects BETWEEN transitors, not within the transistor itself (which is what FINFET is all about).
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 27th Jan 2012, 17:29   #3
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Which is why I said it was "not dissimilar," rather than "exactly the same." Both are about extending things which are usually two dimensional into the third dimension.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 28th Jan 2012, 16:02   #4
ffjason
Multimodder
ffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysis
lol @azazel1024 - you been told!!
ffjason is offline   Reply With Quote
Old 28th Jan 2012, 17:08   #5
ch424
Design Warrior
ch424's Avatar
ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.
azazel1024 is correct though, tri-gate transistors and stacked dies do have very little in common.
ch424 is offline   Reply With Quote
Old 29th Jan 2012, 12:57   #6
Bakes
Hypermodder
Bakes has yet to learn the way of the DremelBakes has yet to learn the way of the DremelBakes has yet to learn the way of the Dremel
That is the only way in which they are similar, though. By the very same logic, you could add 3D printing to the list. In fact, it seems as though 3D printing is actually a superior analogy to use!
Bakes is offline   Reply With Quote
Old 30th Jan 2012, 09:09   #7
Gareth Halfacree
WIIGII!
bit-tech Staff
Sure, that's a superior analogy - if you ignore the fact that it's about improving computing power and performance by extending things which are traditionally two dimensional (either the transistors themselves in tri-gate or arrays of transistors in HMC) into the third dimension. Then 3D printing is a pretty poor analogy, wouldn't you say?
__________________
Old 30th Jan 2012, 12:07   #8
Bakes
Hypermodder
Not particularly. There have been many attempts to improve computing power by integrating 2d packages into 3d.
The Apple processors for example have several dies inside, mounted atop each other, in order to reduce space - using what I can only assume is a similar method (might not be, but the article is unclear).
With 3D printing, layers are often printed atop each other, with chemical bonds joining the layers together, improving the process.
If you consider your exact wording,
vertical conduits that allow components to be connected in a three dimensional mesh, in a way not dissimilar to Intel's tri-gate transistor technology
you can see that your comparison is not correct, with the technologies being different. Tri-gate transistors are three dimensional, sure, but I fail to see the vertical conduits linking layers of silicon you speak of in their production process.
Old 30th Jan 2012, 12:11   #9
Gareth Halfacree
WIIGII!
bit-tech Staff
If you consider your exact wording, [...] you can see that your comparison is not correct, with the technologies being different.
Okay, my wording was unclear: I didn't meant to infer that tri-gate uses TSV (although I can see how it reads that way,) but simply that tri-gate is another example of 2D-to-3D in chipmaking. In retrospect, it'd have been much clearer as a separate sentence: "Another example of chipmakers taking a 2D technology and expanding it to the third dimension is..."
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
