Reply
Thread Tools View Mode
Old 1st Feb 2012, 19:35   #41
bugeye
Sleep Deprived
bugeye has yet to learn the way of the Dremelbugeye has yet to learn the way of the Dremelbugeye has yet to learn the way of the Dremel
Looks like you've got it covered then
This is already looking sooooooo good , something about properly thick bits of metal and you went with my favourite out all your designs
bugeye is offline   Reply With Quote
Old 1st Feb 2012, 19:40   #42
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
Dang it Waynio... I've spent the last hour looking at scroll saws now.... You've got me wanting one!
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 1st Feb 2012, 23:21   #43
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Cheers mate I'll give the other blades a try on the 10mm alu because there is still quite a lot to do of that & I don't rule out tips ever, could well be right & the 12 TPI or 25 TPI cut it easier.
I love the way Attila left frames made from bars in the past, just looks really cool while adding a ton of strength compared to normal bars & my alu supplier really improved to get customers back so the option to go chunky was a real one now without it costing heaps, but there is some basic bar frame work going on in the gaming case but it's all hidden from view & it's a pretty complex self supporting frame work that plays an essential part of the rigs functionality, glad I managed to put a lot of thought into the design this time.
Hope to get the HTPC side panels done tomorrow.
Sorry can't be helped as I'll be making a lot of it with the scrollsaw , I feel the same about mills & lathes & even routers but think a router is within my reach at least .
Waynio is offline   Reply With Quote
Old 2nd Feb 2012, 00:46   #44
Mosquito
Hypermodder
Mosquito's Avatar
I have a router... or two.... But I wouldn't mind a mill either oh the fun that could be had with no budget restrictions.....
__________________
Mosquito
Old 2nd Feb 2012, 13:41   #45
Combatus
Custom PC/bit-tech modding sections
Combatus's Avatar
Combatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for president
Seeing as you pulled the last one off in spectacular style, I'll be keeping a close eye on this one!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES! | Mod of the Month March 2013 is here! Vote now!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 2nd Feb 2012, 17:22   #46
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
Can't bear to miss any of this! Wonderful stuff once again!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 2nd Feb 2012, 21:55   #47
Waynio
Waynio's Avatar
Certainly would be fun eh.
And like people with mills say, you always want something even better & I expect it's very true.
And then people with full access to the best stuff, they just say lets make something amazingly awesome.
And then you get average joe modders often making highly excellent stuff with normal tools but takes forever to do.
I only know how satisfying it is to do the long way when you have all your pieces ready to put together but it is a really awesome feeling putting those final bits together.
Cheers Antony.
Cheers Kidmod.
Started a bit late but because of skipping yesterday I just wouldn't stop until I got 1 of them done.
Tried the 12 TPI & they cut really well but only for about 2 inches & then they get pretty blunt & struggle to cut more so I'll stick to the 18 TPI, seem to get a whole lot more done with those on the 10mm alu.
Snap, this happens more than I like but not too often.
Continue
Neeeeeed fuel awesome pasta pesto 10 minute quick fix of goodness with a good kick of scorching chillies.
Woo hoooooo feeling 50 times better so time to get this panel finished.
More soon
Old 3rd Feb 2012, 16:08   #48
KidMod-Southpaw
Wonderful stuff! And a great meal.
__________________
Old 3rd Feb 2012, 16:14   #49
Monsieur R.
In cornichons I trust.
Monsieur R.'s Avatar
Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!
Finally you're done with this part. Will you file the inner part, or are you satisfied with the finish ? I'm amazed how this tool can create regular edges. Very nice and clean.
__________________
“If you don't know what it is, it may be edible.”
— Mod or not mod, leçon n° 27 —
Monsieur R. is offline   Reply With Quote
Old 3rd Feb 2012, 17:20   #50
Waynio
Waynio's Avatar
But it really takes a big toll on the patience thanks mate.
I'm sure I could have used a jigsaw for this getting it close to where I want it & filed it in a far quicker time but for some reason I cut right up to the lines which takes a lot of concentration with it moving so slow, but with it being up to the line it will only need a light sanding to get them exactly how I want them & I have an idea for making my own sanding blades to make quick work of it, an easy idea I started doing a while ago of using strips of paper pulled tight on both ends & pull back & forth through the material to get it smooth, I'm thinking a piece of card with various grits of wet dry paper stuck to it on both sides & use it as a scroll saw blade, the saw allows for a slack tension up to tight where you place the blades.
At this moment though I'm unable to do zombie endurance focus mode so need some better mental stimulation so I'm going to have a gaming session for the rest of today.
Working the scroll saw is fun but only for easier materials, the band saw blades eat through the 10mm alu really well at a good pace so I'll mod a couple of them to allow me to do curve cuts easier & I should be able to get a lot done tomorrow then.
It takes an incredible amount of time to get through while keeping it so the edges only need a light sanding so I'm going to grind down 1 of the band saw blades so they are able to do curves better, my patience to get through the 10mm with super thin fretsaw blades has vanished.
Old 3rd Feb 2012, 19:39   #51
Waynio
Waynio's Avatar
Figured it would only take a couple of minutes to mod a band saw blade by grinding it so went & done it & tested it & it works awesome.
Took a few seconds to get from the start hole to be just inside the line for the cutting & can easily do the curves I need it to while eating though it nicely.
And since I'm not 100% happy with the front chunky piece for the HTPC because of a tiny error while getting used to the 10mm alu I will continue to do the whole project & make notes of any bits I botch so I can make another order to re do any bad parts so it all stays to plan.
I looked on ebay for 10mm alu plate & it is far more expensive than the place I buy from, to get a replacement piece from the shop it would be £3 on ebay it would be £21 for double what I need so if I wait until I have all panels & bars ready to fix together then I won't waste money on postage unnecessarily.
Old 3rd Feb 2012, 21:24   #52
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.
Sticking to the line - Check!
Good job man, can't wait to see this beast come together!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 3rd Feb 2012, 22:55   #53
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.
Looking good mate!! Good thinking with the band saw blade... Never figured me for an ALU guy, but that 10mm looks sweeeeeeet potato!
__________________
Revelation (in progress)
R-KAID-Я (on hold) / The Shrine / REDELUX / 4M / R-kaid-6
http://www.facebook.com/enannanvision
quizz_kid is offline   Reply With Quote
Old 4th Feb 2012, 06:00   #54
Waynio
Waynio's Avatar
Cheers Martin it was going unbelievably slow when using the fretsaw blades but think I should get all this 10mm alu done nice & fast now & even get the edges cleaned up with the sanding blade idea, might even be able to do that simply by folding over some wet dry paper & placing a piece of card in between so it can be held in without ripping, I'll test out the sanding idea today.
Cheers mate & switching to the modded blades will let me breeze through the 10mm now compared to the fretsaw blades.
Hope to make some significant progress today especially with being up at a good time.
Old 4th Feb 2012, 10:23   #55
Waynio
Waynio's Avatar
Soooooo much better than days getting nowhere, took about 2 hours to do.
Next up is the bigger plates shown here.
Old 4th Feb 2012, 11:39   #56
bugeye
Sleep Deprived
mmmmm chunky
Old 4th Feb 2012, 12:35   #57
Waynio
Waynio's Avatar
mmmmm chunky
It had a very successful diet there weighs loads less now.
Just got the stand design printed & cut ready for sticking to the last of the 10mm plate & I'll be using the adhesive spray so should be a quick task.
Old 4th Feb 2012, 13:44   #58
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Amazing job and perfect cuts there bro!!! Are u a robot or something?? Man you have a natural talent in modding thats for sure!!!! And I love the pace of the updates!!!! Mod on brother!!!
AnG3L is offline   Reply With Quote
Old 4th Feb 2012, 13:58   #59
Marcos_Viegas
Supermodder
Marcos_Viegas's Avatar
Marcos_Viegas has yet to learn the way of the Dremel
These cuts in aluminum are perfect as always!
Congratulations Master Waynio, as always doing your projects to perfection!
EDIT:
I forgot to say I finished my new project http://forums.bit-tech.net/showthread.php?t=218830
__________________
My actual project:
Marcos_Viegas is offline   Reply With Quote
Old 4th Feb 2012, 14:18   #60
KidMod-Southpaw
This is coming along quickly and ever so nicely! Well done!
__________________
Reply
Tags
dual pc, heavy bottom, modular, top heavy
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
