News Intel's first Haswell chip pictured
Discussion in 'Article Discussion' started by brumgrunt, 30 Jan 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Mmhmm.......yeah........mmhmm........I know some of these words
    Action_Parsnip likes this.
  3. kenco_uk
    28 Nov 2003
    Resistors usually shrink, surely?
  4. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Is that another complete die up on the top of the chip? Surely covering that with a heat-spreader and making sure that it isn't crushed is going to be a hell of a challenge?
  5. mark@scan
    mark@scan Product Manager
    21 Jun 2007
  6. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    I thought the graphics processor in Ivy Bridge was already a vast improvement on Sandy Bridge, even if the rest of Ivy Bridge is merely a die shrink. Is the graphics processor in Haswell 'significantly improved' from Ivy Bridge.
  7. Gareth Halfacree
    4 Dec 2007
  8. azazel1024
    azazel1024 What's a Dremel?
    3 Jun 2010
    Well sure I'll wait till Hawell comes out instead of upgrading from my Core 2 duo. Wait, when Haswell is almost out the door, the Haswell lithography shrink will amost be out...I should wait for that, but when that is almost out...
    I am going to finally spring for an upgrade to probably the 2500 or 2600 equivelent of IB (whatever those are again) around early June (a slightly delayed birthday present) and probably a mid-grade 7000 series AMD discrete GPU. I'll eye Haswell with jealousy, but unless something truely revolutionary drops from Intel along the way, I'll probably wait at least 2-3 years (maybe 4) before upgrading again (I got my core 2 duo 3 years ago this spring, though admittedly at the time I was buying about 18 month old tech when it hit and lowish end, this time I am going to go near top end for the CPU).
  9. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    With that thought process, you could be waiting forever. After Haswell comes the 14nm die-shrink Broadwell, which is rumoured to be the moment that desktop CPUs start turning into SoCs with Ethernet/USB 3.0/Thunderbolt controllers being integrated on-chip.
    Beyond that, there'll be Skylake, which they're probably targeting for DDR4 and PCIe 4.0 support and is supposed to incorporate technology from the Larrabee project (instead of a CPU+GPU on-chip as we have now, the CPU BECOMES the GPU). That in turn, will be shrunk to 10nm with Skymont...
    Best advice is to buy what you need, when you need it unless the new tech is < 3 months around the corner.
  10. Deders
    Deders Modder
    14 Nov 2010
    Isn't ivy bridge the tock? is it that much different from Sandy bridge in terms of architecture and technology?
  11. Ayrto
    Ayrto What's a Dremel?
    20 Jun 2007
    Haswell uses an LGA1150 socket instead of the LGA1155 so it'll need a new motherboard featuring the LGA1150 socket.
  12. Ayrto
    20 Jun 2007
    Not alone in that. It does seem counterintuitive for a new architecture to be on the 'tock'.
  13. Action_Parsnip
    Action_Parsnip What's a Dremel?
    3 Apr 2009
    They mostly come at night, mostly?
    *ahem*
  14. 3lusive
    3lusive Minimodder
    5 Feb 2011
  15. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    To be honest I'm never going to wait for anything in particular. I'll just buy whatever I think is the best for my needs at the time.
    My laptop life cycle seems to be about 4-5 years, so I've got another 2-3 years to go.
    I may build a new desktop before then, but probably not as I don't have the disposable income these days.
  16. Deders
    Deders Modder
    14 Nov 2010
    so do I... mostly....
  17. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    I'm gonna wait for the Roswell chip, apparently scientists are working on it in the New Mexican desert as we speak! It must be true I read it in a newspaper.
  18. azazel1024
    3 Jun 2010
    Well I'd say buy what you need when you want to upgrade...though that being said, if you know a new generation of chips is just about to be released, it hurts little to wait a few weeks or a couple of months to upgrade. Personally I don't like buying in at the initial release, prices tend to be higher and I don't want to find out that there is some kind of tragic error in silicon (see Cougar Point chipset issue and SB-E Vt-d issue). So for me it is buying in about 4-8 weeks after launch. So if Intel comes out with IB in April it'll be May before I buy in, though probably June. Wait till just after my birthday as a delayed birthday gift. That and I have a medium sized software release at my job coming up early June and should be working enough overtime for the release to pretty much pay for most of the upgrade.
  19. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Can it play............no i won't say it ;)
Tags: Add Tags
