Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 19th Mar 2012, 18:10   #21
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
How about giving us a model number of your router ? Without it, we are in dark.
faugusztin is online now   Reply With Quote
Old 19th Mar 2012, 19:25   #22
Cleggmeister
Of reasonable knowledge...
Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.
Hold on, just to be clear have you connected all your devices to the switch and just taken one cable from the swich to a router LAN port? Thats how it should be but your last post isnt clear. Try different ports on your router too, you may have an iffy port.
__________________
Pooting: Antec 300, P6T SE, i7 920 (3.20), Corsair F120SSD, 3x1TB HDD, 9Gb (1600XMP), GTX560Ti 2Gb (880/1760/2100), Win7 x64. Raspberry Pi B with OpenElec.
Grooving: Linn LP12, Klimax DS, Klimax Kontrol, Aktiv Akubariks. Linn Sekrit DSI +104's + Velodyne sub
Watching: Raspberry Pi running OpenELEC to 50" Panasonic.
Serving: HP Proliant Microserver N40L running Openmediavault.
Cleggmeister is offline   Reply With Quote
Old 19th Mar 2012, 21:16   #23
LDJ
Minimodder
LDJ has yet to learn the way of the Dremel
Sorry, its a TP-Link TD-W8960N v3 0x00000002. Firmware Version: 1.4.0 Build 111108 Rel.40398n
LDJ is offline   Reply With Quote
Old 19th Mar 2012, 21:18   #24
LDJ
Minimodder
Yep, apologies for the confustion. Everything plugged directly into the switch, then the single ethernet between router and switch.
Router ---> Switch
PC ---> Switch
HTPC ---> Homeplug ----> Homeplug --->Switch
Reply
Tags
adsl, homeplug, lan, router
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
