Reply
Thread Tools View Mode
Old 30th Jan 2012, 20:03   #1
z3bb0
Minimodder
z3bb0 has yet to learn the way of the Dremel
(Buildlog: custom case) Building the beast!
So I wanted a case that could aircool and watercool so I spent some time designing my own case using sketchup and ended up with this (changed from inverted to norml mobo tray later on) :
wont be using that crazy hardware but still
this is what what I'll be using to build the frame, with a ATX psu for reference
metal in da hause?
done!
picked up 2 180mm fans from silverstone, airpenetrator ones
really big as you can see, the case in the background is a Fractal design R3
built in fancontroller for 2 fans I think? awesome
This is how there going to sit in the case, tall? oh yezz
how they look next to the frame
found this old harddrive cage and modded it to fit 2 hdds, might use it.
got the plate to hold the 2 180s in the front in
pretty big huh?
I/O shield, on/off button, dust filters and some fan grills
the beginning of a 5.25 bay
how I'm going to fit the I/O shield and back fan
still room for a mid plate
and plenty of room for a 120mm fan
3.5cm of cable management room behind the mobo tray
can go for 2 120mm fans but not sure if I actually want to
9cm of room for fan and rad
picked up some mesh, alot actually
custom fan grills anyone?
looks pretty beast
I/O shield mounted and back 120 is mounted
outside view, ignore the scratches
back with fan mounted
outside view with fan, looks okay?
3 5.25 D-drives mounted
carbon fiber !!! cheap stuff though :/
wont be running out of this for awhile
Had to try it out some Looks okay??
z3bb0 is offline   Reply With Quote
Old 7th Feb 2012, 18:27   #2
z3bb0
Minimodder
Originally Posted by peteski View Post
looking sweet mate keep up the good work
thanks , my only reply
Update
Start of a new rad holder for the top
done
mounted and fans fitted
got a handle for the back 120fan grill and a 30CM ruler for reference
here's the dust filter mounted on the 180 airpenetrator fan
180s mounted in the case
the piece of paper is 17x17cm which is about the size of an mini-itx motherboard. So I could get 2 systems in there
the cpu power for the top of the motherboard is no where as long as it needs to be, sure this psu has an extra short cable but still I'll be needing some extensions
that's all for now :roll: Hoping to get the motherboard tray in soon..
Old 12th Feb 2012, 15:17   #3
z3bb0
Minimodder
some pics of the rig that's going to be installed in the case
tried to take some pics of the gpus but I don't really know how to use this camera but I'll figure it out soon
Old 12th Feb 2012, 19:48   #4
z3bb0
Minimodder
pics of the gpu look good mate
Thanks man I'll be taking some pics with the camera when I changed the lens and maybe I'll be able to focus on the card instead of the background Thanks for commenting
Old 14th Feb 2012, 23:30   #5
z3bb0
Minimodder
Originally Posted by Bladesingerz View Post
Nice stuff so far! Good luck on soldering extensions on that PSU, its a pain!
No I'm just using this psu as a try out I'll be using my TX850 from corsair
Old 18th Feb 2012, 16:46   #6
z3bb0
Minimodder
Yay, I got the motherboard mounted and it sits there good.
Case with the motherboard in.
from behind
2 L brackets to secure it
2cm cable management space under the bar, 3.5cm elsewhere.
also changed the PSU mount to be able to mount the psu with the fan down
nearly 5cm of breathingroom
That's all for now
Old 18th Feb 2012, 17:51   #7
z3bb0
Minimodder
Originally Posted by monkiboi View Post
What's the proper name for those corner connectors so I can find some. I presume by the following pics the tubular bars slide or fix on to them somehow?
I have no clue what they're called in english :/ but you slide them in using some force using a hammer and they sit firm...
Old 18th Feb 2012, 23:12   #8
z3bb0
Minimodder
Originally Posted by dwinsor View Post
Can i ask where you got them from have been looking to do the same with a case design.
Bauhaus, it's a swedish store btw..
Old 19th Feb 2012, 00:47   #9
z3bb0
Minimodder
coming along nicely mate keep up the good work
Thanks mate
Old 28th Feb 2012, 19:24   #10
z3bb0
Minimodder
quick update
one sidepanel done and the roof is soon done + midplate :P
that's all for now
Reply
Tags
aircooling, custom, fulltower, gaming rig, scratchbuild
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
